epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Sun Mar 26, 2017 1:54 am Post subject: DIY home fabricated parts: photo gallery |
If such a thread exists I apologize (please delete);
But for inspirational purposes for those of us who might aspire to fabricating our own spare parts as opposed to purchasing used or aftermarket parts, please post your photos of any parts you have "built yourself".
Thanks! _________________ www.edwardpowell.com |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Sun Mar 26, 2017 8:41 am Post subject: Re: DIY home fabricated parts: photo gallery |
Aluminum Step Protector
https://www.thesamba.com/vw/forum/viewtopic.php?t=546911
_________________ '90 Syncro Westy w/GW2.5L
Posted: Sun Mar 26, 2017 9:46 am Post subject: Re: DIY home fabricated parts: photo gallery |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Yellow Rabbit Samba Member
Posted: Sun Mar 26, 2017 10:55 am Post subject: Re: DIY home fabricated parts: photo gallery |
I made arm rest pivot covers.
Paulbeard Samba Member
Posted: Sun Mar 26, 2017 11:00 am Post subject: Re: DIY home fabricated parts: photo gallery |
Fresh from the laser cutter:
replacement for flue vent to accommodate a solar power connection:
Combined galley vent and USB/12V power:
My own take on a hatch lock:
_________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1645 Location: Budapest Hungary, Europe
Posted: Sun Mar 26, 2017 11:42 am Post subject: Re: DIY home fabricated parts: photo gallery |
replacement hose connector for 4 way coolant hose on diesel
replaced to a new hose since, but kept the connector for emergency repairs _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
Posted: Sun Mar 26, 2017 12:04 pm Post subject: Re: DIY home fabricated parts: photo gallery |
Funky stuff! _________________ www.edwardpowell.com |
ARMc Samba Member
Joined: February 10, 2012 Posts: 116 Location: Wisconsin
Posted: Sun Mar 26, 2017 5:38 pm Post subject: Re: DIY home fabricated parts: photo gallery |
This thread is a GREAT idea, I find myself making stuff often. Like yesterday I needed a slide hammer to replace the water pump on my not yet in the van Zetec. I was about to buy one from harbor freight, but a little voice in my head said, ah you can make that from scrap in an hour. It's not pretty, but it served its purpose and was a lot more fun to make than to buy. Plus free.
crappy diy slide hammer. by Andrew:, on Flickr |
Posted: Sun Mar 26, 2017 6:52 pm Post subject: Re: DIY home fabricated parts: photo gallery |
https://www.thesamba.com/vw/forum/viewtopic.php?t=664047 rates a mention. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
buildyourown Samba Member
Posted: Sun Mar 26, 2017 7:15 pm Post subject: Re: DIY home fabricated parts: photo gallery |
ARMc wrote: |
I needed a slide hammer to replace the water pump on my not yet in the van Zetec. |
Why do you need a slide hammer to do the waterpump? I've done mine twice and didnt need anything fancy.
Pro tip. Buy a OEM Motorcraft pump. Unless you like doing it every year... |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Mar 26, 2017 7:44 pm Post subject: Re: DIY home fabricated parts: photo gallery |
OK...I'll play...
DIY pilot bearing puller - my work, but not my idea (grind stove bolt head to oval shape,
slip sideways under lip of pilot bearing, use hammer in wire loop as "slide" hammer):
DIY flywheel lock (~12" swing set -or any- chain):
DIY hatch latch extension (6" bolt & nut, plus 30 seconds with a hammer):
DIY replacement temp sender "boot" (regular & liqid elec tape, 3 layers each):
Nothing rocket science here, just I'm cheap & live about an hour from any decent tool store.
FWIW, all this stuff worked & still working...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Mon Mar 27, 2017 3:09 am Post subject: Re: DIY home fabricated parts: photo gallery |
I installed a RMW aluminum expansion tank on my syncro last year and wanted to make an adapter for the "Libby Bong " that did not leak to badly while bleeding the coolant system, this adapter works pretty well.
Another annoying problem I had was the syncro oil fill tube, most of us know how these tubes loosen at the crimp, probably from vibration and start to leak so I thought I would try some heat shrink tube
and after several years it is working fine.
one piece is long enough to cut in half and place one over the other, it is a very strong repair.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Zeitgeist 13 Samba Member
Posted: Mon Mar 27, 2017 7:45 am Post subject: Re: DIY home fabricated parts: photo gallery |
I'm currently in the planning stages for a DIY driver side rear tire carrier for stock fiberglass bumpers. Does anyone know of other similar examples? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Mon Mar 27, 2017 11:23 am Post subject: Re: DIY home fabricated parts: photo gallery |
Sorry, no parts to share but a few DIY tools ...
Brake Spoon
I made this brake spoon from an old paint can opener, to adjust the ’star ratchet’ wheel on Vanagon rear brakes. Just bend it up as shown.
To use the tool, simply grasp the handle in the palm of your hand and reach in behind the rear wheel. Insert the tip of the tool in the access hole in the brake backing plate and find the teeth on the ratchet ‘star’ wheel. Pressing firmly, use the tool to dial the star wheel up or down as needed.
With practice (ask me how I know), you can pull over and easily make this adjustment within seconds, then hit the road for further brake testing until you get it right. Oh, what an enjoyable way to spend one’s first day of cross-country vacation after a last-minute brake job …
BONUS: many such paint can openers feature an integrated bottle opener in the handle, so you can enjoy an adult beverage while admiring your work.
CV joint removal tool
Really just a simple drift, used for driving a stubborn axle out of a CV joint. Made of a (one-inch?) hardwood dowel, I added a cheap hose clamp on the top end to prevent splintering. Dangle the axle assembly vertically in a loose bench vise, remove the axle’s retaining clip, and use a 2-pound hammer on the drift to pound the end of the axle out the bottom of the joint.
CV Joint Alignment Tool
It can be difficult to hold a CV axle assembly in place while you install the first bolt.
Get an M8x48 bolt from the hardware store (or just use an old CV bolt) and cut the head off, then cut a slot into the same end of the bolt so you can insert a flat screwdriver. Thread this ‘alignment tool’ into the uppermost hole in the drive flange of the transaxle or wheel hub, then slip the axle’s CV joint over the protruding tool. The axle will hang in position while you install the proper bolts; use a screwdriver to remove the tool, then install the final bolt.
BONUS: The same tool also works in similar fashion for installing Vanagon diesel V-belt pulley sheaves.
Diesel oil pan bolt tool
The two forward most oil pan bolts on a diesel or other inline engine are difficult to reach, and the usual hex drivers with 3/8" drives have shanks too large to fit in the tight space. So, I simply cut up an old Allen key of the correct size and slipped it into a matching slim 1/4"-drive socket. _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Mon Mar 27, 2017 12:19 pm Post subject: Re: DIY home fabricated parts: photo gallery |
Wow, I'm going to use that oil pan tool... some of those bolts are really buggers!
I have also not make many parts. But here is a tool I made for pulling out and installing the Diesel intermediate shaft bearings. Andrew Libby gave the instructions, but I don't have a steel lathe, just a wood one, so I made the thing out of a material called TRESPA. It's a fantastic material I use in my guitar making... fingerboards, bridges, nuts, saddles - etc etc...
ARMc Samba Member
Posted: Sat Jul 08, 2017 4:10 pm Post subject: Re: DIY home fabricated parts: photo gallery |
I like this thread so I'll post this easy brainless fix. Guessing I'm not the first one to come up with this. I broke the magnet off my transaxle drain plug while trying to clean up the threads. I then felt stupid for breaking it. So I looked online for an oem replacement and came up empty handed. Turns out maybe for the better. A stack of neodymium magnets are far more powerful than the original, and with more surface area to collect shavings! I set the magnets in a little RTV, probably won't do much but help keep the stack straight as the broken part of the magnet that remained in the plug wasn't quite flush. Keep em coming! Its great to see what people come up with.
FIxed it. by Andrew:, on Flickr |
RicoS Samba Member
Posted: Sun Jul 09, 2017 7:47 pm Post subject: Re: DIY home fabricated parts: photo gallery |
Here's a Blast from the Past, an Oldie But Goodie
These are two of eight telescoping, adjustable pushrod tubes I spun off about 30 years ago for my first, and perhaps my favorite Vanagon, an 84 Sunroof.
Right after I bought that jewel, it puked a big puddle of oil in the driveway. I found two pushrod tubes nearly rotted away. Welcome to Vanagonland.
Once I found out about such things, I went to the dealer to pick up adjustable pushrod tubes. I figured I'd replace them all because if two were shot, the others would not be far behind. The counter guy quoted me about 90 bucks and I thought, that's not so bad, until he said,". . . a piece." After I (expletive deleted) myself, I went home to regroup.
Remember this was at the end of the 80's. There was no i-net to search, there were no aftermarket Vanagon parts (especially telescoping pushrod tubes) and I could buy a used, low-low-milage 2.1L for six chops.
So what else could I do, I rolled my own.
By the way, as I installed the home-brewed tubes, I found out why a couple had rotted away. Some moron had swapped the engine tins, left for right and when he had trouble getting them to fit up, he cut away a lot of sheetmetal which turned the tins into perfect scoops to suck up any well salted slush the van rolled over.
These were made from what I had on hand: 3/4 and 1/2 rigid, aluminun electrical conduit. The two pieces were bored out and turned to assure ample clearance for the pushrods and to provide a loose, sliding fit between the constituent tubes.
The collars at the top and bottom, which the seals bear against, were aluminum-brazed to the tubes. I used stock seals, top and bottom and a third in the middle which seated in a full chamfer on the mouth of the lower tube.
The springs were selected from whatever the Tru-Value hardware had in their Century Spring display case. Although I didn't have much of a choice of spring constant, my guesstimate proved to be good enough as these tubes sealed perfectly and remained solidly so until the van went to Vanagon heaven.
Richie (near The Burgh) |
jimf909 Samba Member
Posted: Sun Jul 09, 2017 8:53 pm Post subject: Re: DIY home fabricated parts: photo gallery |
This thread is above average. Good solutions posted already.
The best I got is (although I'm not sure if this is what the op had in mind)..,
This muffler heat shield...
This anti-friction pad for the dining room table...
Cuphplder...
_________________ - Jim
Abscate wrote: |
