jamtonio Samba Member
Joined: September 08, 2014 Posts: 140 Location: Albuquerque, New Mexico
Posted: Wed Apr 12, 2017 11:10 am Post subject: Tachometers and other auxillary gauges. |
I hope this isn't a repeat topic. I am considering installing this NOS MotoMeter tachometer I picked up. I was thinking above the speaker holes on my dash since I don't have a speaker and no plans on putting one there and I wouldn't have to do any unnecessary modifications. I am curious to see how other people have done simar gauge mounting for tachs, oil pressure/temp, engine temp gauges etc...
Any info one might have about the MotoMeter tach I have would be appreciated as well.
Thanks for your thoughts. Please post photos!
_________________ 1965 Kombi
"The more walking-around money I have, the less I walk around."
-Iggy Pop |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Apr 12, 2017 12:45 pm Post subject: Re: Tachometers and other auxillary gauges. |
Here's a pic of my first 1971 bus. Notice the VDO oil P, oil T, and voltmeter plus the tach in the clock area
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Apr 12, 2017 1:09 pm Post subject: Re: Tachometers and other auxillary gauges. |
aeromech wrote: |
That looks cool. What gauges did you use, especially that tach? _________________ 1965 Kombi
-Iggy Pop |
Posted: Wed Apr 12, 2017 1:17 pm Post subject: Re: Tachometers and other auxillary gauges. |
All VDO cockpit series. Actually you can buy an adapter ring and mount the tach from the back so it looks correct. You can also buy a tach (not VDO) that looks original and matches your speedo. I have one in my current bus.
http://www.justkampers.com/tachometer-type-2-bay-window-1967-1971.html
These guys have good prices on gauges
https://www.egauges.com/SearchResults.asp?Cat=21001 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
The real Curly Samba Member
Posted: Wed Apr 12, 2017 1:33 pm Post subject: Re: Tachometers and other auxillary gauges. |
These are some great ideas!!
Mine has nothing in that spot now, how do I get to it, do I do it from the back or do I pull the gauge panel and slide it out? _________________ 1975 Baywindow Riviera Camper
1931 Model A truck (Model A folks are smart and handsome) |
Posted: Wed Apr 12, 2017 1:53 pm Post subject: Re: Tachometers and other auxillary gauges. |
Thanks for the links...I believe ispwest makes a tach that fits in the clock part of the cluster too. So many choices out there.
I like my MotoMeter tach, and think it could look kinda unique if mounted just right. It may stink up the place too. We shall see. I like the look of the smaller gauges on the lower dash.
I was also looking into outfitting a type 3 clock too on the cluster if my MotoMeter works out....
It's a whole new world for me to obsess about. _________________ 1965 Kombi
-Iggy Pop |
Posted: Wed Apr 12, 2017 1:58 pm Post subject: Re: Tachometers and other auxillary gauges. |
You first have to remove the steering wheel. If it's been on there for the last 40 years that can be a real bitch. I finally bought a special puller so I wouldn't damage the SW. Then you've gotta remove the heater and fresh air levers and that can be a bitch if the plastic rivets are still in place. Once you do that you take off the speedo cable from under the dash and remove the four screws holding in the gauge cluster. Now you can slowly pull out on the cluster but several of the wires will be short so you might need to remove them and try to keep track where they go. Sometimes it's best to take the gauge cluster to the bench and check all the background lights using a test battery while you're at it. Then you mount the new tach and put it all together hoping you got all the wires installed. I usually forget to hook up the speedo cable but that's not too bad once you've done it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Wed Apr 12, 2017 5:45 pm Post subject: Re: Tachometers and other auxillary gauges. |
Quote: |
You first have to remove the steering wheel. |
I installed my VDO tach in the clock hole without taking my steering wheel off. Was pretty easy _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Rodmullet Samba Member
Posted: Wed Apr 12, 2017 6:10 pm Post subject: Re: Tachometers and other auxillary gauges. |
That is a cool looking tach.....here's my solution.....not to everyone's taste, obviously.....it is one piece, 1/8 inch birch plywood, with an L-shaped wooden trim piece glued at the top, a few small screws hold it to the dash bottom, certainly would give away in an accident....
Posted: Wed Apr 12, 2017 7:59 pm Post subject: Re: Tachometers and other auxillary gauges. |
Nice workmanship there bro but who chose the colors? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed Apr 12, 2017 9:17 pm Post subject: Re: Tachometers and other auxillary gauges. |
But how does the tachometer/clock delete plate come out? Does it screw off the back? _________________ 1975 Baywindow Riviera Camper
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Wed Apr 12, 2017 9:30 pm Post subject: Re: Tachometers and other auxillary gauges. |
Nice work by both Aeromech and Rodmullet on the below-the-dash gauges. The only problem I see is that you have to take your eyes off the road for a loooong time to see and focus down that low. I made a funky mount that goes on top of the dash speaker location for 3 gauges and some computer fans for ventilation.
The clock delete pate come right off the back. I flipped mine over and drilled a 2 1/8" (?) hole in it and mounted the VDO tach in it. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Hoody Samba Member
Posted: Thu Apr 13, 2017 12:31 am Post subject: Re: Tachometers and other auxillary gauges. |
To each his own. If your happy with that set up that is all that matters. |
Hoody Samba Member
Posted: Thu Apr 13, 2017 2:23 am Post subject: Re: Tachometers and other auxillary gauges. |
That Tach is not stock. There was no stock tach for a Late Bay. Most people install the VDO tach where the clock resides. I have every gauge there is but they are all hidden. You will see some beyond hidious examples of what not to do. Do not hack your dash board. VDO gauges are dog shit. Spend your money wisely and go with Dakota Digital. The only people that will say the VDO gauges are sufficient for trending are full of shit. They had a hard time opening their wallet and are trying to justify it. The Tach from VDO is good....the rest are not accurate...not even close. |
Posted: Thu Apr 13, 2017 10:08 am Post subject: Re: Tachometers and other auxillary gauges. |
Rodmullet wrote: |
That's very unique! If it's a reflection of who you are as a person, seem like you a interesting and fun person to hang out with! _________________ 1965 Kombi
-Iggy Pop |
Posted: Thu Apr 13, 2017 10:10 am Post subject: Re: Tachometers and other auxillary gauges. |
Hoody wrote: |
Good info, I'll look into the Dakota digital stuff. _________________ 1965 Kombi
-Iggy Pop |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Thu Apr 13, 2017 4:09 pm Post subject: Re: Tachometers and other auxillary gauges. |
my set-up... i used the radioblockoff plate from samba vendor 'werksburg' it fits right in and is stiff enough support the gauges. and i have room for one more if i need it.
the CHT diwn below is held on with 2 sided tape to the underside of the dash and is great. the wheel blocks my view when driving so im not alwaya seeing the blue light but its easy to glance down
_________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Thu Apr 13, 2017 4:47 pm Post subject: Re: Tachometers and other auxillary gauges. |
aerosurfer wrote: |
I love the use of the radio hole!!! I thought about that too, but have not decided yet on gauges. Great use of that space, especially considering all the different options for music systems linking to phones and what not, that do not use conventional car stereo applications. _________________ 1965 Kombi
-Iggy Pop |
Randy in Maine Samba Member
Posted: Thu Apr 13, 2017 6:07 pm Post subject: Re: Tachometers and other auxillary gauges. |
Dakota Digital CHT, OP, and OT under the radio (from Phil) if you want the template to mount them there, I have it.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 13, 2017 6:18 pm Post subject: Re: Tachometers and other auxillary gauges. |
Hey, is that one of those ASPX wide band meters?, do you like it?, how does it behave?, was the wire long enough? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
