pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Apr 13, 2017 6:43 am Post subject: Pertronix/Compufire/Tach |
I've run both the Pertronix and the Compufire and found no real noticeable difference between them. (Didn't have a tachometer back then!) After frying both of them - - eventually I got another Pertronix. Now, I have been running points on the Bug's engine and there has always been a slight "miss" going on that bounces the tach needle just a bit. Recently I scored me a distributor that has a Compufire in it so I threw it in the Bug's engine and when I fired it up the tach's needle was bouncing hysterically all over the place!!! Barely steady at all at idle and just plain going crazy upon acceleration!
At first I thought maybe I screwed up the tach or it just lost it but before swapping it, I went back with the points distributor and the wildness stopped!?! Anyone here ever had this situation happening before??? _________________ Some people are so busy being clever they don't have time enough to be wise. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Apr 13, 2017 9:53 am Post subject: Re: Pertronix/Compufire/Tach |
Yeah ... Electronic module had poor ground where mounded to dist points plate... Cleaned area where module mounted and checked ground at dist body and made sure mount screw was tight... No problems after that... But that may not be you problem...
pyrOman Fire Master
Posted: Fri Apr 14, 2017 6:30 am Post subject: Re: Pertronix/Compufire/Tach |
I have them cheap Sunpro tachs from FLAPS in the Dormy and the Bug and both behaved the same way with the Compufire. I will try it in the Plump Truck which has a VDO tach. If it does the same thing then something is amiss with this Compufire when used with a tach, though it works fine as far as running the engine is concerned. _________________ Some people are so busy being clever they don't have time enough to be wise. |
larryducas Samba Member
Joined: October 25, 2011 Posts: 233 Location: Fallbrook, CA
Posted: Fri Apr 14, 2017 8:35 am Post subject: Re: Pertronix/Compufire/Tach |
Put a diode in series with the tach input. This fixed mine. 1n4003 from radio shack is fine. Almost anything works _________________ 71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb |
pyrOman Fire Master
Posted: Fri Apr 14, 2017 11:53 am Post subject: Re: Pertronix/Compufire/Tach |
I had to put one in for the VDO when I got it since it was not only erratic but way off too! I did take the diode from it and tried it with the Sunpro, it didn't make a difference. _________________ Some people are so busy being clever they don't have time enough to be wise. |
tkelley Samba Member
Joined: January 10, 2006 Posts: 1597 Location: Where Pterodactyls crash and burn...
Posted: Fri Apr 14, 2017 11:54 am Post subject: Re: Pertronix/Compufire/Tach |
I had the same problem with my compufire and
the needle bouncing with the engine running. I tried
using inline diodes, checked and cleaned grounds,
all sorts of things...I ended up changing out the coil
and all the problems went away.
Tom _________________ When the sun doesn't rise, we'll replace it
with an H-bomb explosion or a painted jail cell... |
pyrOman Fire Master
Posted: Fri Apr 14, 2017 11:56 am Post subject: Re: Pertronix/Compufire/Tach |
tkelley wrote: |
Tom |
I have a bucket full of'ems! Will try that next, thanks! _________________ Some people are so busy being clever they don't have time enough to be wise. |
pyrOman Fire Master
Posted: Wed Jul 05, 2017 9:09 am Post subject: Re: Pertronix/Compufire/Tach |
I did replace the coil and though it helped, decided to go with points instead of the Compu-Fire diz. Ran bitchen....
Until this happened!
So I bought a fresh Pertronix, just installed it and it fired right up! Sweet!
However, I didn't get to actually drive it until this morning going to work. Though it starts right up, idles fine and runs good, the tach now reads WAY high! Normally at 70 to 75 it read around 3500 rpm and felt like it too. Now with only the Pertronix being different, it reads 5000 rpm! WTF?!?!?!?
Though the difference between the points and the Pertronix might have advanced the timing some, I can't see why that would make the tach reading high!?!? _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Wed Jul 05, 2017 9:47 am Post subject: Re: Pertronix/Compufire/Tach |
Is tach set for 4 cylinder?...
pyrOman Fire Master
Posted: Wed Jul 05, 2017 9:57 am Post subject: Re: Pertronix/Compufire/Tach |
But of course! Everything is as it was and worked fine before this swap. Again, I do suspect the timing needs to be reset now but I just found this out and I'm at work. I will retard it some but can't really check it until I get home and put the light to it.
FWIW, I have the same tach on the Dormy and have ran Pertronix and points without any difference in readings. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Wed Jul 05, 2017 10:47 am Post subject: Re: Pertronix/Compufire/Tach |
put a diode in the tach sending line, worked for me _________________ 71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Wed Jul 05, 2017 12:22 pm Post subject: Re: Pertronix/Compufire/Tach |
What you are trying to do with a diode is to kill off "ringing" which is a part of the way the coil works when it fires. The tacho counts 2 pulses instead of one sometimes. When I built my own rev counter the first version claimed that idle was 60K RPM because of the ringing.
Changing coils or condensers will change the ringing .
Another route is to filter with e.g. a 1000 ohm resistor from the coil -ve to tacho input terminal and then a 0.1 microfarad capacitor to ground across the tacho input (e.g. a condensor).
Tacho--------- 1k resistor ----------- coil -ve ----> contact breaker or module
Capacitor (condenser)
Chassis
In rhe end I built this circuit into my tacho sender computer.
This filters out the ringing. _________________ Ancient vehicles and vessels
pyrOman Fire Master
Posted: Thu Jul 06, 2017 7:02 am Post subject: Re: Pertronix/Compufire/Tach |
Well, how 'bout them apples?!?
I think I did mentioned that once at work I did retard the timing a bit. Doubt that really "fixed" the problem but apparently the thing just calibrated itself!
On my way home from work it went back to normal! Idled fine and readings at speed were correct. Still wondering why this happened?!? Unlike the "jumpy" issue I had before with the Compu-Fire, the way high readings yesterday were steady as could be. _________________ Some people are so busy being clever they don't have time enough to be wise. |
