I need a Syncro Diesel/ Electrical Guru
Page: Previous  1, 2
?Waldo?
?Waldo? is offline
PostPosted: Fri Jun 16, 2017 11:37 am    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
I made a typo before. The number of bracket mounting bolts on the AAZ is three, not two. They are under the pump and go through the bracket to mount it to the block.
Team WorldTour
Team WorldTour is offline
PostPosted: Fri Jun 16, 2017 1:05 pm    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
Cool. I'll check it out in the morning.
Thanks again, Mate.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
vandoka
vandoka is offline
PostPosted: Tue Oct 24, 2017 7:23 pm    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
I just picked up a doka with the 1.6 turbo diesel and am having similar symptoms as Team World Tour. After driving for only 10 minutes on a mild day the fan runs for 20-30 minutes after the engine is off. Wondering if the relay on top of the fan (part #27 in the posted diagram) is the best place to start troubleshooting this issue?
ZsZ
ZsZ is offline
PostPosted: Wed Oct 25, 2017 12:36 am    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
As told, both the aux. coolant pump and fan are switched on by a thermoswitch marked F95 on the circuit diagram. It should be present at the coolant flange at the end of the cylinder head.
It switches on at 102C coolant temp in 2wd I think its the same switch on syncro.
There are two versions:
early for enginees with metal flange. Partnr: 251 919 521
https://www.volkswagen-classic-parts.de/temperaturschalter-d5a811.html
and late for engines with plastic flange. Partnr: 251 919 369 F
https://www.tk-carparts.de/article/3795/Temperaturschalter_20_mm_97_104_Grad_2_polig.html
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
Team WorldTour
PostPosted: Wed Oct 25, 2017 1:07 am    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
vandoka wrote:
Team World Tour
Team WorldTour. It's not a typo.
Just an FYI. Cool
Click to view image
vandoka
vandoka is offline
PostPosted: Wed Nov 01, 2017 7:23 pm    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
ZsZ,
Thanks for the helpful part numbers and links to diagrams on the Classic Parts sites. After following the diagrams I removed what I thought to be the temp. sensor but of course it looks unlike the two parts you have shown....
although it seemed to fit with the diagram location. Can you identify this and possibly point me in the right direction Wink
ZsZ
ZsZ is offline
PostPosted: Thu Nov 02, 2017 12:18 am    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
vandoka wrote:
ZsZ,
Looks like a manifold heater switch switches on at 65C
EDIT: this switch is a normally open switch so it opens at 65C while the others are closing at 100/102/104C
035 919 369
035 919 369 C
https://www.brickwerks.co.uk/manifold-heating-switch-t3-1-9-wbx-early-premium.html
Altough there is a similar older style 100C switch with one connector so I am not sure if early syncros had switches with two connectors.
251 919 521
https://www.brickwerks.co.uk/coolant-temp-switch-t3-td-aux-water-pump-early-100-c.html
Maybe PO could get only the manifold heater switch. Who knows.
Are there any letters or nrs stamped onto your switch?
EDIT nr 2:
Ive found several similar looking switches used in rabbit/cabby etc
035919369D (25°C)
027919369B (45°C)
http://www.cabby-info.com/electrical.htm
Zoltan
ZsZ
ZsZ is offline
PostPosted: Thu Nov 02, 2017 1:40 am    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
found this article:
http://www.charlie-o.de/index.php?article_id=322
which shows that thermoswitch present in the flange which is at the side of the engine under the injectors
so I got confused where it should be present, Mine was in the flange at the end of the block the online ETKA shows the switch in the side flange
the color of the wire that switches the fan and the aux pump (through the relay in the relay box) is brown with red tracer
the temp sender for glow plug has a blue wire with white tracer and the temp gauge sender has yellow wire with red tracer
EDIT (again Smile ) further ETKA investigation tells that the manifold heater switch is present in JX at the end of the head when additional WEBASTO DBW46 heater is present Smile
Zoltan
vandoka
vandoka is offline
PostPosted: Fri Nov 03, 2017 10:00 am    Post subject: Re: I need a Syncro Diesel/ Electrical Guru Reply with quote
ZsZ thanks for all the great info. At this point I tested the thermo sensor and it is functioning properly. And you were right that my truck does have the webasto heater (which does not really work right now) But after driving the truck this morning for 30 minutes I got the blower fan to start. With the truck turned off I removed the relay shown in your linked document and the blower continued to run. So I believe the issue is not with the thermo sensor or relay but somewhere else...?
Page: Previous  1, 2
Page 2 of 2
