1968 Deluxe resurrection
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 14, 15, 16  Next
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Mon Jun 19, 2017 3:06 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
wcfvw69 wrote:
Remember people, the glass isn't have empty it's half full! Wink
Glass half empty, glass half full, either way, the glass is twice as big as it needs to be Laughing
I ordered an ignition switch from fellow Samba member VWtech & it showed up the other day THANKS Bob!
Then I unbolted the column & rotated it so I could install the switch, all the fasteners were missing so I'll have to source those. I was curious about the steering lock so I removed the lock mechanism.
Unfortunately the lock pin has been removed, I'll have to find one later.
But now the key will work in the ignition & should once I remove this & sort out this rat's nest.
Tcash
Tcash is offline
PostPosted: Mon Jun 19, 2017 4:43 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
This is for a 1970 but will give you the idea.
click on pic
wiring diagrams
https://www.thesamba.com/vw/archives/info/wiringt2.php
sdmanzor
sdmanzor is offline
PostPosted: Tue Jun 20, 2017 10:26 am    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Hi, Im in the same mission of a old 72 resurrection. This is very inspiring!
Although, I've been looking desperately for a new or old front beam. Do you have any tip about where to look for this part? I will appreciate it a lot!!!
TDCTDI
TDCTDI is offline
PostPosted: Tue Jun 20, 2017 11:13 am    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Welcome to The Samba!
Try doing a search in the bay bus classified section.
https://www.thesamba.com/vw/classifieds/search.php...words=Beam
It would also help to know where you're at.
TDCTDI
TDCTDI is offline
PostPosted: Tue Jun 20, 2017 3:09 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Todays task was to reassemble the steering lock housing, I got the lock housing back together, & used some heat shrink on the harness to clean it up as much as possible.
In the process of trying to install the lock mechanism & housing I discovered that the housing is the incorrect part.
It's designed to sit higher causing the column tube to sit lower & cause the steering wheel to not sit where it needs to.
Oh well, the hunt is on, I might just modify & shim it up until I can find the proper one for a reasonable price.
So I then decided to try to re-key the door handles, so I removed the drivers side.
After lubricating it & futzing with it, I discovered that the new key actually matches the handles. YAY!
So then I cleaned the nasty repaint from around the door handle & reinstalled the handle & lubed up the lock mechanism.
TDCTDI
TDCTDI is offline
PostPosted: Thu Jun 22, 2017 3:57 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Todays Crusty Pig progress.
TDCTDI
TDCTDI is offline
PostPosted: Fri Jun 23, 2017 3:57 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Crusty Pig update
orwell84
orwell84 is offline
PostPosted: Fri Jun 23, 2017 4:12 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
What are your plans for paint once you get it all cleaned up?
TDCTDI
TDCTDI is offline
PostPosted: Sat Jun 24, 2017 8:07 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
I'm not quite sure yet, the original paint isn't quite nice enough to try to drive as is while doing the body repairs (too wet & humid to let it go bare metal.) so touch up will be needed at the very least.
This Crispy Pig kept me from doing anything with the Crusty Pig.
rogerd20
rogerd20 is offline
PostPosted: Sun Jun 25, 2017 5:53 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
the pig and the bus both look good lol
TDCTDI
TDCTDI is offline
PostPosted: Tue Jun 27, 2017 9:39 am    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Thank you sir. And welcome to The Samba! Yes, the Crispy Pig was great, the Crusty Pig however...
I received my window seals & some other parts that I needed to get the Crusty Pig back together.
So I pulled the old gaskets out to prep the openings for the windows that I picked up from someone that was parting a Bus on Clist. The passenger side was apparently broken out with a baseball bat or the like which slightly bent the opening.
So I removed the sliding door track cover & started to clean the channel & it looks like I'll be doing some rust repair before installing the glass.
TDCTDI
TDCTDI is offline
PostPosted: Wed Jun 28, 2017 1:40 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
I REALLLY didn't want to do this but...
I started by straightening the window opening, first with a pair of pliers.
Then with a modified pair of Vice-Grips.
Much better.
Then it was time to start addressing the rust. First I drilled out the spot welds on the slider cover mounting flange.
Then I gently worked the flange back & forth to get to release from the body.
Pinetops
Pinetops is offline
PostPosted: Wed Jun 28, 2017 1:45 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Gotta do what you gotta do. Great work on this bus so far, thanks for the updates!
"A rolling bus gathers no rust."
TDCTDI
TDCTDI is offline
PostPosted: Thu Jun 29, 2017 1:18 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Thanks! I'm glad it's been interesting enough for people to follow.
Here's where I started cutting out the rotted window frame.
And then separating the pre-drilled spot welds.
Here it is with the rot removed.
Then forming & fitting the replacement metal.
And with a few tack welds.
TDCTDI
TDCTDI is offline
PostPosted: Fri Jun 30, 2017 3:46 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
The weather didn't cooperate to do anything with the body so I just cleaned, blasted, & painted the sled tins.
TDCTDI
TDCTDI is offline
PostPosted: Sun Jul 02, 2017 7:51 am    Post subject: Re: 1968 Deluxe resurrection Reply with quote
I spent a few more hours scraping, cleaning, & blasting the left heat exchanger.
Then painted it.
Then installed the sled tins & heat exchanger.
TDCTDI
TDCTDI is offline
PostPosted: Mon Jul 03, 2017 3:41 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
I was just about to toss the engine back into the Crusty Pig but then I kept thinking about the fact that the fuel sender unit wouldn't be accessible once it was back in so I pulled it back out & followed this process...
https://www.thesamba.com/vw/forum/viewtopic.php?t=629435
With one slight deviation to keep from melting the plastic insulator.
Since the hardware store is already closed, it might be tomorrow (if they're open.) or the next before I can get the tank & engine back in.
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Tue Jul 04, 2017 9:03 am    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Nice to see these updates! Any reason for going black instead of grey on the heat exchangers?
Robbie
In the woods for the next two weeks.
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
TDCTDI
TDCTDI is offline
PostPosted: Tue Jul 04, 2017 10:15 am    Post subject: Re: 1968 Deluxe resurrection Reply with quote
Robbie
Thank you sir!
After removing all the crud & grime, what paint was still there was black with no hint of anything under that (You can still see some of it in a couple spots.).
I thought about trying to go through archived pictures of what the engines looked like as they came off the assembly line but couldn't find anything definitive. Yes, I know that all of the replacements were grey but mine were black so that's what they went back to. It's not like this thing will ever be concourse quality.
TDCTDI
TDCTDI is offline
PostPosted: Sat Jul 08, 2017 1:09 pm    Post subject: Re: 1968 Deluxe resurrection Reply with quote
I finally got to find a screw & nut at the local hardware store (they went on vacation through the 6th) I used a 4mm x 6mm pan head screw (since I have metric taps).
So I reassembled the sender unit, tested it (it works now!!!), installed it in the tank, & put the tank back in.
I also installed a new in tank filter.
Tomorrow, I'll try to get the engine back in!
Page 7 of 16
