UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Fri Nov 17, 2017 1:30 am Post subject: Re: Valve ajustment and THIS happens! |
You have to make sure it's cleaned and oiled, but....how? Can't take it apart, clearances are too tight to pour oil through it, so you have to soak it or something. In a hurry I heat them up in oil and let the oil pull itself in as it cools.
We are assuming whatever oil is on them is just rust protector, and I don't know if it is, but better safe than sorry. ANd IMO, use gear oil. |
fccperdiem Samba Member
Joined: August 16, 2005 Posts: 107 Location: Ellsworth, Maine
Posted: Fri Nov 17, 2017 1:04 am Post subject: Re: Valve ajustment and THIS happens! |
What does the oil soak accomplish? _________________ Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com |
Daddybus Samba Member
Posted: Sat Oct 21, 2017 4:45 pm Post subject: Re: Valve ajustment and THIS happens! |
nsracing wrote: |
Out of ...jail? Something about self-exposure to the outdoors.
The Berg swivels have been terrible of late. I have bought several sets before and used them all without issues. Then these newer units had issues w/ the tails coming off like that. They are too brittle -IMO. maybe someone needs to adjust the heat-treating or annealing one of them.
Only option that lasts some time is the Porsche units. Not cheap but absolutely the best. |
My Berg swivels have a slotted end. Empi (junk) have the Allen head ends and cost 1/2 as much as Bergs. Yes, I cried twice (empi junk broke) and went with Bergs. You're supposed to presoak the Berg adjusters in motor oil (for 24hrs or something like that) before installation. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sat Oct 21, 2017 11:49 am Post subject: Re: Valve ajustment and THIS happens! |
I agree.....and for the record...Virtually none of the "OEM quality" swivel feet adjusters have the Allen wrench adjuster feature.
http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=911-70-73§ion=103-15
Scroll down on that link diagram and click on the part # for #49 and it will bring up three part #'s and Prices...from about $37 each for actual parts from the Porsche dealer...and about $25 for the same part from Mahle which was an OEM supplier of this part and one for about $20 that just lists OEM which is also Mahle or Mahle/Weizman.
There are more than a handful out there of swivel feet....but the OEM build design and construction/material quality are just so much better than anything out there...that if you use swivel feet and need swivel feet and have serious $ and care and time invested in your engine...its just not worth using the cheaper alternatives.
The material and construction quality and design difference is that big. The closest to it are the original Ford/Mazda swivel screws...OEM not knock-offs...and they do not do as well on type 4 but work well with type 1 rockers in stockish cam lift range. Ray |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sat Oct 14, 2017 8:31 am Post subject: Re: Valve ajustment and THIS happens! |
I can sell anyone here genuine Porsche adjusters for $220 shipped, and 10mm tool steel Elephant Bus adjusters for $97 shipped. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3438 Location: San Diego
Posted: Sat Oct 14, 2017 8:24 am Post subject: Re: Valve ajustment and THIS happens! |
I bought a set or Porsche not long ago - $275 for 8 |
Posted: Sat Oct 14, 2017 7:10 am Post subject: Re: Valve ajustment and THIS happens! |
bluebus86 wrote: |
I had some elephant feet adjusters on a type IV, not sure of the supplier, but they were of a poor material choice, the ball end of the screw punched its way thru the foot pad on several of them. soft weak foot pad is my guess. went back to regular adjuters after that. Total junk.
good luck |
And.....this is why we spend those stupid prices on the OEM Porsche swivel feet.
Ray |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Oct 14, 2017 3:16 am Post subject: Re: Valve ajustment and THIS happens! |
I bought some T4 heads and the valve stems on some were hollowed out- I think that happens when the valve sticks or floats and the ball rotates off the flat spot and runs on the round bit.-- way prefer elephants feet. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
bluebus86 Banned
Posted: Sat Oct 14, 2017 12:02 am Post subject: Re: Valve ajustment and THIS happens! |
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Oct 13, 2017 8:03 pm Post subject: Re: Valve ajustment and THIS happens! |
mark tucker wrote: |
SamT wrote: |
I guess you could just adjust it and tack weld it! Or clean it up good and JB weld it. |
Hey ROCK CRUSHER IS OUT!!!!AND HAS A NEW NAME!!! the jb kid for sure. |
He still owes me $1,100.00. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
nsracing Samba Member
Posted: Fri Oct 13, 2017 7:12 pm Post subject: Re: Valve ajustment and THIS happens! |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Mar 22, 2017 1:25 pm Post subject: Re: Valve ajustment and THIS happens! |
SamT wrote: |
Damn haven't heard his name in a while. He is from our coast Mark. Pennsyltucky! _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
mark tucker Samba Member
Posted: Wed Mar 22, 2017 1:15 pm Post subject: Re: Valve ajustment and THIS happens! |
SamT wrote: |
Posted: Tue Mar 21, 2017 8:07 pm Post subject: Re: Valve ajustment and THIS happens! |
SamT wrote: |
"I'm only trying to help" "There--aint dat better" _________________ some days I get up and just sit and think. Some days I just sit.
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Tue Mar 21, 2017 7:22 pm Post subject: Re: Valve ajustment and THIS happens! |
I guess you could just adjust it and tack weld it! Or clean it up good and JB weld it. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
joemo5 Samba Member
Joined: August 13, 2009 Posts: 78 Location: Atoka, TN
Posted: Tue Mar 21, 2017 6:39 pm Post subject: Re: Valve ajustment and THIS happens! |
I called Gene Berg ENT today and they are going to hook me up. Thanks everybody for the response |
modok Samba Member
Posted: Tue Mar 21, 2017 4:29 pm Post subject: Re: Valve ajustment and THIS happens! |
tommiebsmith wrote: |
Looks like that is a BERG setup s |
yep, hex adjsuters, the steel center spacer, head nuts on holding it on. BERG
Stock rockers are not rare AT ALL, so any vw nut will probably give you one for free. I would. but a new swiel adjuster is not free. I think ACN sells singles of the porsche ones, and they should be comparable |
Posted: Tue Mar 21, 2017 9:27 am Post subject: Re: Valve ajustment and THIS happens! |
This is common when the lock nut is over-tightened. I have even sheared off my share of them before I learned. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
