Vnyd Dog Samba Member
Posted: Sat Sep 09, 2017 4:56 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
vwjetboat wrote: |
Vnyd Dog wrote: |
Update on my experience. Three issues presented. After install I had noise and then odo stopped working again which was weird cause the bracket was on. Noise was partly from very bottom of bracket near clearanced section for worm drive rubbing the gear. I whittled it down with a knife.
After that noise was better but then today odo stoped rolling. I've concluded that, as was stated in another thread, the issue is my metal gear must be spinning on the rod which requires a different fix from the bracket.
I guess I get to tear it down one more time !
Great part though. |
did you install upside down? |
Doesn't it only fit one way?
_________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
vwjetboat Samba Member
Posted: Sat Sep 09, 2017 5:04 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
weird.. yep thats the right way.. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Sep 09, 2017 5:27 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
Vnyd Dog wrote: |
I've concluded that, as was stated in another thread, the issue is my metal gear must be spinning on the rod |
Which is what I've mentioned and was told to me in the 80's when Mercedes had this issue. This 3D printed bracket does nothing to prevent the gear from spinning. If the gear is pressed on with enough pressure, it will keep the shaft from coming out and the odometer to work.
This bracket does not fix the problem and only benefits the seller. |
Posted: Sat Sep 09, 2017 6:33 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
Vnyd Dog if you are not satisfied please let me know . I will refund your money no questions asked..
Thanks
Greg |
Posted: Sun Sep 10, 2017 12:23 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
Hey thanks Greg but nah no refund needed. I didn't know my issue was the "Butcher symptom". The bracket wil help others I think.
In the end, I ended up pulling the rod and roughing it. It was tedious and time-consuming work but I think I got it. After reassembly the needle is steady and my numbers be rollin'. I wouldn't want to do that again!! See other threads or pm me if details needed. Thanks again to Greg for willing to order the printed parts. _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
Posted: Sun Sep 10, 2017 12:33 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
Vnyd Dog wrote: |
In the end, I ended up pulling the rod and roughing it. It was tedious and time-consuming work but I think I got it. After reassembly the needle is steady and my numbers be rollin'. I wouldn't want to do that again!! See other threads or pm me if details needed. Thanks again to Greg for willing to order the printed parts. |
Yea this is not actually a repair or fix.. if the shaft has not fallen out then putting this on will prevent it.. and if it has fallen out and not to far like I think that is what happen with yours .. it will keep it from falling out again.. once the shaft comes out of the tumblers.. all hell breaks lose.. as ya found out.. |
Paulbeard Samba Member
Posted: Sun Sep 10, 2017 2:50 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
Just installed mine. Took me longer than it should have. I added a tiny dab of glue to hold the nuts captive. That complicated things for a few minutes when it grabbed one of the bolts and I had to do some corrective surgery to get the nut and bolt to thread. Maybe a slightly smaller hole would allow the nuts to be press fit and stay without glue.
But it went in easily enough, once I worked out the orientation of the parts. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Tue Sep 19, 2017 12:50 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
Butcher wrote: |
Vnyd Dog wrote: |
Actually this is no benefit to me what so ever.. I am still $75 in hole and if I sell everyone I might make 30 -40 bucks total.. by the time you add in cost of envelopes hardware and my time.. I am not really making anything actually.. Hell I do not even own a vw.. I inquired about people that might be interested.. there was enough interest in having them made.. so I did.. if you put this on before you speedo takes a crap.. it will keep it from taking a crap because it wont let the shaft and gear come out.. this is a fact.. and if it did come out this will keep it from happening again.. |
macjack Samba Member
Joined: February 26, 2004 Posts: 357 Location: Colorado
Posted: Fri Sep 29, 2017 9:08 am Post subject: Re: 3D Printed Odometer Fix - Photos |
Yea, three cheers for vwjetboat for offering this fix in a cool custom made kind of way. Anyone trying to fix their odometer can look at all the threads about the custom superglue, screw, and platic attempts that people have made to attempt the same thing that this accomplishes elegantly. Too bad when someone makes a very affordable product available for purchase and then gets blamed for mechanical failures beyond the scope of the repair, then accused of profiteering $13 at a time. While getting pummeled by a hurricane. Sheesh.
I have placed my order. _________________ 87 TDI Syncro Westy
81 Westy (sold)
80 Rabbit Wolfsburg (rolled)
Bike as primary transportation |
flyboyaviator Samba Member
Joined: November 29, 2009 Posts: 154 Location: South Florida
Posted: Fri Sep 29, 2017 10:20 am Post subject: Re: 3D Printed Odometer Fix - Photos |
VWjetboat, can't make everybody happy most of the time. If you have one left I'll buy it, please let me know, your effort is much appreciated. |
Posted: Mon Oct 02, 2017 12:06 am Post subject: Re: 3D Printed Odometer Fix - Photos |
flyboyaviator wrote: |
I pmed you.. I Will be shipping out the 1 order I have .. I have one left with hardware.. and 10 without hardware.. How many can I put you down for ? heheh |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Oct 02, 2017 5:38 am Post subject: Re: 3D Printed Odometer Fix - Photos |
Well, I know I could use at least one. I PM'd about 2, but after 5 days of no answer, I withdrew my query from my outbox. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Mon Oct 02, 2017 6:15 am Post subject: Re: 3D Printed Odometer Fix - Photos |
gears wrote: |
Well, I know I could use at least one. I PM'd about 2, but after 5 days of no answer, I withdrew my query from my outbox. |
That is weird as i have notifications on for everything..
[email protected] is paypal |
gears Samba Member
Posted: Mon Oct 02, 2017 6:28 am Post subject: Re: 3D Printed Odometer Fix - Photos |
No worries .. I e-mailed instead of PMing this time. Thanks for making this doodad available to us .. it's a cool solution to a common problem. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Mon Oct 02, 2017 6:37 am Post subject: Re: 3D Printed Odometer Fix - Photos |
gears wrote: |
No worries .. I e-mailed instead of PMing this time. Thanks for making this doodad available to us .. it's a cool solution to a common problem. |
thanks.. if you search my threads I started you will see what is going on with jet boat.. its on hold for a bit till i can get place cleaned up outside .. hurricans suck.. |
Posted: Thu Nov 23, 2017 7:59 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
removed my cluster to install this fix, plus reconnect something loose causing my guage lights to not work. Quickly saw that the main large white plug was loose, so that was the cause of my guage lights. Then took off the face of the speedo, which isn't really necessary, but does make for a little better picture to see where the clamps go:
Put it on the cluster, in the process I had to re-orient the other side of the pin to go into the right place in the casing, then spun the gears by hand a bit to see the trip odometer and main odometer scroll, installed it and watched in wonder as the numbers rolled over while I drove. My odometer works now! My van has "gone to the moon" in miles, but didn't register the last 8k or so. Working my way all the way to 238900 mi, then work on bringing it back to earth (distance from earth to moon is 238900mi).
Thanks, vwjetboat, for sharing this effective and affordable fix. The parts really fit where they are supposed to.
Happy Thanksgiving! _________________ 87 TDI Syncro Westy
81 Westy (sold)
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6618 Location: Houston, Texas
Posted: Thu Nov 23, 2017 9:58 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
So your vehicle hits 200,000k miles and the odometer's parts come popping out? _________________ www.vwnos.com [email protected]
Posted: Thu Nov 23, 2017 11:32 pm Post subject: Re: 3D Printed Odometer Fix - Photos |
kawfee wrote: |
So your vehicle hits 200,000k miles and the odometer's parts come popping out? |
If odometer parts were the only ones that came popping out at 200k on these vans, I'd be a richer man. _________________ 87 TDI Syncro Westy
81 Westy (sold)
heimlich VWNOS.com
Posted: Fri Nov 24, 2017 12:29 am Post subject: Re: 3D Printed Odometer Fix - Photos |
macjack wrote: |
kawfee wrote: |
If odometer parts were the only ones that came popping out at 200k on these vans, I'd be a richer man. |
I hear you on that. _________________ www.vwnos.com [email protected]
Posted: Fri Nov 24, 2017 7:36 am Post subject: Re: 3D Printed Odometer Fix - Photos |
Glad you got your speedo fixed... good job |
