chrisjbrown147147 Samba Member
Posted: Sun Mar 26, 2017 8:49 am Post subject: Gas In my Oil Tank |
Hello all, New to this thread so please bear with me, please.
I have been passed down a Trike that my Late uncle built from Scratch 15 or so Years Ago. The Engine model number is: AD 5545 and the carb is a PICT-3.
I was driving the other day in third gear, when my engine started to sputter out, finally dying. I pulled over, started the engine again and it started (idling very bad), But when I would try and put it in gear or press on the gas peddle it would shut off. I managed to make it back home and have been looking all around but want to make my own post to make sure i am going in the right direction. But it turns over, Does not start though.
The Trike was sitting for around 6 years prior to me firing it up again. (When it was running again I had only been driving it around for 20-30 minutes at a time)
After hours of searching online I found one post that said check my oil tank for gas, and sure enough my tank smells very strong of gas. I haven't tried to start since finding gas in the oil tank, but before i knew i had gas in my oil, I tried cranking it and it Did Turn but Didn't Start. From what I looked up, It could either be my fuel pump or stuck float needle?(best case)
if you can list exact parts numbers/links would be awesome
Thank you for taking your time to read.
Below Are picts of the Trike, Engine, The oil tank, And inside the carb.
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Sun Mar 26, 2017 9:00 am Post subject: Re: Gas In my Oil Tank |
There is no "oil tank", there is the oil in the crank case.
Your fuel pump is likely leaking into the crankcase. Pull the fuel pump and check to see if it is wet from fuel underneath.
A leaking carburetor/stuck float won't leak fuel into the crankcase at all. It will just cause a rich fuel mixture.
If fuel did manage to make it's way into the crankcase from the carb, you have bigger issues to deal with and those should be pretty obvious. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Keith Samba Member
Posted: Sun Mar 26, 2017 9:12 am Post subject: Re: Gas In my Oil Tank |
Your motor still has a generator. You need a generator fuel pump.
Someone added that alternator from another car on the left hand side which doesn't belong on the motor and if it was added, then the generator likely doesn't work which you can see by the fact that the wires are cut on it. _________________ Formerly known in the forums as "OVALTEEN"
Posted: Sun Mar 26, 2017 9:20 am Post subject: Re: Gas In my Oil Tank |
Awesome, if i got a replacement generator fuel pump and installed it it should run like it previously did without me having to wire the generator, correct? (assuming the pump is the only problem). Thanks! |
Keith Samba Member
Posted: Sun Mar 26, 2017 9:22 am Post subject: Re: Gas In my Oil Tank |
Yup. It's for a generator. _________________ Formerly known in the forums as "OVALTEEN"
Posted: Sun Mar 26, 2017 9:36 am Post subject: Re: Gas In my Oil Tank |
Awesome, I am ordering the part today and will get back when i replace it. Thanks for all your help, i really appreciate it. |
Posted: Sun Mar 26, 2017 1:29 pm Post subject: Re: Gas In my Oil Tank |
Went to Order the part and there are so many variations, I don't want to order the wronf part. Can somone please link me to a Cheap one That would work on my engine? Thanks. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Sun Mar 26, 2017 2:49 pm Post subject: Re: Gas In my Oil Tank |
Hey! First off, don't be looking for "cheap." Secondly, find the Buyer/Seller feedback forum and read up on PartsGeek before you order ANYTHING. And Autohaus is a fine retailer, order from them. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Posted: Sun Mar 26, 2017 3:00 pm Post subject: Re: Gas In my Oil Tank |
Thanks for the reply, I'll definitely keep that in mind when buying it. I just posted to the buyer/seller forum. Thanks again. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Mar 26, 2017 5:19 pm Post subject: Re: Gas In my Oil Tank |
Couple things quick. You can use either the generator or alternator style pump. If you get a real Brosol, it will be fine BUT the pushrod for the fuel pump is different for a generator and alternator style. 2 different lengths and they are NOT interchangable. Make sure you pack some grease in the underside (you'll see where) before you install it.
Guessing the generator or voltage regulator died, so someone stuck on an alternator. as long as the belt doesnt slip, what the hell - go with it. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Mar 26, 2017 6:27 pm Post subject: Re: Gas In my Oil Tank |
The Push rod is 100mm Long. Would I get an Alternator fuel pump?
Another Thing; The insulator broke off and is stuck seated in the block. I am having terrible luck so far. Pictures attached below. thanks! |
Posted: Mon Mar 27, 2017 5:45 am Post subject: Re: Gas In my Oil Tank |
108mm = generator pump
100mm = alternator pump
The flange snapping is not unusual - I use a lag bolts with the end rounded off and screw it in and them pry it up. Don't bitch up the sealing surface on th engine case when you are doing this. Sometimes it works and sometimes the plastic breaks. Not a big deal. You'll find the pieces when you do oil changes.
Would STRONGLY suggest measuring the fuel pressure after you install the pump. You want it to be a little under 3 lbs if you can get it there. You can adjust pressure some by adding gaskets. Order some extras or you can make your own. The top one is pretty easy to make though.
Last thing - dont use RTV. Get yourself a little bottle of Permatex Aviation gasket sealer. You will use this for other things as well.
One last thing - so you don't always have to wait for an answer, learn how to use the search function. You will find the answer pretty fast and learn other stuff as well. For example - if you searched for fuel pump pushrod length, you would probably find an answer in a couple minutes. I use it a lot. _________________ D-Dubya Manx clone - 63 Short pan,1914.
bluebus86 Banned
Posted: Mon Mar 27, 2017 8:10 am Post subject: Re: Gas In my Oil Tank |
the carb inside appears very dirty, could use a clean up probably. could be the float valve is stuck open or the pump. the original generator must still spin via the belt, as the engine cooling fan is spun by it. you could install a 12 volt alternator in its place nd thus remove the extra one you now have. a VW bug 12 alternator should fit, although you will also need to replace the stand it rests on. make sure you fan inlet on front side of the fan house has a wire screen over it, these are sold aftermarket (dune buggy guys use them a lot) as with the open engine bay you have wont keep leafs and such out, and leaves when sucked in dont amke it out, they build up on top the cooling fins and cause over heating, so make sure the inlet has a screen to stop junk from getting sucked in.
cool ride you have, get the motor sorted out and have fun this summer!
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
