Dual oil bath aircleaners for weber 34's
Rusted64
Rusted64 is offline
PostPosted: Mon Apr 10, 2017 8:52 am    Post subject: Dual oil bath aircleaners for weber 34's Reply with quote
Like the title states, I want to use dual oil bath air cleaners for my weber 34's (on a 1600 SP engine)
I plan on shortening or removing the snorkel.
wondering if I will need to open them up more to allow for more intake/airflow?
williamM
williamM is offline
PostPosted: Mon Apr 10, 2017 9:00 am    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Crying or Very sad motor size and engine bay pics would help-- I'm doing the same on a bus for the desert, but using stock carb (pic 34) and the dual rubber manifold to a pair of "thing" air cleaners. But having trouble as all my air cleaners point the same way and I need a left side one to do what I want- So good luck with that and mock it up so your cuts aren't fatal to the plan.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Rusted64
Rusted64 is offline
PostPosted: Mon Apr 10, 2017 12:27 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
I get what you're saying about pointing in the wrong directions....
that's why I was going to remove the snorkel where I can spin them around to which ever direction clears the best.
Rusted64
Rusted64 is offline
PostPosted: Mon Apr 10, 2017 12:34 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Kjell Roar
Kjell Roar is offline
PostPosted: Mon Apr 10, 2017 2:35 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Rusted64 wrote:
Some says that the fan will take away air from the right carburator when its pointing that way.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
Brian Anthony
Brian Anthony is offline
PostPosted: Mon Apr 10, 2017 7:00 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Here's the engine in my wife's '67 Convertible where I used modified '65 air cleaners. The snouts were shortened with the base of one side turned upside down to be opposite hand. I had to re-position both snouts and rotate the air cleaners to get them as close to the fan housing as possible.
1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
Iím not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans.
Rusted64
Rusted64 is offline
PostPosted: Tue Apr 11, 2017 7:34 am    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
thats a great set up....
could you explain in more detail (or pix) what you mean by "with the base of one side turned upside down to be opposite hand"
sgmalt46
sgmalt46 is offline
PostPosted: Tue Apr 11, 2017 8:11 am    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
i have used 36hp air cleaners before. no mod's needed.no snouts . Wink
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
Brian Anthony
PostPosted: Wed Apr 12, 2017 7:55 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Picture showing they are opposite hand.
This allows them to wrap around the fan housing. It took four air cleaners to make these two.
1965 Double Cab
1967 Bug, Sedan
Rome
Rome is offline
PostPosted: Sat Apr 15, 2017 2:37 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Removing the snorkels altogether will be the easiest method to get them to fit. You'll end up with a rectangular opening in the side of the air cleaner bottom bowl. You can widen the opening maybe 1/2" on each side to accomodate the slightly larger air intake volume from the 34mm carb throats, then rivet/braze on some cleanly cut perforated metal or other sturdy screen from the inside. Paint eveything semi-gloss black.
Shot of a friend's 1500 engine with 34ICTs and some 36hp air cleaners. Engine has 36hp doghouse-style shroud which enables some extra space compared to the wider stock 1500 or 1600 fan shrouds with the side air outlet snouts. 2 more shots of the air cleaners in my gallery.
Joseph DR
Joseph DR is offline
PostPosted: Sun Apr 16, 2017 6:01 pm    Post subject: Re: Dual oil bath aircleaners for weber 34's Reply with quote
Same here. Except I centered the flange that connects to the carb.
1964 Beetle
