sprbxr Samba Member
Joined: October 04, 2004 Posts: 108 Location: Sleepy Hollow
Posted: Wed Mar 22, 2017 5:50 pm Post subject: Ball Joint lower Control arms differences |
Are there early and late style lower control arms? Or are all ball joint control arms the same?
Thanks _________________ 1957 Oval Ragtop
1974 Thing
1966 Deluxe
1959 Panel
1967 Vert
1959 Semaphore Ragtop |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1294 Location: Modesto, CA
Posted: Wed Mar 22, 2017 6:07 pm Post subject: Re: Ball Joint lower Control arms differences |
For a Super Beetle? Yes, halfway through 1973, VW redesigned the control arms so the ball joints press into the arms from below. Prior to that, the ball joints were attached to the bottom of the strut itself and passed through the control arm from above.
The early style control arms are forged. The later type are stamped and welded.
H2OSB |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
sprbxr Samba Member
Posted: Thu Mar 23, 2017 2:32 pm Post subject: Re: Ball Joint lower Control arms differences |
This is a standard not a super.
I bought a narrowed beam from a vendor on The Samba. It is a fabricated beam not a modified stock beam. He insists the lower control arm outer bearing diameter is the same on a ball joint beam as a link pin beam. He is incorrect. He said he has used the same beam on his own 66 beetle and his lower control arm bearing diamter is the same as a link pin. He told me I should use link pin bushings instead of ball joint bushins. Basically, what he is telling me isn't going to work. He also said I should have my lower control arms turned on a lathe by a machine shop to be able to use his beam.
Anyway, I am getting the feeling that he has never tried to use one of his fabricated ball joint beams. Admittedly, he said he mostly deals with link pin beams. _________________ 1957 Oval Ragtop
1974 Thing
1966 Deluxe
1959 Panel
1967 Vert
H2OSB Samba Member
Posted: Thu Mar 23, 2017 2:45 pm Post subject: Re: Ball Joint lower Control arms differences |
sprbxr wrote: |
This is a standard not a super. |
Ok. Good luck getting it sorted.
johnL (aka H2OSB)
www.superbeetlesonly.com |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Thu Mar 23, 2017 7:54 pm Post subject: Re: Ball Joint lower Control arms differences |
all ball joint standard bug arms are the same and are interchangable...he's nuts, run away |
Posted: Thu Mar 23, 2017 9:39 pm Post subject: Re: Ball Joint lower Control arms differences |
sprbxr wrote: |
He also said I should have my lower control arms turned on a lathe by a machine shop to be able to use his beam |
This person is a total idiot, I am not a machinist by trade, but I do have a small machine shop in my garage. There are many problems with trying to turn the arm down. First there is no way to grab it with the lathe chuck, it is the wrong shape. You would essentially have to build a turning fixture from about 1-1/2" solid round stock. Then use a mill to shape half the length into the shape of a leaf pack. After that slide it into the arm and use the grub screw to hold it into place. Now the fun part, in order to swing the arm, the lathe would have to be HUGE. The kind we see in black and white on PBS making bombers, and things like that.
To protect the rest of us, you really need to point out who the vendor is, he is worse then EMPI. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
sprbxr Samba Member
Posted: Mon Mar 27, 2017 5:41 am Post subject: Re: Ball Joint lower Control arms differences |
Not Airkewled. _________________ 1957 Oval Ragtop
1974 Thing
1966 Deluxe
1959 Panel
1967 Vert
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
Posted: Mon Mar 27, 2017 9:04 am Post subject: Re: Ball Joint lower Control arms differences |
sprbxr wrote: |
Anyway, I am getting the feeling that he has never tried to use one of his fabricated ball joint beams. Admittedly, he said he mostly deals with link pin beams. |
Ball joint uppers are the same inner and out and the lower inner is the same but the outer is definitely larger and the bushings will not interchange. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
