hashmaster3k's 1963 project
Page: Previous  1, 2
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Apr 25, 2017 12:00 pm    Post subject: Re: hashmaster3k's 1963 project Reply with quote
hashmaster3k wrote:
So since its truly not a 1600cc motor what would the previous owner had to do in order to switch it to being considered a "1600cc dual port" motor? Here are more pictures to help with identification.
DPO would have stripped engine to short block and installed DP 1600 parts as needed.
In Stereo, Where Available!
Sharp64
Sharp64 is offline
PostPosted: Tue Apr 25, 2017 12:02 pm    Post subject: Re: hashmaster3k's 1963 project Reply with quote
Case number makes it June of 66. Heads, not case make it dual port which here in the US didn't come until the 1600. Pop off a valve cover and post up the number on the heads. It will tell you if they are 1600 or fairly rare here 1300 DP. Most likely someone rebuilt your motor using the 1300 case and put larger pistons, cylinders and heads on it making it a 1600.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
hashmaster3k
hashmaster3k is offline
PostPosted: Thu May 04, 2017 8:33 am    Post subject: Re: hashmaster3k's 1963 project Reply with quote
Either way, the decklid must be popped open in order to properly cool the engine correct? Instead of doing the pop out decklid? Is it possible to just keep the bottom portion (where the handle is) open with a tennis ball while driving then shut it completely for shows and stuff? Will that be proper ventilation for the engine?
Sharp64
Sharp64 is offline
PostPosted: Thu May 04, 2017 8:47 am    Post subject: Re: hashmaster3k's 1963 project Reply with quote
I've heard different opinions. Being in Colorado I'd guess you'll have less of an issue than here in Florida.
1967 Ghia
hashmaster3k
PostPosted: Thu May 04, 2017 8:52 am    Post subject: Re: hashmaster3k's 1963 project Reply with quote
UPDATE: I finally got the bug stopping! New shoes, drums, springs, cylinders, master cylinder, rubber lines, new reservoir, bearings, and seals all around! I did not bench bleed the master but rather once everything was installed just bleed the brakes about 4 times (including braking a line at the master). Once I started driving I noticed the pedal would start to engage at 3/4 down. I did another brake bleed to get any last air bubbles out and adjusted the pushrod. I went by the "keeping your VW alive" book when adjusting. Loosen the nut, use the bolt to push the rod all the way, then half a turn out and tighten lock nut. All in all the bug brakes much better! Engagement point is a lot earlier, however I am getting a pulsation when braking. I assume this is due to the new brakes wearing in. I think it will decrease once they wear into each other.
Eric&Barb
PostPosted: Thu May 04, 2017 9:04 am    Post subject: Re: hashmaster3k's 1963 project Reply with quote
Pulsing is more likely drum/s are warped a bit. That will smooth out from wearing in the shoes.
When you readjust the shoes in the next week or two, adjust the parking brake for five clicks. There after you need to readjust the brake shoes when you get six clicks of the parking brake.
Page: Previous  1, 2
Page 2 of 2
