slalombuggy Samba Member
Posted: Sat Apr 08, 2017 1:12 pm Post subject: Worlds Fastest Aircooled VW |
Mike Fischer's Ghia, driven by Dan Lawson just went 180.1 mph at the Mojave Mile event. Powered by a 2.7L naturally aspirated, injected Pauter engine running on alcohol. This is now the fastest ACVW of all time surpassing even Hans Dahlbach's monster Bug record of 175 set in Europe in the 90's
brad |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Sat Apr 08, 2017 1:58 pm Post subject: Re: Worlds Fastest Aircooled VW |
Congrats to the team. _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Sat Apr 08, 2017 5:25 pm Post subject: Re: Worlds Fastest Aircooled VW |
Are you talking of any event or just this one? Paradise Express did 191mph in 2001 and 200mph in 2002 in the 1/4 mile. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Sat Apr 08, 2017 10:05 pm Post subject: Re: Worlds Fastest Aircooled VW |
Keith wrote: |
Are you talking of any event or just this one? Paradise Express did 191mph in 2001 and 200mph in 2002 in the 1/4 mile. |
In a "stock" bodied car, not a rail
brad |
Keith Samba Member
Posted: Sat Apr 08, 2017 10:13 pm Post subject: Re: Worlds Fastest Aircooled VW |
slalombuggy wrote: |
Keith wrote: |
brad |
I can see that, your terminology of "worlds fasted ACVW of all time" is what was confusing. What you meant is that it is the "Worlds fastest stock bodied ACVW" , got you. _________________ Formerly known in the forums as "OVALTEEN"
Posted: Sat Apr 08, 2017 10:32 pm Post subject: Re: Worlds Fastest Aircooled VW |
I Don't really consider the rail an ACVW there's absolutely nothing VW in the car, but that's my opinion. The Ghia is going for 200mph + at Bonneville this year on a course that is twice as long as Mojave. Hopefully I can make it down again this year to run something.
brad |
Keith Samba Member
Posted: Sun Apr 09, 2017 6:04 am Post subject: Re: Worlds Fastest Aircooled VW |
I can see your opinion.
Some might argue that since the Ghia has a Pauter engine, that isn't a VW engine, it isn't the fasted ACVW because it isn't doing this with VW power. Just like you say that Paradise Express isn't because isn't using a VW engine either, or body. I guess it is all about perspective. To be clear, I'm not
arguing it isn't the fastest ACVW because of the engine.
Either way, that Ghia is fast as hell and it is a full bodied aircooled VW getting it done, regardless of what's pushing it. A true accomplishment and something to be proud of. _________________ Formerly known in the forums as "OVALTEEN"
Starbucket Samba Member
Posted: Sun Apr 09, 2017 3:45 pm Post subject: Re: Worlds Fastest Aircooled VW |
The question should be is it a real body or a plastic look alike. Those two strengtheners along the top make me wonder. I wonder if the weight is logged for the run. |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sun Apr 09, 2017 5:46 pm Post subject: Re: Worlds Fastest Aircooled VW |
Starbucket wrote: |
I doubt that those are "strengtheners" on the roof.
My guess would be that they work in conjunction with the larger "fins" on the rear fenders to guide the airflow more cleanly over the body. |
Posted: Mon Apr 10, 2017 9:21 pm Post subject: Re: Worlds Fastest Aircooled VW |
Starbucket wrote: |
It's an all steel original body, not fiberglass. The roof rails are not stiffeners. They are there to guide the air straight back off the car and give the car straight line stability. Bob Stahl uses similar rails on his 156mph LSR Beetle and I have seen them on other cars at Bonneville. They seem to be more prevalent on cars that have curved roofs.
brad |
Posted: Tue Apr 11, 2017 6:42 am Post subject: Re: Worlds Fastest Aircooled VW |
Out of curiosity and on a loosely related note, which Karmann Ghia fron end do you suppose is more "aerodynamic", the early original lowlight design or the later highlight model one?
The difference in drag coefficient between the two would likely be very small, but that small difference could possibly translate into a noticable difference in mph at top speed.
(... at least according to the completely uneducated suspicions that I have on the subject, anyway ) |
Posted: Tue Apr 11, 2017 9:27 pm Post subject: Re: Worlds Fastest Aircooled VW |
Surprisingly enough small changes in front ends design don't affect aerodynamics that much. Making small changes on how the car leaves the air are much more important.
brad |
Posted: Thu Apr 13, 2017 4:13 am Post subject: Re: Worlds Fastest Aircooled VW |
^^^ That video of the record run ^^^ is pretty sweet! Thanks for posting the link, John.
(... although I must admit, though, that I'm a little disappointed that you didn't apply some of your usual Photoshop magic filters to the video prior to posting it. )
What would be really sweet is if someone could now post a video of that record run from the driver's point of view.
While I'm sure that there's plenty of science behind all of the little tweeks that go into the fine tuning of everything to milk out the last little bit of performance, it sure seems like more of an "art" than a "science" to me. |
WickedWagens Samba Member
Joined: April 09, 2004 Posts: 190 Location: Carson City, NV
Posted: Wed Aug 23, 2017 10:43 am Post subject: Re: Worlds Fastest Aircooled VW |
The roof rails are to spoil the air if the car gets sideways reducing lift. This is how it was explained to me anyways. They are required at 175 or 200 at Bonneville. _________________ 1968 Ghia Land Speed Car
G/CFALT 106.643 MPH
G/CGALT 113.131 MPH
G/CBGALT 134.606 MPH
G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH
H/CPRO 93.383 MPH
H/CBGC 94.33 MPH
H/CBGALT 101.282 MPH
H/CBFALT 120.591 MPH |
