plimthing Samba Member
Joined: March 29, 2014 Posts: 278 Location: West Midlands UK
Posted: Sat Mar 25, 2017 11:49 am Post subject: Help! What is this? |
So first, apologies as I cant upload a photo just yet.
I'm in the middle of my 72 crossover project and ive discovered something that I'm not too sure about. Its in the braking system and lives on the right hand side ( underneath van, obviously), further back than the master cylinder. Hydraulically its between master cylinder and rear brakes. Its help to chasis rail by two bolts. As for the number of hydraulic connections, I'm unsure as i have empty ports on the thing.
I have a part number that's not recognised by VW heritage, JustKampers over here in UK- 211 612 501 (?) that's the best i can make it out to be, but I'm 99% sure its correct,
I'm thinking somekind of bias valve to give more braking pressure to front brakes?
Also, if anyone knows what it is, can anyone help with the routing of pipes please. As i said i have missing fittings and crimped of pipes on mine.7
Thanks For Help
Tony |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sat Mar 25, 2017 12:06 pm Post subject: Re: Help! What is this? |
It's the brake pressure regulator, which reduces pressure to the rear brakes, and does so to a greater extent
when the vehicle is being braked hard. It's supposedly intended to keep the rear wheels from locking up and
causing "directional instability". Only used on vehicles with front disk brakes.
There were two versions, and the part no. you give is for the earlier one. Line from the M/C connects to
the rear port, and line to the rear brakes connects to the front port. There was a Residual Pressure Valve
on the front (I think) port, and if it's missing you'll have to find one or an adapter, because the brake line
union nut won't fit directly into the Pressure Regulator.
Your Bentley manual has some info on these items. _________________ '67 bug: seized by the authorities
Abscate Samba Member
Posted: Sat Mar 25, 2017 1:11 pm Post subject: Re: Help! What is this? |
Treat those carefully as they arent available anymore, TTBOMK _________________ .ssS! |
Posted: Sat Mar 25, 2017 1:33 pm Post subject: Re: Help! What is this? |
Thanks for info, I'm going to presume it still works and refit it. The valve at the front is missing, so I'm not sure what I'm going to do there.
Would it be rude to remove it completely? Can you buy the valve that's missing anywhere. I've got no info on it from vendors I use in UK.
Tony |
Posted: Sat Mar 25, 2017 3:57 pm Post subject: Re: Help! What is this? |
The r.p.v. would probably only be available used. VW had them on most master cylinders of the era, but
discontinued their use in the early-to-mid-seventies. Perhaps they were used on other European car makes of the period.
Here's a topic that has nice photo's of what you'd be looking for:
https://www.thesamba.com/vw/forum/viewtopic.php?t=476304
I don't think a functional r.p.v. is actually necessary, but you'll need at least the shell or a similar-threaded adapter.
VW of America (I think it was) came out with a service bulletin regarding wimpy bus rear brakes, and a part of one of the procedures
they outlined was to gut the r.p.v. (as the thread above discusses). I followed that procedure, and ran my '71 bus with
no r.p.v. for many years, and it didn't seem to affect anything one way or another. _________________ '67 bug: seized by the authorities
Posted: Sun Mar 26, 2017 1:04 am Post subject: Re: Help! What is this? |
thanks for all the usefull info... i think I'm going to ditch the R.P.V and get the regulator fitted with an adaptor to accept brake pipe fittings.
onwards and upwards! |
mainstreetprod Samba Member
Joined: March 09, 2017 Posts: 313 Location: Tennessee
Posted: Sun Mar 26, 2017 6:32 am Post subject: Re: Help! What is this? |
On that note- I'm new to VW buses and wondered what percentage of the braking is done by front/rear brakes on a bus? I know on any car with the engine up front, it mostly done by the front brakes and if your rears go out you can hardly tell. . How does rear engine configuration change the equation? |
Posted: Sun Mar 26, 2017 11:39 am Post subject: Re: Help! What is this? |
Just looked at my regulator, it has a fitting already in the end connection, not sure if its an integral valve or just an adaptor. I'm going to leave it in place flush it through with fluid (fwds and back) and go for it! |
