peagreenbus Samba Member
Joined: December 07, 2014 Posts: 22 Location: SW France
Posted: Sun Apr 02, 2017 9:51 am Post subject: '78 Westy exhaust - can I swap from US spec to EU ? |
I have a question on a 1978 bay with the type 4 2L engine.
Californian import into Europe.
Full exhaust replacement -
The heater smells of exhaust if I put it on to heat - so I don't and we freeze! - so I suspect aging leaky heat exchangers. (And seals, etc).
It all looks pretty rusty down there.
The existing setup is manifold pipes into "after-burner" 180 degree curves going into the heat exchangers, out to a cat and then into the silencer. Tailpipe out on passengers side. I think this would have been stock for a US Californian vehicle.
I think I want to replace the whole lot with European exchangers and silencer. I am presuming I can just loose the cat.
A few other detalis -
The FI was stripped out by a PO. I replaced the very wobbly empi thing that the PO had put on in its place, with a pair of Dellortos.
There are no sensors any more on the cat, and no egr setup.
Bottom engine tin, which would have been specific for the US exhaust, has gone along with the thermostat - so a side effect of this is that I will replace stat with a remanufactured one - and the tin with EU tin to fit EU exhaust.
My question is whether this is the right thing to do or should I replace with US parts? And do away with the cat?
Any help would be gratefully received. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Apr 02, 2017 10:34 am Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
If you don't have to do a smog test then there's no reason you need the cat. The deciding factor for your swap will be the shape of the exhaust ports on the heads, if it has the 72-78 oval ones then it's no problem, the 79+ square ones will be more difficult to work with off the shelf parts on, but not impossible. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Apr 02, 2017 12:32 pm Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
Just did this exact thing to my Riviera
Don't know what happened there but edit turned into quote??? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Posted: Sun Apr 02, 2017 12:35 pm Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
williamM wrote: |
Just did this exact thing to my Riviera -It had square ports- and a Cali style cat cross the valve cover and after burners- Replaced with US federal heat exchanger (79) and simple header that bolted on to the Federal heater boxes and welded a Vanagon long muffler on with tail pipe.
To get the heaters to hook to control valves- you need federal tin on the left side where the heater meets the control valve and cut the heater booster tube hole thru the tin on left side and a new skid tin (below the exhaust) drivers side..
The right side all fits. |
Don't step in any! |
Posted: Wed May 16, 2018 5:28 am Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
Gentlemen?
(And Mrs Gentlemen?)
Any other views on this?
Its a 1st January 1978 cali bus and I'm pretty sure its with oval ports. Its pretty rusted up down there and I'm working my way through without sheering the studs.
I just want to know if I can strip off the whole cali exhaust and HX's and fit UK ones, ports to tail pipe. New lower engine tin of course - but the old tin is missing anyway along with the thermostat.
Anyone know where I can get a left side under-engine Tinware?
Many thanks |
Zed999 Samba Member
Posted: Wed May 16, 2018 12:13 pm Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
Yes you can. You need a pair of heat exchangers an exhaust and tailpipe. If you use JK in the uk they have good quality stock earnst exhausts. Avoid the Jopac ones. |
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Wed May 16, 2018 12:41 pm Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
That's the setup I'm ruining on my 78. Much simpler/better system imo.
_________________ 1978 CEII Get-away hightop |
Posted: Wed May 16, 2018 2:39 pm Post subject: Re: '78 Westy exhaust - can I swap from US spec to EU ? |
Now that looks a lot easier..
The Cali setup looks like spaghetti junction!
Many thanks and I’ll be off to JK for the bits. |
