cecil Samba Member
Joined: February 23, 2005 Posts: 461 Location: Stockton, CA
Posted: Sun Mar 26, 2017 12:32 pm Post subject: Double Din Stereo |
Anyone ever install a double din in the package tray? Seems the de-froster duct would need to be removed as the box/case is the same height as the front plate ( no Problem ). Any other glitches? _________________ I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
I have this wierd desease called "must tear everything up and put it back together when there's nothing wrong with it...Itus." |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Mon Mar 27, 2017 5:22 am Post subject: Re: Double Din Stereo |
Cecil-
I would be hesitant to remove the defroster duct; it does serve a useful purpose.
What is your goal? Are you looking for integrated phone and nav?
Possibly there is a unit with a detachable screen where the chassis could be mounted remotely. That would solve the mounting depth problem.
I did that with my Retrosound radio.
Another possibility would be to select a radio with Apple CarPlay (or Android equivalent) so a small tablet (or your phone) could be used for controlling the radio/phone/nav functions.
I use a "Ram" mount for my iPhone which provides music, phone and nav through my iPhone compatible radio and the car speakers.
In the Thing, I have found that a noise cancelling "lapel mic" is necessary for acceptable phone conversations because the noise level in a Thing (top up or down) is too much for a dash mounted mic.
Hope that helps, Mondshine |
cecil Samba Member
Posted: Mon Mar 27, 2017 7:58 am Post subject: Re: Double Din Stereo |
Thanks Gary.
This helps. _________________ I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
oasis Samba Member
Posted: Wed Mar 29, 2017 11:16 am Post subject: Re: Double Din Stereo |
There are also single-DIN units where the screen pops out and folds upward to be viewed. That could go in-dash as many have done it or under the dash using an aftermarket box.
The under the dash unit would have to be fairly flush so it could effectively open properly. That's what I had thought about doing near the center. My ash tray would have either been deleted or moved to the right. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
