mkbug Samba Member
Joined: October 12, 2004 Posts: 145 Location: Northern California
Posted: Thu Mar 23, 2017 8:01 am Post subject: Vent Window Felt - Source? |
Does anyone have a source for this? WW is out of stock.
The felt channel has the same profile as the large channel, but much thinner. Part #111837433
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Thu Mar 23, 2017 8:34 am Post subject: Re: Vent Window Felt - Source? |
You need one piece or two, I may have an extra in the shop?
Bruce |
mkbug Samba Member
Posted: Thu Mar 23, 2017 8:46 am Post subject: Re: Vent Window Felt - Source? |
MeeferMadness wrote: |
Bruce |
Thanks for the offer. I need enough for both doors. What are they about 12 inch long each? |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Mar 23, 2017 9:10 am Post subject: Re: Vent Window Felt - Source? |
CIP1
WCM
JBUGS
Any of the popular vendors should have it |
mkbug Samba Member
Posted: Thu Mar 23, 2017 9:51 am Post subject: Re: Vent Window Felt - Source? |
txoval wrote: |
CIP1
WCM
JBUGS
I've looked - they have convertible ones. Any difference? |
txoval Samba Member
a57oval Samba Member
Joined: September 28, 2003 Posts: 202 Location: West Seattle, WA
Posted: Sun Mar 26, 2017 5:02 am Post subject: Re: Vent Window Felt - Source? |
Give Restoration Specialties an inquiry. They are on the east coast. I have found lot's of odd bits there. Great online catalogue.
Peter |
mkbug Samba Member
Posted: Mon Mar 27, 2017 10:40 am Post subject: Re: Vent Window Felt - Source? |
Thanks TXOval - I ordered the one from CIP. We'll see if it is correct. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Nov 30, 2017 10:56 am Post subject: Re: Vent Window Felt - Source? |
mkbug wrote: |
I'm curious - what did you receive from CIP? Was it Brazilian with a green stripe on it or something else? How did it fit? |
mkbug Samba Member
Posted: Fri Dec 01, 2017 12:15 pm Post subject: Re: Vent Window Felt - Source? |
ataraxia wrote: |
mkbug wrote: |
I havent installed them yet. The have a red strip on the outside. _________________ I'm Martin
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=667183 |
Posted: Fri Dec 01, 2017 1:42 pm Post subject: Re: Vent Window Felt - Source? |
mkbug wrote: |
ataraxia wrote: |
mkbug wrote: |
I havent installed them yet. The have a red strip on the outside. |
Thanks for the reply...I attempted to install the Brazilian felt trim in my Type 3 and, while it fits the channel, it was too tight on the glass.
I called Wolfsburg West yesterday and they told me that the OE early vent felt will be available in about 4 weeks so I think I'll wait. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Jun 20, 2018 1:25 pm Post subject: Re: Vent Window Felt - Source? |
mkbug wrote: |
ataraxia wrote: |
mkbug wrote: |
So did this turn out to be the right stuff and how did it work? |
mkbug Samba Member
Posted: Wed Jun 20, 2018 4:32 pm Post subject: Re: Vent Window Felt - Source? |
Well it was the right part but it made the window very difficult to roll up and down. So I went a different route.
I went to Home Depot and bought some black low pile indoor/outdoor carpet. I spray glued the carpet into the channel and with a dull knife molded it into the channel. It worked great. The black carpet is fuzzy just like the felt part and the window moves much better (not loose).
One linear foot from a six foot roll. I've got lots left over. Let me know if you want some.
txoval Samba Member
Posted: Wed Jun 20, 2018 5:18 pm Post subject: Re: Vent Window Felt - Source? |
How did you install the divider bar? You should leave it loose and then roll the window up. Once it’s rolled up, tighten the divider.
The tightness probably had more to do with the divider install then the felt.
I learned this lesson the hard way too...when your window is hard to roll up, 99% of the time it’s the location/install of the divider bar |
Posted: Wed Jun 20, 2018 6:43 pm Post subject: Re: Vent Window Felt - Source? |
The felt with the stripe is the correct width but it's too thick so the window doesn't have enough space to roll up/down smoothly. Even installing with the divider loose - there's only so much space for the felt, the glass and the divider bar.
I have tried two different reproductions of the felt - neither worked. I wound up finding NOS quarter window frames with the felt and it's a lot thinner than the Brazilian (red/green stripe) felt.
Wolfsburg West has been out of stock for over six months - not sure when (or if) it'll return to stock but I've been watching/waiting. If I get tired of waiting, I'll either use the Home Depot carpet (I'd found that a while back myself) or swap in the NOS frames I've got. It'd be great if there was more than one source for the stuff that actually works. |
jason Samba Member
Posted: Fri Jul 06, 2018 9:21 pm Post subject: Re: Vent Window Felt - Source? |
I’ve loosened up the tight felts by running a piece of wood up and down the channel, by hand. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Sat Jul 07, 2018 7:14 am Post subject: Re: Vent Window Felt - Source? |
EIS has them in stock. I purchased a set at the VW Classic show last weekend. $10/ea. They have a zred stripe down the side. As for fitament issues, unknown. I haven’t installed them yet _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Sat Jul 07, 2018 7:16 am Post subject: Re: Vent Window Felt - Source? |
RareAir wrote: |
EIS has them in stock. I purchased a set at the VW Classic show last weekend. $10/ea. They have a zred stripe down the side. As for fitament issues, unknown. I haven’t installed them yet |
Everyone has the Brazilian (red stripe) in stock. |
