tencentlife Samba Member
Posted: Fri Feb 21, 2020 11:16 am Post subject: Re: Sanchius and Tuna ride again... |
Hadn't looked at this until now, but yes, for sure, that clean band around the #2 chamber mirroring the piston's squish band is the piston almost kissing the head due to excess rod bearing clearance, or a beaten-out wrist pin bore, but much more likely the former.
After the standard cylinder-cancel test points you to the suspect rod, a loosening rod bearing or wrist pin can easily be physically confirmed. Move the pistons to mid-stroke, put a metal rod as a probe against the crown of the piston in the suspect cylinder, and rock the crankshaft back and forth while feeling the probe; you'll feel the free play in the rod when the piston doesn't move immediately when the crank movement changes direction. You'll be surprised how well you can feel even very small amounts of free play this way.
This can even be done on complete engines still in the car with the head still on, just probe thru the spark plug hole.
The test is optimal at mid-stroke because there's the greatest amount of piston movement per degree of crank rotation there, but if you can't reach the crown thru the plug hole at mid-stroke, just move that piston higher until you can.
(And don't use pencils or wooden implements as probes inside the engine, folks. I've seen people do that and they find out how easily a piece of wood will break, and then they can't get it out because, surprise!, wood isn't magnetic!) _________________ Shop for unique Vanagon accessories at the Vanistan shop:
sanchius Samba Member
Posted: Fri Feb 21, 2020 8:42 am Post subject: Re: Sanchius and Tuna ride again... |
I finally made some time to extract the engine to start the teardown to see if the WBX is rebuildable or if there's a Subi in my future.
rbambrick astutely noted that the lack of carbon buildup in the #2 head surface in the pic above indicates that the piston was kissing the head there, pointing to a stretched rod bolt. However, I would have expected to get a low oil pressure buzzer. Strange.
Dropping the WBX solo with a floor jack and the HF engine support bar was safe, uneventful, and took about 3 hours working slowly. All the anti-seize I applied everywhere the last time I had it out really payed off.
I was about to pull the trigger on a new engine stand when one showed up locally for $10 the day before I needed it. I always love a bargain. With no ceiling hardpoint or engine crane, it took some ingenuity to get the engine up on the stand solo. But I know better than to try to deadlift something like that.
I've never cracked a WBX case before, so this will be fun.
Fortunately the weather is very mild, which makes it easy to work on it without having to run garage heaters.
The WBX isn't the only thing in for repair.
Tunes picked up a bad sticker in her front leg on a recent outing that she couldn't stop licking.
So she's stuck in the dreaded cone of shame until the wound heals.
_________________ The Syncro years (2005-16) - The 2WD years (2017-23) - Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going! |
Posted: Sun Feb 02, 2020 7:14 pm Post subject: Re: Sanchius and Tuna ride again... |
Abscate wrote: |
Can y0u ease out #2 con rod with the engine in place and inspect?
Haven’t done a wasser boxer myself. |
I've done a fair number of WBX head gaskets & main seals, but never cracked a WBX case to do a lower end.
This will be educational.
I was hoping that I could get away with a quick, in situ, 1-2 head refresh and reinstall.
The WBXs are so quick to pull and easy to move around once you have them out that removal is the logical next step. _________________ The Syncro years (2005-16) - The 2WD years (2017-23) - Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Abscate Samba Member
Posted: Sun Feb 02, 2020 6:35 pm Post subject: Re: Sanchius and Tuna ride again... |
Haven’t done a wasser boxer myself. _________________ .ssS! |
4Gears4Tires Samba Member
Posted: Sun Feb 02, 2020 5:59 pm Post subject: Re: Sanchius and Tuna ride again... |
I wonder if it's possible to pull the oil drain plug and insert a boroscope to check out if there is anything damaged that is easily visible.
Can you rotate the crank and see if the #2 cylinder does not quite reach TDC? _________________ '87 Syncro
Posted: Sun Feb 02, 2020 5:48 pm Post subject: Re: Sanchius and Tuna ride again... |
I finally had time to dig into the hammering noise this weekend
I removed the new lifters, disassembled and primed them as per 10c and Christopher Schimke's excellent tutorial, and reinstalled them.
I've never had to do this before so this is new territory for me.
Since the lifters were already full of oil when I disassembled them, I wasn't surprised when the hammering sound was still there when I restarted the engine.
Well, maybe it was the something with the 1.25 ratio rockers I had recently installed.
I pulled the plugs and rotated the engine by hand, with my other hand touching the 4 rocker arms.
Nothing felt or sounded out of place as they went through their cycles.
I cranked the engine with the fuel pump relay also removed and no hammering sound.
I pulled the new rocker set, swapped the stock rockers back in and restarted the engine,
Nope, no change, it's still hammering.
OK, I'm out of ideas externally, maybe it's a broken/dropped valve seat.
Time to take things up a level and pull the head.
It turns out to be stunningly easy and about an hour later I extract the head expecting to see something visibly wrong.
But, nada, everything looks normal and well seated
So, the only thing I can think at this point is that it's a failed #2 rod bolt and my concluding that it was the valve train hammering was a red herring.
The Westy is well north of 144K miles and we were pulling a steep mountain grade at altitude at full throttle with 5 adults and a husky on board when this all started.
Or maybe I just shouldn't have painted the intakes red.
Either way, this has got to come out... again... ugh... More down time...
Since 95% of the threads here are about repairs, I had hoped this thread would mainly be about adventures on the road in the Westy.
However, maybe it's time to change the thread name to "Sanchius and Tuna wrench again..."
E1 Samba Member
Joined: January 21, 2013 Posts: 6565 Location: Westfalia, Earth
Posted: Sun Jan 05, 2020 9:30 am Post subject: Re: Sanchius and Tuna ride again... |
Thanks for cleaning up the glyph site. 👍🏼👍🏼👍🏼
The tall plant by the "scorp figure" is corn. You see this on a lot of glyphs in Utah for one, but curiously, have yet to see it on any pictographs. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Jan 05, 2020 9:19 am Post subject: Re: Sanchius and Tuna ride again... |
Yes, Luna turns seven next April.
This is her in her early days when she was no bigger than a boot.
I had a chance to look into the engine noise yesterday and it doesn't look good (repair discussion thread here).
To check the collapsed lifter theory, I ordered replacement lifters and collapsible lifter tubes for cylinders #1 and #2.
They arrived promptly and it was a simple matter to remove the old with a long magnet...
...and very satisfying to install the new.
The collapsible lifter tubes from Bus Depot are an impressive bit of kit.
The old #2 exhaust lifter was definitely expired, I could easily depress the core with my finger and the others were weak.
However, once everything was all back together with the new lifters, the hammering was still there and, if anything, seemed worse than before.
I'm going to try a couple more things, but I'm growing less optimistic that it's not something with the #2 con-rod, which will require a complete tear-down.
Ugh, it looks like I'm going to be back off the road for awhile...
All back together, but definitely not fixed.
Note the Husky hair on cyl #1, that stuff floats everywhere, though I don't suspect it has anything to do with this issue.
Posted: Tue Dec 31, 2019 2:08 pm Post subject: Re: Sanchius and Tuna ride again... |
Tuna coming up on 7 years now?
Woof. _________________ .ssS! |
SyncroBouree Samba Member
Joined: August 25, 2017 Posts: 26 Location: Alongside Monterey Bay
Posted: Tue Dec 31, 2019 11:31 am Post subject: Re: Sanchius and Tuna ride again... |
What a lovely holiday share. The hikes to the train tunnels and petroglyphs are intriguing Good on you for your care-taking of the site.
Sorry for the WBX tribulation that befell you--it appears from all the smiles that the positive spirit of the activities overcame the interuption. I hadn't run into that situation so have nothing better than what has been offered already.
Tuna is beautiful and quite the character I see.
Happy New Year -- Good health and high spirits to all! _________________ --Liam
1990 Vanagon GL Syncro Westy VW1.8T Triple-Knobber
1975 911S Widened Turbo/RSR Hybrid
1979 Harley Lowrider -- Donated to a good home
1969 Ford Bronco Half-Cab 351W, Toploader, Dana 44 FE, Detroit Locker, Duffy’s Suspension – wish I still had it
1962 GMC 3/4T Fleetside, V6<-Chevy 409 w/factory headers, Camper/Tow Rig – ditto |
Posted: Tue Dec 31, 2019 10:14 am Post subject: Re: Sanchius and Tuna ride again... |
As the holidays wind down and our guests slowly depart, we had lots of fun, but also ran into some trouble...
Fun stuff first, we made several snowshoeing trips up to the abandoned UP train tunnels on nearby Donner Pass.
The whole group revisited the Court of Antiquity site for a closer look.
With all the thorns and stickers there, Tunes was sporting her doggy booties to protect her pads.
If you want a laugh, find some videos of dogs wearing these for the first time and trying to walk while getting all four legs off the ground at the same time. Tunes was just like them at first.
At the site, as we looked around, we saw hundreds of pictures that we hadn't seen on the first quick trip.
I don't know what the big image is, but I really like the simplicity of the mini scorp figure in the upper left hand corner.
Our 4 big garbage bags were no match for all the modern trash there, but, fueled by anger, we did our best to clean up the center of the ancient site.
The big event was loading up the Westy for our annual expedition to the mountains for our Christmas tree.
I had picked up the $10 Forest Service cut permit back around Thanksgiving.
As we motored up the Mount Rose highway, trouble struck: loss of power and a very loud metallic engine knock/hammer.
Here's a video of the knock (click the picture) and a separate thread on the problem.
Uh-oh. We pulled over and assessed the situation while two of the party Lyft'd back to the house to pick up a backup van and a tow vehicle.
We left the Westy and tow vehicle at the bottom and went the rest of the way up the mountain in the backup van.
Snowshoeing up the mountainside, we found a perfect tree 100 yards from where we took last year's tree.
Like last year, Tunes enjoyed the outing.
Like last year, she was absolutely worthless on the retrieve, the mice in the holes being much more interesting.
But we had lots of fun on the mountain and the long tow back was uneventful...
This year we got smart and put the lights on the top of the tree before standing it up.
Like last year, Tuna was no help decorating the tree, she is either full on or full off.
And, like last year, it came out great.
Happy Holidays and a great New Year to all!
Posted: Fri Dec 20, 2019 7:10 pm Post subject: Re: Sanchius and Tuna ride again... |
Maddie the Husky Mix has approved the latest posts in this series
Woof, poof goes the Husky Glitter _________________ .ssS! |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Fri Dec 20, 2019 7:05 pm Post subject: Re: Sanchius and Tuna ride again... |
sanchius wrote: |
Since we are not trained archeologists, we were free to make up our own interpretation of the petroglyphs.
This one we called "The Squid".
It seems obvious to me that you found ancient evidence of the Flying Spaghetti Monster ...
https://en.wikipedia.org/wiki/Flying_Spaghetti_Monster _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Fri Dec 20, 2019 5:29 pm Post subject: Re: Sanchius and Tuna ride again... |
Our errands the other day took us by the Tractor Supply store, which is alway fun to visit for all the unexpected farm stuff they carry.
Tuna quickly found her favorite section of the store.
Errands done, we headed out a nearby track to try to locate a dryland/hilltop petroglyph site called Crowsnest.
There are plenty of online descriptions of the site and I have a general idea where it might be.
But there is no exact location info anywhere I can find. https://www.nvrockart.org/pages/Crows_nest.html
We searched a couple outcroppings on the hillside behind the bus, but came up dry.
One big rock on the other side of the valley seemed promising, but the only thing there was modern graffiti.
I suppose if it was easy, it wouldn't be worth doing. In any case, we had a beautiful morning's walk out in the wilds.
E1 Samba Member
Posted: Wed Dec 18, 2019 10:06 am Post subject: Re: Sanchius and Tuna ride again... |
Just noticed the deer video.
Wow, and lucky it didn't come in. Whew.
Glad she's okay and that you fixed the car. 👍🏼👍🏼👍🏼 _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Wed Dec 18, 2019 9:30 am Post subject: Re: Sanchius and Tuna ride again... |
I am going to have to get a better phone. My cell phone pictures from our previous outing on the last warm November day before the snow arrived, where Tuna, Mrs S and I attempted to reach the 1964 crash site of a Lockheed Constellation high up on Genoa Peak outside of Minden NV, were so bad that they were unusable here.
With the first of our holiday guests starting to arrive, we did some initial reconnoitering of fun sites to visit with the full clan.
First we hit some of the Truckee River truss bridges we'd been to before.
The trains coming down the river run fast and quiet.
We were out on the lower trestle checking out the beautiful ice on the river rocks below when we heard a loud train horn just upriver.
We hustled off the bridge and onto the nearby rocks just in time to get a face full of the California Zephyr whistling by.
We drove further up some high-gradient tracks on the Tahoe-Pyramid Lake trail until it became too icy and dangerous to continue.
Then we headed east downriver, through Reno/Sparks, to find the Court of Antiquity petroglyph site just a mile outside of town along I-80.
I'm glad we had left Tuna at home as the path wandered through thickets of tough desert brambles and caltrop burrs that we called Devil's Thorns as the painful spikes got everywhere in our socks and boots.
Along the way, we were revisited by the California Zephyr, headed east out of Reno towards Denver (Click on the picture for the video)
20191217_161835 Amtrak
Thousands of people drive by every day, just 100 yards away, without ever knowing it is there.
Once very impressive, the river-side site was very degraded and full of trash, we'll return with garbage bags on our next visit.
And this one "Rain", "Lizard" and "Falling Man" from left to right.
When we got home, our very fierce husky was very glad to see us and forgave us for leaving her at home by demanded belly rubs.
This is all anyone needs to know about Huskies, except that they are also very stubborn.
jimf909 Samba Member
Posted: Sun Nov 24, 2019 7:12 pm Post subject: Re: Sanchius and Tuna ride again... |
What a great post: videos, screams, repairs, bonus finds at the scrapyard and the descent of dogs into the mixed results of domestication. A good Sunday evening read. Thanks.
Full-size Volvo's do seem to be one of the most comfortable cars ever made. The only front seats that I've found to be equally comfortable are GTI seats. _________________ - Jim
Abscate wrote: |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Sun Nov 24, 2019 6:40 pm Post subject: Re: Sanchius and Tuna ride again... |
I get it - We just sold our 2004 XC70 after 5 years of ownership - likely the most functional, comfortable highway cruiser I have owned. I outfitted it with some ‘R’ suspension parts including sway bar and a GROM Bluetooth unit which just added to the joy of driving it. We once drove it from Sacramento to Vancouver in one shot and upon arrival, was no worse for wear - I liken it to sitting on a lazy boy with a steering wheel in front of it. My only reason for selling was the wife wanted something smaller (it was her driver), so we got her a 2011 C70 to complement my S40. Yes, I love my Westy, but also swear by my Volvo collection. _________________ 1991 Westfalia EJ251, 1972 Volvo 1800 ES |
E1 Samba Member
Posted: Sat Nov 23, 2019 5:11 pm Post subject: Re: Sanchius and Tuna ride again... |
sanchius wrote: |
Finally, I was in the rare books section of the university library researching some of the original archeological studies of the nearby petroglyph sites and came across this image of what could be Grandpa and Grandma S in their early Westy if they had ever made it west of the Hudson River.
THAT is flat-ass awesome! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sat Nov 23, 2019 12:49 pm Post subject: Re: Sanchius and Tuna ride again... |
Woof woof from Husky Maddie in upstate NY..
Did you confirm that colour code for me? 444?
Headed to the big Volvo boneyard later this December _________________ .ssS! |
