Bigginbradley Samba Member
Joined: April 11, 2017 Posts: 14 Location: New Braunfels, Texas
Posted: Tue Apr 11, 2017 7:04 am Post subject: 84 Westfalia Vanagon, dormant for eight years - What to do? |
I recently acquired this 1984 Vanagon camper. It has been unused for eight years but fortunately parked under cover and well taken care of. It has 70,000 original miles. I am a first-time Vanagon owner so please forgive me if any of my questions are elementary. I just wanted to see if there are any recommendations in terms of maintenance due to its dormancy. Everything seems to be running fine other than in it tends to want to die first start of the day. Here is a list of what I have done so far. Just FYI… I have zero mechanical experience.
1. New battery
2. Replaced fuel lines and filters
3. Changed all fluids
4. New spark plugs
5. New distributor cap
6. New ignition rotor
7. New ignition wire set
8. Replaced belts
9. Replace brake hoses |
86scotty Samba Member
Posted: Tue Apr 11, 2017 7:15 am Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
You're definitely going to need tires but it sounds like you've done the basics for rehabbing any vehicle. Does it start? Take it for a drive and see what it needs.
Congrats on your new toy! _________________ 86 Vanagon Westfalia 87k
1998 Ford E350 4x4 camper build
Vans flip flops |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Tue Apr 11, 2017 7:23 am Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Replaced the fuel?
Oh and let's see some pics. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Tue Apr 11, 2017 8:36 am Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Your going to want to flush that coolant, and dispose of properly. Once you get it running check the brakes and wheel bearings.
If the van then proves to be reliable and your brakes and engine are solid, start working on replacing the suspension bushings to improve ride handling and safety.
Yes, drain and replace fuel.
Good Luck _________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
Posted: Tue Apr 11, 2017 9:00 am Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Posted: Tue Apr 11, 2017 9:35 am Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
It starts easy and sounds good. Drives good, stops good. There is a minor squeeking sound coming from the left front that squeaks to the rhythm of the wheels turning. I replaced the tires with the only thing available in order to drive the vehicle back home after purchase. These tires are underrated and will need replacing. I see many folks going Gowesty 16 wheel and tire combo? Thanks for all info. I'm a rookie so this is very helpful. |
Paulbeard Samba Member
Posted: Tue Apr 11, 2017 3:06 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
nice looking rig…you did well. And you're off to a good start with fixes and safety updates. The wheel and tire stickies (especially the tire one) will be worth your time. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Tue Apr 11, 2017 3:08 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
I suppose you have got underneath? I would check the coolant pipes, I believe 84 still used the metal ones and those tend to rust out, switch to plastic ones if they need replacing, you don't want to lose coolant flow! |
Merian Samba Member
Posted: Tue Apr 11, 2017 3:18 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
the best coolant pipes are stainless steel and cost about $500
sounds like you have made a really good find
next thing is to inspect everything carefully, and then get it back on its long-term maint. schedule - goWesty has an entire library full of stuff _________________ .... |
Posted: Tue Apr 11, 2017 4:54 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
This is the only place I could find a hose kit for an 84. This do the trick? http://www.van-cafe.com/1.9l-hose-kit.
Do 16 inch wheels and tire upgrade really improve the ride considerably? |
Merian Samba Member
Posted: Tue Apr 11, 2017 5:25 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
no, but you have a choice of less rubber for a harsher ride, or bigger rolling radius that may eff up your gearing _________________ .... |
Posted: Tue Apr 11, 2017 6:09 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Is there a risk of damaging the manual transmission by moving to 16s? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Apr 11, 2017 6:21 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Bigginbradley wrote: |
FWIW - I have an '84 (with 4X the miles that are on yours).
- The big coolant hoses are original and still quite pliable - so I have never been tempted to replace them.
- The metal coolant pipes have not rusted.
- I still run 14" wheels with an appropriate tire (Hankooks in my case).
All I am saying - do some inspection and thoughtful consideration before to pursuing lots of replacement & 'upgrades'.
BTW - That looks like a very nice van. |
Posted: Tue Apr 11, 2017 6:27 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
All of this good grown up advice is killing me;) I will try to suppress my want for 16s. I would like to fix the rear ac though! |
Chainsaw Samba Member
Joined: August 07, 2015 Posts: 249 Location: Issaquah Washington
Posted: Tue Apr 11, 2017 6:38 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Congrats on the new van! Got my self an 89 with 70k on it not to long ago so wanted to share a tid bit. Wheel bearings! I just did mine, its shockimg how little grease is packed into them stock. Also repack the CV joints. _________________ 89 Westy. 2wd. Manual. |
Posted: Tue Apr 11, 2017 7:34 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Got front wheel bearings packed today. I'm assuming there are no rear wheel bearings? I don't know what a CV joint is but I'll figure it out👊! This forum is crazy helpful. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Apr 11, 2017 7:54 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Nice find! Welcome to the invanity!
Do a lot more research on going to larger wheels. There is plenty here to find and read about it.
Right now just drive it and instead of going to bigger wheels/tires right now invest in a Blazecut to go along with the Fire Extinguisher you are going to buy.
Clean all your electrical grounds. Corroded grounds will effect the running more then you might think.
Perhaps think of upgrading the headlights...you'll find out why!
You say it's been sitting for a a good while I would think about replacing the seals on the brake master cylinder just to know they are new. _________________ This free advice is worth exactly what you paid for it.
Posted: Tue Apr 11, 2017 7:59 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
If it is round and it rotates it has a bearing! _________________ This free advice is worth exactly what you paid for it.
Posted: Tue Apr 11, 2017 8:01 pm Post subject: Re: 84 Westfalia Vanagon / dormant for eight years / what to do |
Chainsaw wrote: |
Congrats on the new van! Got my self an 89 with 70k on it not to long ago so wanted to share a tid bit. Wheel bearings! I just did mine, its shockimg how little grease is packed into them stock. Also repack the CV joints. |
Do not overpack the bearings! That will cause them to heat up. It's a Goldilocks thing...too little is not enough, too much is too much, but there is a just right! _________________ This free advice is worth exactly what you paid for it.
bluebus86 Banned
Posted: Wed Apr 12, 2017 8:50 am Post subject: Re: 84 Westfalia Vanagon, dormant for eight years - What to do? |
if you change tire diameter the final drive ratio is messed up, as small as a 10% change in diameter can really be determental on mountain roads, you may end up down shifting too much. these engines are under powered, the stock gear is set to optimize this, any change may effect this badly.
also 16 inch rims with same diameter tires will not change the final ratio, but you loose side wall cushioning, and you become more prone to rim damage, less off road ability. save the low profile tires for your sports car, not your camper, else you may not be able to go over that rutted dirt road to your camping spot.. dont go for useless bling, think function for camping. now if ypu stay on the highways and camp at a paved KOA camp, then you might consider low profile tires for the cool look, but functioality be damned
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
