Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Mar 23, 2017 2:18 pm Post subject: Bad end play? |
I'm checking my end play.
I'm unsure what I need to have tightened down in order me to check the end play. I'm assuming just the case (the Bentley shows checking without cylinders on). I hope it is just the case, because I don't have my heads on. This is bad, right? Anyways, here is a video.
https://youtu.be/oFlLzJJE5JU _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
Maticus Samba Member
Joined: September 02, 2015 Posts: 25 Location: Louisiana
Posted: Thu Mar 23, 2017 2:25 pm Post subject: Re: Bad end play? |
Yeah, if you can hear/feel the endplay, there's too much! The VW guy I work with does endplay in short block form, aka no cylinders and heads. You should only need the case together because the endplay rests on your thrust bearing (the one by the flywheel). You either need more shims, or just thicker shims. I've only built one engine so take my advice with a grain of salt. Surely a VW vet will come along and say I'm wrong if I am. Good luck. _________________ 1969 Rust Bugget AKA "Blitzkrieg" |
anthracitedub Samba Member
Posted: Thu Mar 23, 2017 2:37 pm Post subject: Re: Bad end play? |
I set endplay in short block form, 2 shims, indicate to determine the 3rd shim. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Mar 23, 2017 3:42 pm Post subject: Re: Bad end play? |
Thank you. I "tested" my end play fine then. How does it sound/look to you guys? I'm going with it sounds hideous. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
theDrew Samba Member
Posted: Thu Mar 23, 2017 4:43 pm Post subject: Re: Bad end play? |
measure it and then you can figure out what to do next -- but it seems like excessive play.
if you don't measure it, then were all just speculating and guessing _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Posted: Thu Mar 23, 2017 5:54 pm Post subject: Re: Bad end play? |
theDrew wrote: |
if you don't measure it, then were all just speculating and guessing |
Because I don't have a micrometer. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
modok Samba Member
Posted: Thu Mar 23, 2017 5:56 pm Post subject: Re: Bad end play? |
No dial indicator?
You can buy a cheap one for 25$ |
Posted: Thu Mar 23, 2017 6:37 pm Post subject: Re: Bad end play? |
modok wrote: |
No dial indicator?
Yeah... I just don't have one now, and I'm deciding to break into it anyways. I might get one later though. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
