telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Thu Mar 30, 2017 10:28 pm Post subject: Electrical Terminals FAQ |
To link to this thread
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=675638&start=0&postdays=0&postorder=asc&highlight=electrical+terminals]Electrical Terminals FAQ[/url]
This is a FYI for those of you doing electrical work. I have added Gallery pics (seen below) showing terminals made by Amp and available from Digikey in the proper "F" terminal configuration. All of the standard 1/4" types, in various wire gauges, are shown. As a special treat, piggyback versions are also available, as well as the rare 3/16" size for voltage regulators, and the small 0.110" size. All of the non-piggyback terminals have the retaining tab which keeps them in connector housings. Also two-pin injector housings and pins are shown. The pin is universal throughout a FI harness.
All of these part numbers are available in quantity 1 (although it would be silly to buy just 1, price-wise...)
You do need the proper "F" terminal crimping tool to use these. The payback is these result in an OEM quality crimp (waaaayyy better than the terminals you buy at your local FLAPS). And if you sleeve the finished terminal with a short length of heat-shrink tubing (1/4" for 1/4" terminals, for example), then you're even better than Factory Stock!
For more info, go to the Digikey website and enter the part number. Note: these are just the most useful of the huge quantity of terminal types available.
FI and ring terminals
0.110, 1/4", 3/16"
Here's one (from the Gallery):
This is a front view of the 2-pin DigiKey Junior timer connector A106202-ND connector already shown. The important feature here is the release bar. Press it towards the connector body and it is released from it's mate. It's a perfect solution to those hard-to-reach connectors that are almost impossible to unplug. I use them on all of my injectors, as they tend to get unplugged periodically.
0.250" (6.35mm) Quick Connect Male 14-18 AWG Digikey p/n A27922CT-ND
0.110" (2.79mm) Quick Connect Male 17-20 AWG A107076CT-ND
"These are good for making test connectors or your own noid light, etc." Telford
2 Position Rectangular Housing Connector Plug Black 0.197" (5.00mm) A104935-ND
For the above housing.
CONN TAB CONTACT 17-20AWG JPT A107027CT-ND
_________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Fri Mar 31, 2017 7:57 am Post subject: Re: Electrical Terminals |
Great info. Thanks for taking the time to post. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Mar 31, 2017 12:26 pm Post subject: Re: Electrical Terminals |
Would you recommend a favorite crimping tool for these? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Fri Mar 31, 2017 12:43 pm Post subject: Re: Electrical Terminals |
Removable dies i used in my harness and continue to use regularly.
https://www.amazon.com/gp/product/B00788IUJU/ref=o...k129040-20
I have a generic (Harbor Freight) wratcheting crimper they drop into _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Wed Apr 05, 2017 5:41 pm Post subject: Re: Electrical Terminals |
These are the ones I use most.
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
airschooled Air-Schooled
Posted: Thu Apr 06, 2017 5:29 pm Post subject: Re: Electrical Terminals |
There was a green/black ratcheting crimper sold on Amazon a few years ago with Paladin jaws; I love mine, but I can't find it at the moment. Any crimper with replaceable jaws will allow you to replace the cheap ones in a few years, or the good ones in a few lifetimes.
www.airschooled.com |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Apr 06, 2017 6:36 pm Post subject: Re: Electrical Terminals |
I want someone to hold my hand and show me the male connector to use on the diagnostic box for the small holes. (trailer wire harness) |
Hoody Samba Member
Posted: Thu Apr 06, 2017 10:32 pm Post subject: Re: Electrical Terminals |
Thank you so much Telford for posting this. I am about to tackle every single connector on my restoration. You are a true asset to the Bus community! |
gleason Samba Member
Posted: Sat Jun 03, 2017 2:22 am Post subject: Re: Electrical Terminals |
Thanks for locating. I didn't find through the search. |
Tcash Samba Member
Posted: Fri Jun 09, 2017 1:46 pm Post subject: Re: Electrical Terminals FAQ |
t2a
Tcash Samba Member
Posted: Thu Jun 15, 2017 10:01 am Post subject: Electrical Wire |
Electrical Wire
I'm am going to link this, so I can find it later.
Looking to buy bulk wire
Note: Metric wire was used in VW's |
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Fri Apr 27, 2018 2:56 am Post subject: Re: Electrical Terminals FAQ |
A couple of additional notes on the Junior Power Timer (JPT) connectors for the FI harness, for those replacing a broken connector or making their own harness:
• You cannot use the new style connector with the release bar everywhere: the Auxiliary Air Regulator (AAR) connector needs to be original style, as otherwise the release bar hits the AAR hose to the plenum. A bit of a shame really, as it is one location which could have really benefitted from an easier release.
• Another tight spot is the Thermo Time Switch (TTS). You can in fact use the new style connector (I've done it), but the release bar ends up pointing to the case splitting line underneath the plenum. This makes it fairly awkward to push on. However, it still beats the old style connector in that location, which is nearly impossible to disconnect with a mounted plenum.
• Watch out for the style of the back of the connector. If you look at the picture below, you can use either the EV1-1 or EV1-3 style. EV1-1 is waterproof and you use some rubber boots on the terminals that are then held in place by the small trident-like lid on the back. They work perfectly fine also without the rubber boots, but they look slightly less stock as the back of the connector not covered by the big rubber boot is longer. I would have prefered tp use EV1-3, as they are stock (plus release bar upgrade), but I also wanted the connectors be color-coded. I could only find EV1-3 connectors in black, whereas there were EV1-1 connectors in green, blue, brown and black. Also, the longer EV1-1 connector works fine at the Cold Start Valve (CSV), but it makes everything a bit more cramped in that area.
Another stock connector that comes in very handy to insulate two wires connected to each other by a male/female terminal is VW 111 971 977. I've not found a source for the equivalent non-VW part, but I'm sure there is:
Also, to TCash (or any other mods): could this fine thread be added to the tech tips section? Thanks! _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
spacebiscuit Samba Member
Posted: Fri Apr 27, 2018 7:06 am Post subject: Re: Electrical Terminals FAQ |
Again, thanks for posting this information which is a great help to me as I am re-wiring my bus. I have been in search of the female terminal A27937CT-ND - for the thicker 4.0mm wire. Have searched online and couldn't find the part for love nor money... until now.
Some of my own observations - I bought a crimper on Amazon with yellow handles, these seem to be made in china and although they look the part the jaws broke in mine after 3 uses.
https://www.amazon.co.uk/gp/product/B0743FCFZS/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1[url]
I have since puchased a set from a seller in Germany which have been great and did not break the bank:
https://www.amazon.co.uk/gp/product/B001ILAG2M/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
I also found that some of the terminal connectors are of questionable quality and are easily crushed out of shape. I found the silver finihses ones to be better than the gold/copper type. |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Fri Apr 27, 2018 7:45 am Post subject: Re: Electrical Terminals FAQ |
bit of trivia: the connection made by those crimpers is known in the trade as a double buttcheek crimp. If you say this on a military base, everybody in earshot wants to make a crimp so they can say they are rated to make a double buttcheek crimp.
I made the mistake of getting double buttcheek crimp dies with a flat bottom. when you crimp with them the connector wedges in and you have to hammer a jewelers screwdriver in to drive the connector out. very not safe. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
xyzzy Samba Member
Joined: March 24, 2014 Posts: 229 Location: Encinitas, CA
Posted: Fri Apr 27, 2018 8:47 am Post subject: Re: Electrical Terminals |
Al Capulco wrote: |
Great set of crimp tools -- where did you purchase these? _________________ -----
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia |
sestino Samba Member
Joined: July 03, 2007 Posts: 70 Location: University Park, Maryland
Posted: Sun May 06, 2018 6:00 am Post subject: Re: Electrical Terminals FAQ |
Telford, thanks for posting this. Does anyone know which type of connector I should order to connect some trailer wiring through the diagnostic plug?
This posting by TCash shows that I can access tail light, lleft turn, right turn, and brake light through terminals 9-12 at the diagnostic plug.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8117689#8117689
I suspect the connectors I need are one of these:
telford dorr wrote: |
Thanks in advance. _________________ 1977 Fuel-Injected Sage Green Westy |
Posted: Sun May 06, 2018 9:58 am Post subject: Re: Electrical Terminals FAQ |
sestino wrote: |
This posting by TCash shows that I can access tail light, lleft turn, right turn, and brake light through terminals 9-12 at the diagnostic plug. |
You mean a mating connector for the diagnostic plug? I wish I knew - I'd order up a couple immediately!
Back when these first appeared (1971), the machine which plugged into them was a huge monster which only dealers had. These days, such a device would fit in the palm of your hand (think: OBDII code readers), and could be Arduino based, and pretty affordable. Yeah, the amount of stuff it could check is a bit limited, but it could do a basic electrical diagnosis of stuff which cause many people grief, like turn signals. A more practical application would be a remote start / stop plugin, which would allow engine operation without having to get up and go to the cab, or crawling underneath to clip onto the starter motor.
Sounds like a great cad / 3-D printer project. ANYONE?
Quote: |
I suspect the connectors I need are one of these: |
I think you're right, although I haven't really inspected it that closely. The two big ones in the middle of the connector are like the terminal on a voltage regulator (3/8"), I think. Try a DigiKey p/n A107118CT-ND (10-12 AWG wire), or a A123012CT-ND (7-10 AWG wire). For the matching female connector, use A100538CT-ND (10-12 AWG wire) or A100537CT-ND (7-10 AWG wire). The A106301-ND part listed above is no longer stocked.
Did a quick tally:
Diagnostic Connector Pinout
Small pins:
1 -
2 -
3 -
4 -
5 - rear window defogger (drive sense, after relay)
6 - 12 vdc (use with 14 to measure gen/alt current)
7 - battery electrolyte probe
8 - battery "-" post (use with 17 to measure starter current)
9 - tail lights
10 - left turn (rear)
11 - right turn (rear)
12 - brake (three light models only)
13 - points signal
14 - gen/alt B+ at alternator
15 - auto trans kickdown switch
16 -
17 - body ground (use with 8 )
18 -
19 - cyl #1 plug sensor
20 - cyl #1 plug sensor
21 - TDC sensor
22 - TDC sensor
23 -
24 -
Big middle area high current pins:
"15" - ignition
"50" - starter
"+" - battery power
"31" - battery ground
If anyone knows what the unlisted pins are use for (any model), please post. _________________ '71 panel, now with FI
Last edited by telford dorr on Mon May 07, 2018 8:24 am; edited 3 times in total |
Posted: Sun May 06, 2018 3:14 pm Post subject: Re: Electrical Terminals FAQ |
Telford, thanks for your prompt and thorough reply.
Unfortunately, when I went out to start on this project this morning, I discovered that my diagnostic socket was removed long ago.
The socket that I remember was in my previous bus, which I sold in 2002. I guess I'm getting old.
Without the diagnostic socket, I tapped into the tail light wires, mostly in the bundle of wires that is on the top left of the rear engine hatch.
The trailer I will be pulling is a 1970s Coleman Versa trailer with a tilt top. I will post photos in the Bays and trailers thread soon. _________________ 1977 Fuel-Injected Sage Green Westy |
RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Posted: Tue May 08, 2018 8:52 am Post subject: Re: Electrical Terminals FAQ |
sestino wrote: |
For the next person that wants to try this, the diagnostic plug on my 76 is still present and has female ends needing round pin-type holes. I didn't measure the diameter, but I'd guess the required pins would be about 4 mm in diameter. Something like this:
https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/66099-4/A1340-ND/19385
Those aren't the correct pins, but it illustrates what to look for. _________________ Andrew
Oscar: 1976 Westfalia Deluxe Camper, 2.0L FI, Manual Transaxle |
