rarquilla Samba Member
Joined: August 16, 2008 Posts: 90 Location: Nyssa, Oregon
Posted: Sun Mar 26, 2017 7:22 am Post subject: Need some input, my new LB timing can't get to 7.5 btdc. |
I bought a longblock that was professionally built from a reputable builder in California. The motor has been on a rack for about 4 years. I installed it in my VW Thing. I have everything set but the timing won't run at 7.5 btdc. It runs with the vacuum highest around 20. 1600 cc bosch 009. Blue coil. I can get it to run perfect but even full advance is around 45. What am I doing wrong. I even switched distributors. Same thing. Motor runs great! Scat degree pulley. |
74 Thing Samba Member
Posted: Sun Mar 26, 2017 10:59 am Post subject: Re: Need some input, my new LB timing can't get to 7.5 btdc. |
You probably have a vacuum leak. What carb/intake manifold are you running? You want no more then abiout 32 degrees max advance with an 009. At 40+ you will fry that engine. |
Posted: Mon Mar 27, 2017 8:03 pm Post subject: Re: Need some input, my new LB timing can't get to 7.5 btdc. |
I am running a Pict 34 German Soles. I have checked for vacuum leaks and found none. Took the motor on a 100 mile drive and it's running and cooling great. No issues. Put a different timing light on it and it's the same. Full advance is closer to 45-48. I don't get it. |
