splitjunkie Samba Member
Posted: Thu Oct 28, 2021 4:54 am Post subject: Re: '47 Beetle resurrection |
Not a great picture but every bit helps.
_________________ Chris
WrennMetallWerks Samba Member
Joined: December 06, 2007 Posts: 2650 Location: Rescue ca
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Tue Nov 09, 2021 9:14 am Post subject: Re: '47 Beetle resurrection |
I expect at this time of early post-war production they used whatever they could get. kamax were back in business in '45.
have you seen this thread?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Wed Nov 10, 2021 6:50 am Post subject: Re: '47 Beetle resurrection |
WrennMetallWerks wrote: |
Hey Folks.
So I started digging up Kamax bolts for stuff like spring plates, backing plates , front end and other stuff.
While I was doing it I had the realization that I don’t actually know that the 47 used Kamax in these areas.
Do any of you fine folks know what was what back then.
Thanks in advance,
Jason. |
From memory... The '47 I did had some Kamax, but not much. I think the majority were Rasche and some Dorn. _________________ David S |
Posted: Wed Nov 10, 2021 1:15 pm Post subject: Re: '47 Beetle resurrection |
DSweinhagen wrote: |
Hey Folks.
Thanks in advance,
Jason. |
From memory... The '47 I did had some Kamax, but not much. I think the majority were Rasche and some Dorn. |
I would suspect that all three were suppliers at the same time and no two cars will have the exact same combination.
Fasteners would have been purchased in bulk and distributed throughout the factory with zero consideration for who made them. They would have come in boxes, barrels or crates.
If a bin was empty it would get filled with whatever they had in bulk. Depending on how they were distributed, there would be different patterns on what would end up on a car. If they ran out of one container while filling a bin, they would get some from the next. It could be the same supplier or one of the other two.
You could have bins will all Kamaz, some with all Rasche and some with all Dorn but you could just as easily have bins with all three.
If one of these companies was the primary supplier and supplied them in larger numbers than the others, then you will see them more often, but we don't know that information so as long as a bolt is one of the three and has the correct markings, I wouldn't sweat it too much. _________________ Chris
SplitPersonality Samba Member
Joined: September 26, 2004 Posts: 630 Location: Norway
Posted: Thu Nov 11, 2021 1:09 am Post subject: Re: '47 Beetle resurrection |
Love your attention to detail Jason!
A note on the hardware: The 3 bolts that hold the rear axle to the spring plates.... These are "important" in terms of quality - and - they need to be fine threaded (as original of course).
We found it impossible to find good OG ones (in terms of non-wear-quality you would trust) and ended up doing this:
Bought a modern day hex bolt, smoothened out the head completely on a lathe and black-coated them.
"A smooth head is better than a modern day marked head" - as we say in the business...haha. |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Fri Jan 13, 2023 7:34 am Post subject: Re: '47 Beetle resurrection |
Beautiful! No other word for it. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
Posted: Fri Jan 13, 2023 7:39 am Post subject: Re: '47 Beetle resurrection |
oOoh green! nice!
