harrycrackerdog Samba Member
Posted: Mon Mar 20, 2017 1:17 pm Post subject: Hockey Stick stuck |
Hello
now before I ask, i am going to admit being a little dumb and not checking for movement before i barged ahead with fitting my new transmission.
I purchased a rancho swing axle street transmission and had to change the nosecone for a bus one to fit my 59 ghia chassis, with a bit of pushing an pulling it slid in just fine, i got excited and carried on fitting up everything else on a fresh build one month later I went to fit my new berg shifter and quickly found the hockey lacked any movement (very slight back and forth in car) but obviously not selecting gears
I have never had to fit a nosecone before so it seemed straight forward enough but what have I done wrong ?
Before I have to pull out the transmission is there anything i can do to rectify issue ? I had read about pushing fork selectors through oil fill hole ?
any advice greatly appreciated thanks
Paul. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Mon Mar 20, 2017 2:35 pm Post subject: Re: Hockey Stick stuck |
Did you use the bus hockey stick or a type 1? _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Mar 20, 2017 3:40 pm Post subject: Re: Hockey Stick stuck |
Rancho sent the bus cone with a stick so I used that one but they knew what it was for.
The dimple seems in the correct place
Honestly I do not know the difference
Thanks
Paul |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Mon Mar 20, 2017 5:02 pm Post subject: Re: Hockey Stick stuck |
It would look different than the other one you got. It should have a bent leg to the tip. |
Posted: Tue Mar 21, 2017 12:11 am Post subject: Re: Hockey Stick stuck |
Ok I can only assume right now it's the bus stick as it came with it from Rancho
What stick did I need ?
If the bus stick is correct and it won't move do I still need to pull the transmission ?
Thanks
Paul |
jason Samba Member
Posted: Tue Mar 21, 2017 9:01 am Post subject: Re: Hockey Stick stuck |
Take it back off and make sure no gear is selected and put the hockey stick between the fingers. I usually move it back and forth while tightening. An OCD thing I guess. |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1170 Location: San Angelo, Texas
Posted: Tue Mar 21, 2017 9:45 am Post subject: Re: Hockey Stick stuck |
It is possible to have a gear pulled and have the hockey stick in a position to pull some other gear. Before you do anything, take the gear oil filler plug out of the side of the case and see if you can move the 1/2 slider back in the neutral position. (You may have first or second gear engaged and the hockey stick in the 3/4 shift rod.)
This will save having to do considerable work. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
jason Samba Member
Posted: Wed Mar 22, 2017 2:50 pm Post subject: Re: Hockey Stick stuck |
That urethane coupler probably wont last long either. Mine broke before it even got back on the road. Ill never use urethane again. Everything urethane Ive tried fails super quick. |
Posted: Wed Mar 22, 2017 3:02 pm Post subject: Re: Hockey Stick stuck |
If you have solid mounts, you don't need any cushioned mount at all. I use machined aluminum blocks in place of the rubber in a stock coupler. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
miller0358 Samba Member
Joined: November 07, 2007 Posts: 1200 Location: northford,ct
Posted: Thu Mar 23, 2017 6:34 pm Post subject: Re: Hockey Stick stuck |
You need to take the nose cone back off and make sure your not stuck between gears. Line up the levers so the trans. is in neutrel. Then reinstall the nosecone. Jeff |
Posted: Thu Mar 23, 2017 7:28 pm Post subject: Re: Hockey Stick stuck |
If it is in 1st or 2nd and the hockey stick is in 3rd and 4th, you can put it in neutral via the filler plug in like 10 seconds. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
jason Samba Member
Posted: Thu Mar 23, 2017 7:37 pm Post subject: Re: Hockey Stick stuck |
especially with body off. |
Posted: Thu Mar 23, 2017 7:45 pm Post subject: Re: Hockey Stick stuck |
yeah, if you can see what your doing, maybe 5 seconds. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
bigfuninc Samba Member
Joined: February 13, 2007 Posts: 61 Location: Maple Ridge B.C. Canada
Posted: Sun Oct 22, 2017 2:10 pm Post subject: Re: Hockey Stick stuck |
How do you get into neutral thru fill hole? |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Oct 23, 2017 8:36 pm Post subject: Re: Hockey Stick stuck |
For reference from hazetguy.
Here's the way that the shifter forks should look when in neutral. The slots for the hockey stick are all in line.
If they are not in line, then the transmission is shifted in to a gear.
Even though it's a splitcase tranny in the pic,
tunnel types will still have the slot for the hockey stick in line when in neutral.
Transmission shift forks in "neutral" position. All 3 slots are in line and the same height.
When installing a nosecone on the tranny, make sure the shift rod moves smoothly in the nosecone bushings with no binding or tight spots.
Lower the shift rod out of the bottom of the nosecone to engage the shift forks on the transmission.
Also make sure the tranny is in "neutral", and that the end of the shift rod engages the forks while lowering the nosecone onto the transmission.
Also make sure the tranny is in "neutral" (as seen in pic), and that the end of the shift rod engages the forks while lowering the nosecone onto the transmission.
(Note, this is a demonstration photo, with no gasket installed) _________________ Good Luck
Al |
