TahoeManxter Samba Member
Posted: Wed Apr 12, 2017 3:03 pm Post subject: Trail Riding Manx/Off Road Abilities |
Hello guys and gals. I'm a long time reader of TheSamba.com but this is my first post. I have a question about the Manx and or clones. I have been interested in purchasing a buggy for many years but wanted to ask the group as to the off road abilities of one. I live here in Northern Nevada and would like a buggy for riding around in the mountains and trail riding on tight rocky dirt roads. I also will be using the buggy for a fun around town car and summer cruiser. My question is this; how do your buggy's preform on narrow, steep, rocky dirt roads? I'm not looking for ATV or Quad type capabilities, but will they be able to climb steep hunting roads? Do deep ruts pose much of a problem compared to a Jeep. Can it compare at all to a UTV or Side-by-side? Do they have power to go up steep hills at slower speeds? Thank you all so much for the answers. I appreciate and value the expertise here. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Apr 12, 2017 4:16 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
Probable perform as well as any stock Jeep... Only issue may be ground clearance.... While I like my buggies lowered you may want to have yours raised...
If mine was sitting at "stock VW height" I would have no qualms taking it on basically logging roads and trails suitable for a 4 wheeler (not necessary 4 wheel drive)...
I have street buggy, but also have jeep cause I'm on west side of Sierras love the back country... I know the country, I know buggies capabilities...
GO for it...
wythac Samba Member
Posted: Wed Apr 12, 2017 6:34 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
It can be done. Mine is a swingaxle which limits rear suspension travel and it goes anywhere. Get a later CV axle transaxle and you can really jack it up.
Slower is better for climbing crappy roads. So gearing and tire selection are critical. Spend some time in the offroad forum doing a search on those topics.
I have the lowest gearing R&P and low gears overall in my beetle transaxle to achieve low speeds with tall tires. Many go with a bus transaxle which already has low final drive and gears.
I'd advise seeing if you can find a buggy with a bus transaxle and start there. Good luck! |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Wed Apr 12, 2017 8:11 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
I have had my manx clone for about 15 years, and it has seen quite a few trails. It rides softer than most jeeps, and if you arent trying to go rock crawling, it will go were a jeep can go. It will also perform better on the sand, and are so maneuverable that many times you can squeeze thru obstacles, or go around them
Having said the above, you should be aware that buggies depend on engine rpms to get up hills, and I have found myself feathering and slipping the clutch constantly when going up a steep, rocky, bumpy hill. I recently installed a 5 rib trans in my buggy, and its now more suitable for the above. The advice about gearing is right on. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Wed Apr 12, 2017 10:16 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
A stock 1600 with a stock swing-axle will take you over many rough roads. This setup has been very good for me. Not a lot of HP but good torque for crawling up a rocky road.
With good tires and a skidplate you can have tons of fun and you will be very surprised where these buggies will go.
My friend prefers an IRS bus transaxle. You can get more height with them.
There is a limit to climbing steep hills and you will figure it out after having to back down a few.
1500 single port with IRS
1600 dual port with swing-axle
_________________ My wife said I never listen to her.
Or something like that! |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1051 Location: Portland, OR
Posted: Fri Apr 14, 2017 9:01 am Post subject: Re: Trail Riding Manx/Off Road Abilities |
Wow, great footage of Bruce and Old Red and other buggies!
_________________ 1963 Manx copy
1968 Bus |
Posted: Fri Apr 14, 2017 9:13 am Post subject: Re: Trail Riding Manx/Off Road Abilities |
Thank you all so much for the replies. Everyone echoed what I was hoping to hear and you all have lit a spark in my sole where I must get a buggy sooner rather than later. One more quick question? How well do they flat tow? Does axle type make a big difference in that regard? Pardon my ignorance. I'm humbled by the collective knowledge of this site. |
Posted: Fri Apr 14, 2017 10:48 am Post subject: Re: Trail Riding Manx/Off Road Abilities |
I have towed our buggies for a couple thousand miles, total, over the years. My swing axle buggies tow like they are not there.
They follow very well but you can't back them up. Have to plan where you park so you can pull in and drive out.
doubravsky Samba Member
Joined: July 30, 2014 Posts: 133 Location: Riverside, CA
Posted: Fri Apr 14, 2017 12:13 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
+1 - super easy to tow. Tow bar costs $75 - and if you do get stuck (like I did with RV and had to turn around) - you can just disconnect in like 3 minutes, back up, turn around and reconnect.
I've towed behind my 4 cylinder subaru forester with no problem. |
woodoctr Samba Member
Posted: Fri Apr 14, 2017 2:06 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
Almost any VW based fiberglass car flat tows like there is almost nothing behind you. I've got a kit car set up with a collapsible tow bar which is great. Take my vehicle to where I'm going and ten minutes later my wife and I can split up with no trailer to deal with. I was towing at between 75 to 78 most of the time and still got 25 mpg. with my v6 Hyundai Santa Fe. Just remember, backing up is not a good thing.... just disconnect it as said, piece of cake. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Fri Apr 14, 2017 4:28 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
As others said, no problem. Just make sure if you have a locking steering wheel, that its not locked, make sure parking brake off, and make sure its in neutral. If I stop somewhere, I always check the above in case some joker decides to play a trick. I also have set up the tow bar with safety chains (they dont usually come with them), I think some states require them.
My buggy started as a swing axle, and now its IRS. They both work great, in case you are wondering. |
Bob Elgin Samba Member
wythac Samba Member
Posted: Fri Apr 14, 2017 4:44 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
I tow mine on short trips behind my Vanagon.
One bit of general towing advice... If your tow rig is ever out of your sight on a trip, say at a gas station when you use the head, check to make sure some evil jackass hasn't put your buggy in gear or monkeyed with the towbar. Think of it as a safety check. There are unfortunately people out there who think such things are funny. |
Posted: Fri Apr 14, 2017 7:18 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
To flat tow a buggy its critical that it has fairly light and neutral steering which will follow the tow vehicle and self center after making a turn.
Lots of folks put wide tires on the front of a buggy, mostly for looks. Wide tires increase steering effort and can cause problems with flat towing. Besides having the right width tires, you should also run caster shims under the lower torsion tube, which improves stability and self centering. Alignment, king pin/ball joint condition and steering gear box condition should all be good |
Posted: Fri Apr 14, 2017 9:11 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
I prefer the big tire up front, drives easier for me. And i like the looks better. I have the normal p235r15s, I have in the past towed my buggy from Texas to Colorado in the past, made sure nothing was anywhere near the steering wheel. Oh yah we also bungied the steering wheel works pretty good . _________________ OLD ENOUGH TO KNOW BETTER AND STILL TO YOUNG TO CARE!!!!!
My Build http://www.thesamba.com/vw/forum/viewtopic.php?p=5987690#5987690
My Youtube page
https://www.youtube.com/channel/UCqd2r1Af7uZgqlnxAtMap4A |
Posted: Mon Apr 17, 2017 10:36 am Post subject: Re: Trail Riding Manx/Off Road Abilities |
Excellent info guys. I really do appreciate the replies. Everything that has been said makes me excited and ready to go get my buggy. Now to find the right one... Really what I am looking to do is have a hunting/fishing/camping setup. I currently have an f-350 diesel truck with an overhead camper. I want to be able to flat tow a buggy wherever I go and have that as my off road rig when I get to my destination without having to take the overhead camper off my truck. I am currently looking at a buggy with a 2.2L Subaru engine bolted to a VW bus transaxle. The problem is the buggy slips out of reverse and is also misfiring on a cylinder. The price is only $2,000; does that sound like too much trouble for what it is worth? Apparently it has been sitting for quite a while. |
Posted: Mon Apr 17, 2017 12:56 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
Most buggies that have been sitting are projects. You must decide how much of a project you want.
When reverse pops out, the trans most often needs to be rebuilt. The Subaru motor might be more engine than you need. 1600 VW motors are cheap to maintain and are easy on the trans. $2000 seems like a lot for this one. _________________ My wife said I never listen to her.
Posted: Mon Apr 17, 2017 1:09 pm Post subject: Re: Trail Riding Manx/Off Road Abilities |
I see this in Phoenix. Seems like a good way to go. You buy the motor and trans and off you go. lots of buggies in the $6000 to $8000 price range for sale.
This would get you on the road cheaper than that.
https://phoenix.craigslist.org/nph/cto/6042644652.html _________________ My wife said I never listen to her.
