MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Tue Mar 28, 2017 6:04 am Post subject: Brake fluid corrosion/master cylinder leak |
Two quick questions...I found out that my master cylinder leak is coming from the rear side fitting (three wires attaching there), is this a master cylinder replacement fix?
Also, I need to clean up the corrosion where it's been spraying around and rust bullet/ master series it or something along those lines, any advice on that?
Thanks! |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Tue Mar 28, 2017 6:54 am Post subject: Re: Brake fluid corrosion/master cylinder leak |
I think you have a bad brake light switch. |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Tue Mar 28, 2017 8:39 am Post subject: Re: Brake fluid corrosion/master cylinder leak |
Try tightening it to see if that stops the leak.
Is there a brake line fitting directly above the brake line switch? On mine I thought the brake line switch was leaking, but it was the fitting above it that was leaking. I tightened mine more and that stopped the leak. |
Posted: Wed Mar 29, 2017 5:01 am Post subject: Re: Brake fluid corrosion/master cylinder leak |
Thanks for the replies...I'll dig into it tonight hopefully.
If it is the switch itself, does the new one screw in dry or do I use a sealant? |
Posted: Wed Mar 29, 2017 8:50 am Post subject: Re: Brake fluid corrosion/master cylinder leak |
I just replaced my entire braking system on my dune buggy, including a new master brake cylinder and the switch you're having trouble with. Everything was screwed in dry. |
Posted: Thu Mar 30, 2017 10:03 am Post subject: Re: Brake fluid corrosion/master cylinder leak |
Thanks again! |
