jleavitt73 Samba Member
Posted: Tue Mar 21, 2017 8:03 pm Post subject: Stock transmission paired with big motor |
Is my stock 74 Super Beetle transmission strong enough for a 1835cc engine? Basically, am I going to break things if I dump the clutch? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Tue Mar 21, 2017 8:08 pm Post subject: Re: Stock transmission paired with big motor |
I've broken a stock 74 tranny with a stock 1600.
Abuse it and it will break.
Remember, you're talking about a 43 year old transmission. Who knows it internal condition. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 21, 2017 8:15 pm Post subject: Re: Stock transmission paired with big motor |
So basically do burn outs at your own risk |
modok Samba Member
Posted: Tue Mar 21, 2017 8:50 pm Post subject: Re: Stock transmission paired with big motor |
Never dump the clutch. At least pre-load it.
If it hops then just don't do it.
If you want to impress morons put on some hard old snowtires on the rear |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Tue Mar 21, 2017 9:04 pm Post subject: Re: Stock transmission paired with big motor |
Not just the transmission, but any wheel hop is gonna kill your nose cone and leave you stranded. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
EVfun Samba Member
Posted: Tue Mar 21, 2017 9:47 pm Post subject: Re: Stock transmission paired with big motor |
Beetles have a lot more drive wheel traction than RWD American cars. A 40 horse engine can destroy a stock transaxle if you insist on dumping the clutch. _________________
Wildthings wrote: |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Wed Mar 22, 2017 3:36 am Post subject: Re: Stock transmission paired with big motor |
I had a stock trans in all summer
1915 'Turbo' even made 6 passes down the drag strip it's all in the pre-loading _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Wed Mar 22, 2017 7:16 am Post subject: Re: Stock transmission paired with big motor |
jleavitt73 wrote: |
I've run an 1835cc DP engine for 4 decades now. Stock clutch, and stock transmission in both my 1970 VW and my 1971 VW. No issues, but I don't race mine either, and I redline at 4500 rpm maximum. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
kokanee Samba Member
Joined: April 15, 2007 Posts: 329 Location: Washougal WA
Posted: Wed Mar 22, 2017 7:20 pm Post subject: Re: Stock transmission paired with big motor |
If the trans is in good shape it will be fine as others have said don't dump the clutch from a stand still |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Mar 22, 2017 7:36 pm Post subject: Re: Stock transmission paired with big motor |
I say dump the clutch at will. The guys that build air-cooled transmissions need customers to stay in business and continue to supply us with quality rebuilt boxes. |
modok Samba Member
Posted: Wed Mar 22, 2017 7:40 pm Post subject: Re: Stock transmission paired with big motor |
Yeah. do a burnout in reverse! |
Posted: Wed Mar 22, 2017 7:59 pm Post subject: Re: Stock transmission paired with big motor |
modok wrote: |
see if the gear will come out of the case |
vw moses Samba Member
Joined: April 17, 2012 Posts: 213 Location: independance,louisiana
Posted: Fri Jun 12, 2020 8:59 pm Post subject: Re: Stock transmission paired with big motor |
lots of mounts to help trans to be rigid, but if you have a stage 1 pressure plate i heard get a heavy duty throw out bearing shaft, stronger welds at the arms _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
63 one of a kind beetle. 57 dash,double rear window--sweet!
EVfun Samba Member
Posted: Fri Jun 12, 2020 10:11 pm Post subject: Re: Stock transmission paired with big motor |
kokanee wrote: |
modok wrote: |
Funny story about that... As a bit of an electric car guy I can forget about the clutch at times, not needed in an EV. So with the engine freshly started, idling at about 900 rpm with the choke partly on, I absent mindedly just flicked the stock 40 horse box into reverse. Popped right in without grinding and the car lunged backwards. Didn't kill the engine and didn't seem to cause any harm to the transaxle either. _________________
Wildthings wrote: |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Sat Jun 13, 2020 4:57 am Post subject: Re: Stock transmission paired with big motor |
Would likely have stalled in a forward gear. Weight shift thing, Modoc is correct.
My Rabbit would do burnouts all day in 1st or 2nd but would just smoke the clutch in reverse. Weight shift thing! |
Cusser Samba Member
Posted: Sat Jun 13, 2020 7:59 am Post subject: Re: Stock transmission paired with big motor |
Cusser wrote: |
I've run an 1835cc DP engine for 4 decades now. Stock clutch, and stock transmission in both my 1970 VW and my 1971 VW. No issues, but I don't race mine either, and I redline at 4500 rpm maximum. |
Still fine, and that 1971 transmission has NEVER been out of the VW. Original CV joints/boots too ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
MitchS046 Samba Member
Posted: Sun Jun 14, 2020 2:17 pm Post subject: Re: Stock transmission paired with big motor |
modok wrote: |
If it hops then just don't do it. |
sorry kind of a noob In the performance scene but couldn't help to wonder how the hell you preload your trans. had a look on the old inter webs but couldn't find anything about it..... _________________ Slow is smooth, smooth is fast,
~ mark divine |
nsracing Samba Member
Posted: Sun Jun 14, 2020 2:24 pm Post subject: Re: Stock transmission paired with big motor |
You people are funny. that iddy biddy 1835cc will not crash that box w/ stock clutch. If you put a puck clutch in there will split that input shaft in half.
That 1600cc must have 1200 horses to break a stock trans.
Burnouts, huh? |
modok Samba Member
Posted: Sun Jun 14, 2020 2:26 pm Post subject: Re: Stock transmission paired with big motor |
Drag the clutch a little bit, to take all the slack out if the drive train, before releasing it all the way.
If you "need" to keep the car from rolling forward at all...
Hold the car from rolling using the e-brake.
Release the clutch and e-brake, and mash the go-pedal at the same time.
I made my e-brake work backward, you push the button to lock it.
Unfortunately, it still confuses me now and then. Outsmarted myself apparently. Few more years of training maybe I'll learn.
Would be safer to just have it not lock at all. |
Posted: Sun Jun 14, 2020 3:37 pm Post subject: Re: Stock transmission paired with big motor |
building a 2332 screamer(51mm carb.45x37.5 valves,1 7/8 exhaust) gonna keep the 63 swing arm trans. that came w/vw i'm not gonna dog it, but will wind it out! see what happens, going to put heavy duty thro-out shaft, got a kennedy stage 1 _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
