Oval rear brakes
Mr Fish
Mr Fish is offline
PostPosted: Thu Mar 30, 2017 2:28 pm    Post subject: Oval rear brakes Reply with quote
Im wanting to put on 30mm oval era rear drums onto my bug but i don't have all the parts... here is what i have :
drums
backing plates
bearing housing cover
and i can buy easily:
shoes
cylinders
springs and fitting kits etc
what i don't have is the e-brake lever and the rigid brake distance bar that sits between the shoes.
- what i need to know is whether these parts definitely need to be 'found' or whether i can use later 58-64 items?
I have 58-64 drums/parts at the moment but need to change it back to oval as I'm having some specific oval era drums 'worked' for the car..
anybody have any knowledge on this? i have looked for info but I've found myself going round in circles..
shippey87
shippey87 is offline
PostPosted: Wed May 18, 2022 2:32 pm    Post subject: Re: Oval rear brakes Reply with quote
I have the same issue with my 57 oval. Did you find any answers? I am missing all the parts for my split case transmission brake system. All I have is the backing plates.
Calvatron
Calvatron is offline
PostPosted: Wed May 18, 2022 5:19 pm    Post subject: Re: Oval rear brakes Reply with quote
Following! I have my whole brake setup but don't have the e-brake lever either. The bar might be an easy part to make yourself. Just a rectangular piece of steel with some notches right? If you're interested I can measure mine for you.
gregwiedle
gregwiedle is offline
PostPosted: Sun Jan 08, 2023 7:06 pm    Post subject: Re: Oval rear brakes Reply with quote
I need these too and just found this ad on TheSamba for 1957 and earlier reproduction e-brake levers and push bars out of Finland.
https://www.thesamba.com/vw/classifieds/detail.php?id=2432384
http://www.restorationpanels.com/
Mr Fish
Mr Fish is offline
PostPosted: Mon Jan 09, 2023 12:34 am    Post subject: Re: Oval rear brakes Reply with quote
Smile
tcoop1100
tcoop1100 is offline
PostPosted: Mon Jan 09, 2023 1:12 pm    Post subject: Re: Oval rear brakes Reply with quote
No personal experience but from what I've read here Virtanen's parts are well made and fit properly. The price seems pretty reasonable too, especially compared to the price and condition of originals, IF you can find them! Laughing
Aloha,
Tim
January '57 Sedan with April '64 40hp big bore
lardawge
lardawge is offline
PostPosted: Mon Jan 09, 2023 2:43 pm    Post subject: Re: Oval rear brakes Reply with quote
I bought these from Mika. I had an issue with the spanner piece and had to grind it so it didn't rub the backing plate. It twisted the metal when the dimple was pressed and makes a sharp edge that is not on the factory part. Other than that, they are a good reproduction and work well.
11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
1/7/55 L275 Light Beige
