fuel pump
Page: Previous  1, 2
Floating VW
Floating VW is offline
PostPosted: Fri Apr 07, 2017 7:36 pm    Post subject: Re: fuel pump Reply with quote
A little bit too high will just cause the air/fuel ratio to go rich, leading to excessive fuel consumption and the problems normally associated with that. But a lot too high will overpower the float valve in the carburetor and dump raw fuel down the manifold and into the cylinders, washing the oil off the cylinder walls and chewing up the piston rings.
Most ACVW carburetors like around 2-3 psi of fuel pressure. I use a Holley fuel pressure regulator to keep my Dells at about 2.5 psi. In my experience, they start to run rich at around 5 psi, and nasty things start to happen north of 7 psi. Some of the cheaper aftermarket fuel pumps have been known to put out as much as 10 psi. Effin' scary, man!
"It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works."
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Fri Apr 07, 2017 9:23 pm    Post subject: Re: fuel pump Reply with quote
sammywells wrote:
But what will it do if the fuel pressure is high
Send that pump back to CIP-1 and buy this-
Shameless plug. Laughing
https://www.thesamba.com/vw/classifieds/detail.php?id=2032158
On a serious note, these Pierburg square top fuel pumps were the best made for generator powered bugs. They simply work and last for decades if they are used on a daily driver. I've rebuilt ton's of these Pierburg pumps with NOS rebuild kits. They need no additional shims or grinding of push rods. Bolt it on and enjoy 3psi of fuel pressure. I run restored Pierburg pumps with NOS fuel rebuild kits on all my VW's.
If your fuel pressure is too high, it will overcome your fuel shut off valve inside the carb causing all kinds of havoc.
The Samba member since 2004.
Frodge
Frodge is offline
PostPosted: Sat Apr 08, 2017 4:22 am    Post subject: Re: fuel pump Reply with quote
I have two OEM kits on hand. I also have the pretension tool that is set to 13.5mm. A nice guy from Germany was able to get the parts and build the tool for me. Is it necessary to remove the check valve? Is that still available? Is it fragile or should I just leave it alone? Do you check the inlets and how? Thanks.
Cusser
Cusser is offline
PostPosted: Sat Apr 08, 2017 7:39 am    Post subject: Re: fuel pump Reply with quote
I can't answer the above questions. But I can say that the fuel pump rebuild kit I bought a few months ago DID include the check valve, and I did install it on mine. Note that this rebuild kit had too-strong of spring so my fuel pressure was too high, until Bill (wcfvw69) provided a used spring for me to use.
When I rebuilt my fuel pump, I didn't know that the spring from the old pump diaphragm should be swapped over, and I just discarded that as the diaphragm was rock hard. Now I know.
sammywells
sammywells is offline
PostPosted: Sat Apr 08, 2017 12:18 pm    Post subject: Re: fuel pump Reply with quote
So i can just swap out the spring from the old pump. Would it be best to just use a tee and a gauge to check my pressure to see it there is a problem first before tearing into a new pump.
calvinater
calvinater is offline
PostPosted: Sat Apr 08, 2017 1:14 pm    Post subject: Re: fuel pump Reply with quote
Yes
"Albatross"!
Cusser
Cusser is offline
PostPosted: Sat Apr 08, 2017 2:12 pm    Post subject: Re: fuel pump Reply with quote
Yes.
sammywells
PostPosted: Sat Apr 08, 2017 5:11 pm    Post subject: Re: fuel pump Reply with quote
Thanks for the info.
sammywells
PostPosted: Tue May 23, 2017 3:40 pm    Post subject: Re: fuel pump Reply with quote
Ok, when you say swap out the spring, you are talking about the big one that goes up against the diaphragm.
Page: Previous  1, 2
Page 2 of 2
