Vman60 Samba Member
Posted: Fri Mar 31, 2017 7:17 pm Post subject: Old fart needs help with tire size on front. |
I have a 73 bug with an older baha kit which I am replacing and painting. I wish to put 15x8 torque thrust cnn 515 wheels on it. Back will be 31x10.5x15. Front I am not sure of the tall and wide size tire I can go to without total Front end work. Do not wish to have 🍩 size tires. I like the beefy look. Going with general grabber at2 tires. So if anyone can help a newbie and an old cart out I would be grateful. Thank you in advance. |
Vman60 Samba Member
Posted: Sat Apr 01, 2017 8:16 am Post subject: Re: Old fart needs help with tire size on front. |
Thanks for the reply, but everyone is either going to little skinny tires or lowering their bugs. Checked everything on here that I could search which is why I am asking. Have all I need except for the front. Thanks. |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Sat Apr 01, 2017 10:04 am Post subject: Re: Old fart needs help with tire size on front. |
With an 8" wide wheel I'd recommend something in the 215/65-15 to 225/70-15 range.
Anything tire that is narrower will be too small for the 8" wide rim and any tire wider will give you a heavier steering feel at lower speeds.
Just a reminder-with an 8" wheel and larger tire you may have to adjust your Pitman arm stops, to keep the tires from making contact with the body or suspension. |
Vman60 Samba Member
Posted: Sat Apr 01, 2017 5:57 pm Post subject: Re: Old fart needs help with tire size on front. |
Thank you so very much for your help. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Apr 02, 2017 10:10 am Post subject: Re: Old fart needs help with tire size on front. |
You can find good used tires Cheap to run for a year or so to try out different sizes. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
