82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Thu Mar 30, 2017 10:11 am Post subject: Wiper Shaft - Broken: Left Side FIXED |
(driver's side windshield wiper shaft)
Ok, how screwed am I?
I'm planning on a 10-12K Road Trip in about 5 weeks and want a reliable fix.
I MIGHT be able to locate a complete mechanism locally and I understand that will entail taking the dash apart to R&R it
Are there other options? Your collective help will be HIGHLY appreciated
thanx _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Thu Mar 30, 2017 10:26 am Post subject: Re: Wiper Shaft - Broken |
You could drill it centered, tap it and use a bolt to hold the arm on. You'd have to be pretty good with a hand drill to do it well. _________________ ☮️ |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
DometicLover Samba Member
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Zeitgeist 13 Samba Member
Posted: Thu Mar 30, 2017 10:53 am Post subject: Re: Wiper Shaft - Broken |
When you pull the dash, don't forget to replace the squirters, tubing from the reservoir on up and add a one-way check valve _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
tates1882 Samba Member
Joined: August 07, 2012 Posts: 275 Location: Southwest Idaho
Posted: Thu Mar 30, 2017 11:20 am Post subject: Re: Wiper Shaft - Broken |
I vote drill and tap. Start small and work your way up in size. Also I can't remember the tap type but there one specially for non pass thru holes. The blades of the tap extend past the head of the tap so you can have full threads instead of bottoming out and leaving 1/8-1/4" of threadless hole at the bottom. _________________ 88 Vanaru, ej22, naht |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Thu Mar 30, 2017 11:34 am Post subject: Re: Wiper Shaft - Broken |
removing the dash is not very hard... if you don't have a plan to do anything else, you won't have to take it off completely... just pull it back enough to have access to the wiper shaft...
http://www.benplace.com/dash.htm |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Thu Mar 30, 2017 2:23 pm Post subject: Re: Wiper Shaft - Broken |
Having a fix on the driver'side side fail on a long trip could easily be much worse than taking out the dash.
If you can find a replacement unit take apart the pivots and scrape out the old grease and reapply new grease, you will be surprised how much it improves the action.
Posted: Thu Mar 30, 2017 2:24 pm Post subject: Re: Wiper Shaft - Broken |
Thanx one and all
We have a winner and a project for the weekend
Pulling the dash isn't exactly my favorite project but at least it's not my first rodeo...
I appreciate the drill and tap advise but I'm more 'do it right / new part'
T3 Pilot
http://www.van-cafe.com/page_56_1324/wiper-shaft-left _________________ "The floggings will continue until morale improves"
82 Westfalia - w/ a Raby 'Camper Special' engine |
jberger Samba Member
Posted: Thu Mar 30, 2017 7:24 pm Post subject: Re: Wiper Shaft - Broken |
I would weld a bolt to the end of the shaft, nip off the head of the bolt and head on my way. 1/2 hour fix vs ?? |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Fri Mar 31, 2017 6:51 am Post subject: Re: Wiper Shaft - Broken |
drill and tap it. I've fixed a bunch this way. Tap it about 1/2" deep, then screw a 6mm bolt in it until it bottoms out, then cut the head off the bolt so as to leave the threaded part sticking out like a stud. It can be done in about 5 minutes.
Andrew |
bluebus86 Banned
Posted: Fri Mar 31, 2017 7:40 am Post subject: Re: Wiper Shaft - Broken |
drill and tap if it was my van, replace only if the dash needs to come out for some other reason, for instance my pending blower motor repair. meanwhile the tap and screw method should hold just fine. the torque of the motor and arm is transmitted by the splines, the screw only needs to keep the arm on the splines, not much force needed for that, thus the screw will work. next time go easy on tightening them arm nuts, else the next stud maybe sheared off again.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Fri Mar 31, 2017 8:55 am Post subject: Re: Wiper Shaft - Broken |
I broke one a couple years ago. Drilled and tapped it for a 6mm bolt. I knew i was going to be pulling the dash for a paint job eventually. That was a year later. No issues with the repair. |
Posted: Sat Apr 01, 2017 11:29 am Post subject: Re: Wiper Shaft - Broken: Left Side / NO DASH PULL |
Well it turns out, you DON'T need to pull the dash to replace the left side
I removed the instrument cluster, moved the 2 vent air hoses out of the way, undid the nut on the outside and the 2 phillips head screws inside just below the windshield. After that, it was just a matter of working in a very confined place and popping the relay bar off.
The you just need to grind down and drill out the two attachments to the bracket, remove the offending part, install the new part and and hammer over the new attachments.
After that, its 'easy-peasy', reverse the removal to reinstall
And I feel a lot better about a new part _________________ "The floggings will continue until morale improves"
Posted: Sat Apr 01, 2017 11:32 am Post subject: Re: Wiper Shaft - Broken |
BRAVO !!! very nice job...
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Sat Apr 01, 2017 11:33 am Post subject: Re: Wiper Shaft - Broken |
Nice job. Yeah, that will feel better on a long road trip you've been planning. I'm a rainX fan and apply before leaving, then every few days while the tank's filling at a gas stop. I hardly use my wipers and the heavier the rain and the higher the vehicle speed,the better it works.
Put it on the side windows and even on rainy days you have clarity of view - no claustrophobic effect. It lasts a whole summer on the side/rear glass because no wiper abrasion.
Good job!! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
