agon.parts Samba Member
Joined: August 21, 2010 Posts: 269 Location: Central Coast, CA
Posted: Thu Apr 06, 2017 10:18 am Post subject: Syncro Locker Console | In Progress |
Hello All,
I am consolidating this into its own topic so that it doesn't overwhelm the "3D Printing Vanagon parts" topic.
Below are snippets from the conversation:
Pcforno wrote: |
If you want a tougher project- do the syncro locker console. There's a big need as they get cracked and there's a lot of volks doing 2wd to 4wd conversions, as syncros become less available |
forrest.whitmore wrote: |
Pcforno wrote: |
Do you have a picture of this? |
Pcforno wrote: |
This thing. You might even be able to sell them on van cafe or the like as they're in pretty high demand
RaraBlacksheep wrote: |
Pcforno wrote: |
How complex is the back side? I've been looking around since you mentioned it and haven't found a photo yet. From the front, that looks like an easy piece to make. |
Pcforno wrote: |
Here ya go. The light up plastic thingy would need to be made too
Is that your part? Would you be willing to lend/rent it? I'd need it a week, tops, depending on how the day job is going.. |
Pcforno wrote: |
Yeah sure- there's some weird extra plastic on the sides and it doesn't have the little plastic picture. I'll see if I have the center part somewhere. PM me and I'll send it your way |
Pcforno wrote: |
Gotcha. Is it just the brown plastic that the knobs go onto, or the entire assembly? |
Pcforno wrote: |
How about shipping it West to CA and I'll ship it North to OR?  |
Pcforno wrote: |
Forest- I'm fine with sharing! I already replied to a PM by black sheep so I'll send it his way (he's in cali too) and then he can send it yours too. One thing to work on would be the inserts in the panel. One is a simple rectangle clear plastic that acts as a light diffuser onto the knobs. The other is that picture of the van with 3 leds to indicate locked status. I don't have a spare one of these- I wonder where we could find one? |
Pcforno wrote: |
Sounds good! It looks like it would be a fairly straight-forward object to 3D model.  |
And oops, yeah I need to update my profile. Took a job in SoCal a while ago, though I miss the heck out of Oregon..anyway I'm going to give modeling it a crack but since I've got the equipment, why not scan it too?  |
Definitely scan it! FARO? Where in SoCal? I might need to stop by to scan some stuff...  |
PM'd  |
Almost done!
dkoesyncro wrote: |
WTF👊👏🍻, you did it!! |
Looks good!! Did you find one to copy or did you do that all by eye? Coordination fell through on the loaner so I never wound up with the original to scan.. |
dkoesyncro wrote: |
Yea! I had some free time last nice, so I tried to get as much done as I could! Thanks for letting me borrow it!
dkoesyncro (above) let me borrow his for a bit. I just got it on Monday  |
I just tested what I modeled before. The resolution (low) of the print is mainly for testing the geometry. I have made some slight revisions to the design, but for the most part it's 98% sorted out!
What about the knobs? Are those hard to come by? |
Pcforno wrote: |
Looks great!
Knobs are easily available but the plastic illuminated picture would still need to be made |
Pcforno wrote: |
Looks great!
Thanks!
Oh okay, that's good to hear. Yea, I'm looking into the plastic graphic part. |
I was looking at a diagram of the panel's assembly and it looks like there's another panel behind this one that holds the knobs, etc.? Does anybody have a picture of how these two interface? |
Pcforno wrote: |
If you look at the original you will see 4 screw holes. That's the whole way it attaches |
Zeitgeist 13 wrote: |
There's a stamped steel bracket which holds the switches behind the panel.
Perfect! Thanks for that. Are these relatively easy to find, scrap-wise? I would like to test the fitment eventually, unless there's a Syncro owner nearby that would like to meet up at some point.  |
Nothing Syncro specific is easy to find. |
unibagel wrote: |
I don't see why the stamped steel mount couldn't be a well designed 3D plastic part as well.... |
unibagel wrote: |
Yea, that would be the next best thing. It would be just as easy to model as the other. The grounding points (I think that's what they are) would just have to tie back into the dash.
Does anybody have one that they are willing to share? |
Pcforno wrote: |
Looks great!
I got the graphic designed and sourced.
Pcforno wrote: |
Awesome! Did you see on he back the way the clear plastic attached to the design has fittings for the illumination bulbs? |
dkoesyncro wrote: |
Forrest,
That looks spot on! Somewhere, probably on the samba I seen an LED lit panel that was a personal retro fit that really cleaned up the original wiring/lighting in the back.
I can send you the steel panel if you want, LMK |
_________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
www.print.agon.parts |
dobryan Samba Member
Joined: March 24, 2006 Posts: 12961 Location: Brookeville, MD
erste Samba Member
Joined: March 29, 2013 Posts: 888 Location: San Francisco
Posted: Thu Apr 06, 2017 10:27 am Post subject: Re: Syncro Locker Console | In Progress |
Nice work! Looking forward to seeing the finished panel. |
Bman Samba Member
Joined: April 28, 2005 Posts: 891 Location: South Coast, Oregon
Posted: Thu Apr 06, 2017 1:46 pm Post subject: Re: Syncro Locker Console | In Progress |
Pcforno wrote: |
Thanks! Yea, I'm still working on that portion of it. I am working on the transparent piece and the fittings for the bulbs. I want to simplify the design further though.
dkoesyncro wrote: |
Forrest,
Thanks! I found a few posts that offered some insight on the lighting. I'm going to be redesigning it and placing upgraded LEDs. Would you happen to know what voltage is going to the stock lighting on the panel?
I may need the steel panel at some point. Let me try to sort out the front panel first. I'll let you know.
erste wrote: |
Thanks! Same here!
Bman wrote: |
Way cool and thanks.... |
Thanks and you're welcome. _________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
GoWestyYoungMan Samba Member
Posted: Thu Apr 06, 2017 5:07 pm Post subject: Re: Syncro Locker Console | In Progress |
I will definitely buy one when you have it ready for sell. _________________ 1986 Syncro Conversion |
Pcforno Samba Member
Joined: October 14, 2014 Posts: 567 Location: Santa Fe, nm
Posted: Sat Apr 08, 2017 6:36 am Post subject: Re: Syncro Locker Console | In Progress |
Yup I'll buy one too!
Will the texture and color be difficult to replicate?
Really nice job and a great service to the community! Hats off! |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 10867 Location: Port Manteau
Posted: Sat Apr 08, 2017 12:50 pm Post subject: Re: Syncro Locker Console | In Progress |
I'd be interested in one, but since I will never own a Syncro, it's just for the opportunity to have a switch panel that fits the dash. I have several push-pull switches in mind.
_________________ Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI?
Oly Bulli
'87 300TD OM606 7mm Myna pump and HX30 |
Posted: Sat Apr 08, 2017 4:08 pm Post subject: Re: Syncro Locker Console | In Progress |
Pcforno wrote: |
I'll be working on the texture in the coming weeks. I don't think it'll be that difficult to replicate. The color on the other hand may be a bit tricky. The brown is always the most difficult to match. It may have to have a black or white base and painted afterwards. Not quite sure yet.
Thanks!
[pic] |
Definitely! Same here. I have a few concepts for us 2WD owners. They most likely will be applicable to Syncro owners too. Post or PM me some more info about the switches you have in mind. I've been looking into them also. _________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
artacoma Samba Member
Joined: January 11, 2014 Posts: 118 Location: Victoria BC Canada
Posted: Sat Apr 08, 2017 4:45 pm Post subject: Re: Syncro Locker Console | In Progress |
[pic] |
the syncro switches are vacuum not electric _________________ Cheers
Rik
86 Syncro Tintop
2.5 Subie
86 Doka
2.5 Subie |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 9995 Location: Abiquiu, NM, USA
Posted: Sat Apr 08, 2017 4:59 pm Post subject: Re: Syncro Locker Console | In Progress |
They're not even switches, they're valves. _________________ See innovative Vanagon accessories at the Vanistan shop:
Hmmm, provincial much?:
Quote: |
"I wouldn't go much on whats written on the samba, they love a "theory" and rarely ask any Europeans what is actually correct." |
Posted: Sat Apr 08, 2017 5:07 pm Post subject: Re: Syncro Locker Console | In Progress |
artacoma wrote: |
the syncro switches are vacuum not electric |
tencentlife wrote: |
They're not even switches, they're valves. |
Yea, yea... The switches will be used on 2WD, not Syncros. _________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
Posted: Tue Apr 11, 2017 5:39 am Post subject: Re: Syncro Locker Console | In Progress |
Awesome work!
Hey I've got the plastic piece that fits behind the console and holds the lights, but the graphics are peeled off- PM me if you need it😀 |
Posted: Tue Apr 11, 2017 8:53 am Post subject: Re: Syncro Locker Console | In Progress |
Pcforno wrote: |
Awesome work!
Thanks. I may have to take you up on that because I have to get dkoesyncro's panel back to him soon. I'll let you know. _________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
Team WorldTour  Samba Member
Joined: September 02, 2010 Posts: 2332 Location: Der Vaterland
Posted: Tue Apr 11, 2017 9:38 am Post subject: Re: Syncro Locker Console | In Progress |
There is a BUNCH of stuff here in Germany..... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan |
Posted: Tue Apr 11, 2017 10:11 am Post subject: Re: Syncro Locker Console | In Progress |
Team WorldTour wrote: |
There is a BUNCH of stuff here in Germany..... |
Send it over  _________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
Posted: Tue Apr 11, 2017 11:30 am Post subject: Re: Syncro Locker Console | In Progress |
Send it over  |
What do you want? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Tue Apr 11, 2017 11:42 am Post subject: Re: Syncro Locker Console | In Progress |
What do you want? |
Anything relevant to this topic would be great. _________________ Forrest Walker Whitmore
AGON
[email protected]
www.agon.parts
FREEBIES
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 424 Location: WestWorld Nanaimo BC
Posted: Tue Apr 11, 2017 4:30 pm Post subject: Re: Syncro Locker Console | In Progress |
UPDATE:
Had some time to work on the texture today.
How does a texture like this fare with the print? Is there any post-process, smoothing etc.? _________________ 1991 Double door pop top conversion |
