"Official" Crank Trigger Ignition Information
Page: 1, 2, 3  Next
Dale M.
Dale M. is offline
PostPosted: Wed Mar 22, 2017 6:29 pm    Post subject: "Official" Crank Trigger Ignition Information Reply with quote
Information on crank trigger ignition systems... Not all the best information but a place to start...
Samba thread - Crank trigger pressure port:
https://www.thesamba.com/vw/forum/viewtopic.php?t=714876
https://www.diyautotune.com/support/tech/hardware/crank-trigger/
https://www.diyautotune.com/support/tech/hardware/diypnp/documentation/diypnp-v1-5/ignition-control/
http://www.msextra.com/doc/pdf/html/ms3pro_manual_1.4.1.pdf/ms3pro_manual_1.4.1-98.html
http://downloads.vems.com/documentation/VEMS_V3installandsetupmanual.pdf
https://wiki.autosportlabs.com/MegaJolt_Lite_Jr.
http://speedtalk.com/forum/viewtopic.php?p=21543
http://www.cranecams.com/uploads/instructions/9000-1011a.pdf
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Mar 22, 2017 6:41 pm    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Thanks Dale.
Please, let's keep this technical.
If you want to discuss pros and cons, use one of the many existing topic.
Glenn
Member #1009
#BlueSquare
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Wed Mar 22, 2017 7:55 pm    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
How I mounted the crank trigger wheel and vr.
Whittled out a pulley hub with a step to fit a ford 36-1 missing tooth timing wheel.
Then whittled out a pulley to fit my app.
Assembly, the missing tooth wheel is not pressed on the step in the pic. Has to be degree wheeled into position.
DeathBySnuSnu
PostPosted: Wed Mar 22, 2017 8:00 pm    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
The vr mount.
DeathBySnuSnu
PostPosted: Wed Mar 22, 2017 8:03 pm    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Or......just do it the easy way and call Mario at The Dub Shop and buy a modified pulley, the vr and mount already made up. I think it is added onto a steel empi pulley.
DeathBySnuSnu
PostPosted: Wed Mar 22, 2017 8:10 pm    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
One big thing to remember.....
You can NOT just leave the distributor out.
You MUST pull the drive gear out or make a dummy distributer drive end to put in the hole to keep the gear in place.
If not the gear will thrust up and out of line. The brass worm on the crank will eat up and fill your engine with nice fine brass shavings that dont stick to your magnetic drain plug.
raul arrese
raul arrese is offline
PostPosted: Thu Mar 23, 2017 3:50 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
DeathBySnuSnu wrote:
The vr mount.
Sweet , same alternator I run under my Fan ... and for you Fabricators this G.M. alternator 3 bolts on the case line up exactly with the 3 holes on a Porsche fan housing ..
" Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608
raul arrese
PostPosted: Thu Mar 23, 2017 5:27 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Ok here's 2 examples of trigger mounts I have used , top and bottom depending on what you like or need , Basically a readily available ford taurus magnetic 2 wire crank sensor or you can run a 3 wire hall effect sensor that are cheap and accurate , ford 36 tooth with one missing crank wheel .. Its triggering a M.S- 2 running M.S. Extra software . wasted spark COP coils out of a dodge charger and for drivers you will have to run 4- bip's so you can drive each coil . you can buy these driver boxes now so its easy to do without having to build it ..
raul arrese
PostPosted: Thu Mar 23, 2017 5:28 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
here are the coils mounted
raul arrese
PostPosted: Thu Mar 23, 2017 6:40 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
This is the driver box im using to fire four COP's in waste spark , you will have to run M.S extra firmware
raul arrese
PostPosted: Thu Mar 23, 2017 6:49 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
For you guys who choose to build your own driver . I think either the Bip373 or the VB921 are not available anymore but I don't remember which one ..
The Bosch BIP373 transistor has served in many different Bosch ECUs and ignition modules. They’ve been available to ECU and ignition module manufacturers for some time in wholesale lots, but now we are making these transistors available in retail quantities for the hobbyist market. We’ve done extensive testing on them and found these make a great drop-in replacement for the now-discontinued VB921 IGBT ignition drivers commonly used in MegaSquirt ECUs. Not only do they drop right in, we’ve found they are much harder to destroy if the output or dwell settings are incorrectly configured. In fact we’ve been trying really hard and we haven’t been able to burn one up yet!
Like the VB921, the BIP373 is a transistor in a TO-220 package designed to drive ignition coils. The pinout is exactly the same as a VB921. There is one key difference in building a Megasquirt using BIP373s: The BIP373 is not in an insulated package, so you must use a mica insulator when mounting it on a heat sink. Other than that, it works in any circuit that you can use a VB921 in. When driving a single BIP373 from a processor output, we recommend using a 330 ohm resistor in the wire connected to the base for both MS1/Extra and MS2/Extra applications. When driving two BIP373s from one output for firing coil-on-plug applications in a wasted spark mode, you’ll also use 330 ohm resistors, one resistor per BIP373.
Bosch BIP373s have both output current limiting and thermal shutdown built in. The data sheet puts the typical current limiting at 11.5 amps with a maximum of 16 amps. The thermal shutdown range is between 185 and 210 degrees C with a typical shutdown at 195C. Basically that means the BIP373 will provide a hotter spark that a VB921, and if you configure it wrong and it gets hot, it shuts itself down instead of turning on the pyrotechnics.
raul arrese
PostPosted: Thu Mar 23, 2017 6:52 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Here is an example of using a bosch ignition module
raul arrese
PostPosted: Thu Mar 23, 2017 7:10 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
This is the easy way to set up your 36 tooth wheel on any 4 cylinder , Engine at TDC , crank sensor right on tooth 9 and this puts the missing tooth in the exact place for ease of set up , yes you can put the sensor anywhere that makes it easy for you but then you will have to make the proper settings in your set up ..
Dale M.
Dale M. is offline
PostPosted: Thu Mar 23, 2017 7:51 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Some crank trigger parts...
https://www.cbperformance.com/product-p/2093.htm
https://www.cbperformance.com/product-p/2092.htm
https://www.cbperformance.com/product-p/7073.htm
Lots of technology here... Always hear good thing about Mario..
http://www.thedubshop.net/
http://www.thedubshop.net/crank-trigger
Dale
raul arrese
PostPosted: Thu Mar 23, 2017 7:54 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Dale
Mario is excellent for guys who don't want to do allot of figuring out , he's a ton of help and will get you running quick .. with good products
raul arrese
PostPosted: Thu Mar 23, 2017 10:29 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
this is the mini cam sensor from the Dub shop , its an easy way to go sequential ..
Dale M.
Dale M. is offline
PostPosted: Fri Mar 24, 2017 8:07 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
raul arrese wrote:
modok wrote:
For those that like this "programmable" stuff, consider the
"Daytona Sensors TCS-1"
it is programmable advance curve, it costs 150$
Works with VR sensor or 12volt square wave input signal, so basically anything.
Function like a MSD 8680, 8980, 8981, but programmable
The instructions say it is for triggering CDI boxes, but for those that prefer inductive, you can use it to trigger a TFI module. it could also be used in-line to alter the timing of a distributor WITHOUT locking it. It might also read points, but who would be crazy enough to use POINTS Shocked
You can put it on the sticky Modok
Actually priced a little higher on their site,
http://shop.daytonasensors.net/products/tcs-1-timing-control-system
Installation notes /manual...
http://nebula.wsimg.com/7d1431ada7cf5b57349f745727...oworigin=1
Dale
Eoin
Eoin is offline
PostPosted: Fri Mar 24, 2017 10:05 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
Do you run sequential? It's tempting as a fun thing to do, but I think it's a waste on a camper engine and even more set up. Would be good with some feedback from each cylinder to set up the injectors individually.
1972 Westfalia Camper
1976 BMW R90/6
2013 BMW M135i
Mr. 010
Glenn is offline
PostPosted: Fri Mar 24, 2017 10:08 am    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
This does not eliminate the "slop" in the brass gear, driveshaft and drive dog.
Glenn
Member #1009
#BlueSquare
66brm
66brm is offline
PostPosted: Fri Mar 24, 2017 2:39 pm    Post subject: Re: "Official" Crank Trigger Ignition Information Reply with quote
My understanding is that it only provides the sequence signal, timing is still controlled by crank wheel and sensor and the map programmed in the ecu.
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
Page: 1, 2, 3  Next
