mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Tue Mar 28, 2017 10:09 pm Post subject: Erco 091 trans bus to bug housing adapter |
Hello everyone,
Does anyone have pictures or a good explanation of the process of how the erco adapter housing installs onto a 091 bus trans to make it work with the type one slider rails and nose cone to install into the type 1 pan? |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Wed Mar 29, 2017 5:09 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
It's quite simple. Completely tear down your 091 trans. Take all the gears from the gear carrier and swap them in to your new gear carrier. Adjust everything and put it back together...
A Bentley will help. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Wed Mar 29, 2017 7:28 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
Dougy Dee wrote: |
Not quite that simple, for instance the adaptor housing uses an early t- m/s bearing, so you would have to bore it for a 002/091 bearing or use an aftermarket mainshaft, or machine the late main shaft for an early bearing. This is only one of the things you have to do.
The Bently is not going to show you the things needed to be done for this conversion. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Wed Mar 29, 2017 6:51 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
mcmscott is correct. I received some pics today from Rancho. Trying to figure out how to upload them from my email now. Some clearance of the 091 case is needed. |
Posted: Thu Mar 30, 2017 4:44 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
Mcmscott is correct about not having any info/manual on how to assemble a trans with this housing, and there are a few things other than disassembly/reassembly. Unless they are no longer available, Rancho has an Erco housing that uses a late bearing.
Early
Late
Posted: Thu Mar 30, 2017 9:19 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
Sorry for not getting back to you, my "other" supplier now only has the other style _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Thu Mar 30, 2017 6:08 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
Hopefully Scott will add what I miss, but I have been trying to collect notes on the conversion when people talk about it.
Clearance main case
T1 Shift rails needed
1-2 rail has to be cut down
T1 Reverse parts needed (lever, eyelet, etc) |
Wreck Samba Member
Posted: Thu May 04, 2017 4:59 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
The Erco housing fitted to a 5 rib housing , running an eco 4.56 R&P with an old albins mainshaft . I've just about completed the mounts to fit into a '69 Ghia without cutting or welding to the frame horns . using GM gearbox mounts that can be changed without removing the engine . I can post pictures of the mounting system if people are interested . |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Thu May 04, 2017 8:04 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
Wreck wrote: |
Yes please! _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
Wreck Samba Member
Posted: Fri May 05, 2017 10:23 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
still mocking up , I also shortened the nose cone and hockey stick by about an inch to move the box as far forward as possible . waiting for flat washers etc , also starting to fab up supports for the frame horns and fitment of oil coolers etc . It's going into a '69 Ghia with a 2.6 type 4 . |
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Sat Dec 02, 2017 3:14 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
I'm looking into doing this conversion to my bus, currently using IRS T1 SSC trans. With the way the trans is mounted, have you figured out axle length? Are the axles equal length with the trans mounted the way you have it?
Thanks in advance! |
Posted: Sat Dec 02, 2017 6:14 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
What length are you using now? In a Beetle torsion/suspension, a common length axle the off-roaders would use when switching to a Bus trans is 15 5/8. This would be from a stock Beetle axle of 16 1/4. Any conversion I've come across centered the diff to have equal length axles, but the bell housing on a Bus trans is offset from the centerline. |
Wreck Samba Member
Posted: Sun Dec 03, 2017 2:56 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
I used 15 5/8 axles , the box is slightly off set one way to get the engine closer to centre , (it's still off set ) .
Bruce Samba Member
Posted: Sun Dec 03, 2017 4:41 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
Casting Timmy wrote: |
Clearance main case
A friend tells me that he drills the necessary hole in the main case to support the tail end of the 1-2 shift rod. _________________
Posted: Mon Dec 04, 2017 6:05 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
Bruce wrote: |
Clearance main case
A friend tells me that he drills the necessary hole in the main case to support the tail end of the 1-2 shift rod. |
That would be the good way to do it. |
Posted: Wed Dec 06, 2017 9:12 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
[email protected] wrote: |
Currently, I'm using the stock axles out of a '69 Bus with the T1 SSC trans. T2 CV on the outside and T1 CV on the inside. I don't have frame horns on my bus so the '69 T2 trailing arm mounts fall right where the frame horns would normally be on a stock bus torsion housing. |
Posted: Thu Dec 07, 2017 5:15 am Post subject: Re: Erco 091 trans bus to bug housing adapter |
Is this a Bus that would have normally had a Type 1 style swing axle trans with the gear reductions, or one that would have originally used an IRS trans? Are you using Type 1 IRS arms from a Beetle, or Type 2 arms from a later Bay Bus? The stock axles for the Bay Bus would be 18 3/4. If that's what you are currently using, you may be able to get a high performance version of them that have longer CV splines, and trim the axle to the length you need. Then you could simply cut new c-clip grooves on the ends. Other than that, you may have to cut/splice a stock axle for mock up, then have a custom set made once you have determined the length. |
Posted: Wed Dec 13, 2017 8:55 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
Yes, it originally had big nut reduction boxes and swing axle trans.
Quote: |
Are you using Type 1 IRS arms from a Beetle, or Type 2 arms from a later Bay Bus? |
The arms are from a '69 T2 baywindow bus.
Thank you for the other info! It will come in handy. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Fri Dec 15, 2017 1:54 pm Post subject: Re: Erco 091 trans bus to bug housing adapter |
Wreck wrote: |
Really beautiful job on the Motor mounts. Any issues when romping on it (engine lift, twist, etc). The reason that I ask, is because of my experience putting a 002 in my Baja. This was way before I even knew about Forums like the Samba. I had "heard" that you could put a bus transmission in a Type 1, and keep the nose cone in the tunnel, so I decided that I would make it happen, but I wanted rubber motor mounts. I ended up spending a hours thumbing through a NAPA MM catalog, as well as a lot of fabbing and re-fabbing until I found some MM that could handle all of the different stresses. Once again, great job. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
