driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Mon Mar 27, 2017 6:29 pm Post subject: egr filter kinked, cause vacuum leak? |
I'm hunting down an issue with my engine. the engine won't idle without having the idle set high like 1500 rpm. I noticed the egr filter tube that connects to the exhaust has been kinked in a way it broke the end off it. The egr system is still hooked up to my manifold right under the carb. I was wondering if this could be causing my no idle/ rough idle issue? seems like it would cause a vacuum leak possibly? |
