Turn signals light up when I hit the brakes LOL
74superTN
74superTN is offline
PostPosted: Thu Mar 30, 2017 4:25 am    Post subject: Turn signals light up when I hit the brakes LOL Reply with quote
So I just noticed lastnight in my garage that when my car is running and I hit my brakes, both front turn signals illuminate along with my speedometer light..Any ideas?
73 Thing
DKK - Deutsche Kafer Klub
www.dkk-savannah.blogspot.com
www.georgiadubs.com
Captain Spalding
Captain Spalding is offline
PostPosted: Thu Mar 30, 2017 7:09 pm    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
That is a weird one all right. Not that I'm following any line of thinking, but do the front turn signals work properly with the rear turn signals when you activate the turn signal switch, but the brake pedal is not depressed? When the brake pedal is depressed, do the rear turn signal lamps light up along with the rear brake lamps and front turn signal lamps? When you say speedometer light, do you mean the white bulbs that illuminate the gauge? Or one of the idiot lights?
perello
perello is offline
PostPosted: Thu Mar 30, 2017 11:57 pm    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
My experience is when such funny things happen it means there is a grounding problem. Check the ground on the speedo.
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
911pickup
911pickup is offline
PostPosted: Fri Mar 31, 2017 6:08 pm    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
I'll second the 'grounding' solution. Now, if I can only figure out why I blow my turn signal/wiper fuse when I turn on the ignition..... Crying or Very sad
sb001
sb001 is offline
PostPosted: Fri Mar 31, 2017 10:55 pm    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
That's impossible.
1969 autostick sedan, owned since new
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
60ragtop Premium Member
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sat Apr 01, 2017 5:48 am    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
check all your light bulbs and make sure you don't have a single filament bulb where a dual filament bulb is supposed to be.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
[email protected] wrote:
aftermarket shit that always needs a tweek eats time
Eaallred wrote:
People are over analyzing.......(insert your problem here)
wcfvw69 wrote:
The real German 009's are a quality part, I ran one w/points for years back in the 80's w/zero issues.
Ron Domeck
Ron Domeck is offline
PostPosted: Sat Apr 01, 2017 6:42 am    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
I have said this before, take all fuses out and clean both sides of the fuse box and replace with new fuses. Old fuses may look good but replace them. Easy to do and not much money. Unhook the battery for this.
74superTN
PostPosted: Sat Apr 01, 2017 6:12 pm    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
So the issue fixed itself...I noticed that my turn signals weren't even working normally all of a sudden so after giggling the turn signal switch at the steering wheel, they started working again and the brake issue disappeared..weird
73 Thing
www.georgiadubs.com
Wildthings
Wildthings is offline
PostPosted: Sun Apr 02, 2017 12:42 pm    Post subject: Re: Turn signals light up when I hit the brakes LOL Reply with quote
2x
Also I personally like to use fuses with brass strips verses zinc strips and to coat the ends of the fuses with a bit of dielectric grease prior to installing.
