driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Sun Mar 26, 2017 4:38 pm Post subject: throttle cable won't budge after trying to remove it |
My throttle cable was acting up and sticking alot so i decided to replace it with a new one. As I was pulling the cable out from the front( it was quite stiff to pull any), it pulled out prob. 1-2 ft, then it just stopped completely. Now i can't get it to move another inch Any advice on what could be stopping it? any way to free it up? or what should I do now? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun Mar 26, 2017 4:54 pm Post subject: Re: throttle cable won't budge after trying to remove it |
Its probably hung on the bowden tube. Get under the car and remove the bowden tube and see if you can get the cable out. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Mar 26, 2017 5:00 pm Post subject: Re: throttle cable won't budge after trying to remove it |
can you explain or point me to where i can see how to remove the tube? I got underneath it but the cable looks to be crimped on the metal tube?? maybe im not seeing it clearly |
Posted: Sun Mar 26, 2017 5:17 pm Post subject: Re: throttle cable won't budge after trying to remove it |
n/m I got it off and you were right. it was stuck in middle of tube. I just cut cable once i got tube off and it pulled right out of the metal tube in tunnel. New bowden tube is now on order! |
