wurd Samba Member
Posted: Tue Apr 11, 2017 11:35 pm Post subject: No endplay with 3 flywheel shims |
Hi all,
I'm rebuilding my 36hp, and I'm facing a small issue.
With the original flywheel shims, I have no end play. I ordered thinner shims, but it will not be enough to reach the 0.07mm minimum play.
Is it totally stupid to put a thicker paper gasket.?
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Apr 12, 2017 4:19 am Post subject: Re: No endplay with 3 flywheel shims |
Have you calculated the exact shim size needed? If so, you can purchase a single shim of that thickness from Stoddard for a Porsche 356 engine.
They are the same inner/outer diameters as a 36hp VW. Porsche only used a single shim and is appropriate for our 36hp engines.
This is how I rebuilt mine and several others have gone down this path as well. For a long time, 36hp shims of various sizes were not available |
wurd Samba Member
Posted: Wed Apr 12, 2017 4:54 am Post subject: Re: No endplay with 3 flywheel shims |
Thanks for the info. But it starts at 0.8mm, and it's too big.
I've purchased 3 pcs of 0.25mm shims from Virtanen, but it will be still a little too thick.
With the standard 0.20mm paper gasket, I have something like 0.76mm total play.
So my Idea was to put a 0.30mm paper gasket, 3 shims of 0.25mm, and I will end with 0.11mm of end play. |
txoval Samba Member
Posted: Wed Apr 12, 2017 7:46 am Post subject: Re: No endplay with 3 flywheel shims |
I'm trying figure out why your gap is so tight. Crazy to have only .76mm without shims.
I recommend posting the Vintage Speed section.
Perhaps the flywheel nose should be machined versus a thicker gasket |
wurd Samba Member
Posted: Wed Apr 12, 2017 7:57 am Post subject: Re: No endplay with 3 flywheel shims |
Perhaps the Bearing is thicker than an original.
It's a REPCO bearing at 23mm wide.
Or maybe the guy who cut the trust to 23mm made a mistake.
I really don't know. |
txoval Samba Member
Posted: Wed Apr 12, 2017 8:26 am Post subject: Re: No endplay with 3 flywheel shims |
I would recommend machining the flywheel versus a thicker gasket. You know how much needs to come off and it better to be closer to the minimum end play.
Not sure how available machine shops are in your area, but that's a simple process |
wurd Samba Member
Posted: Wed Apr 12, 2017 9:53 am Post subject: Re: No endplay with 3 flywheel shims |
What about machining the bearing?
What is the risk of putting a thicker gasket? |
txoval Samba Member
Posted: Wed Apr 12, 2017 10:01 am Post subject: Re: No endplay with 3 flywheel shims |
I wouldn't recommend touching the bearing. The case thrust cut has to be exact or the bearing wouldn't fit. It's possible that the bearing flange thickness is causing the issue.
I do not like the gasket period. Another common practice is to use sealant in lieu of the paper gasket.
The paper gasket can get saturated in oil and tear or change its thickness. Either way it leads to leak I believe a thicker gasket would make this worse.
I'm not saying their is anything wrong with the standard gasket...it will work fine as proven over the years. I just wouldn't us a thicker one. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Apr 12, 2017 10:10 am Post subject: Re: No endplay with 3 flywheel shims |
nothing wrong with using a thicker gasket since the ones that come with the kits now are nowhere near the thickness they used to be
Nothing will bad will happen if you go that route.
Make sure there are no burrs, edges etc on the parts to keep from a solid fit.
Been thrashing these 36 HP for over 20 years and have tried nearly everything known to keep them going.
I usually run the single thick shim but this last time it wouldn't work so I used 3 thin shims and on thick gasket, good to go now. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
wurd Samba Member
Posted: Wed Apr 12, 2017 11:39 am Post subject: Re: No endplay with 3 flywheel shims |
60ragtop wrote: |
I usually run the single thick shim but this last time it wouldn't work so I used 3 thin shims and on thick gasket, good to go now. |
I don't know if you're saying right, but it's exactly what I wanted to read.
I will use top quality paper, even if I know that there is so much pressure between the crankshaft and the flywheel that the oik can't damage it. |
Posted: Wed Apr 12, 2017 11:42 am Post subject: Re: No endplay with 3 flywheel shims |
OK is this better reading ? So much for proofreading
3 thin shims and 1 thicker paper gasket. _________________ Rick
tasb wrote: |
sb001 wrote: |
txoval Samba Member
Posted: Wed Apr 12, 2017 12:06 pm Post subject: Re: No endplay with 3 flywheel shims |
There you go, that's the beauty of the forum.
The .30mm gasket will put you close to the maximum allowable end play though.
.07mm to .12mm |
wurd Samba Member
Posted: Wed Apr 12, 2017 12:11 pm Post subject: Re: No endplay with 3 flywheel shims |
I will play with the different gaskets and shims I have to reach as close as possible the 0,07mm. |
