eugenesantos Samba Member
Joined: July 15, 2015 Posts: 29 Location: Wakefield, RI
Posted: Thu Apr 13, 2017 7:55 pm Post subject: broken sliding door window |
I got a 2003 Eurovan MVC with a broken sliding window on the passenger slider door. The window has a screen. The stationary window is fine. A few questions.
1. Are non-screen windows compatible with my model? I have found sliding windows, but not one with a screen.
2. Can I replace just the window or do I have to replace the whole window unit?
Been looking here on Samba, eBay, and calling junkyards, etc. Any leads are appreciated.
Thanks. |
mvaska Samba Member
Joined: February 26, 2015 Posts: 135 Location: United States
Posted: Fri Apr 14, 2017 6:14 am Post subject: Re: broken sliding door window |
I _believe_ that the only difference between screened and non-screen sliding window glass is the location of the release. I'll measure both tomorrow and confirm. If true then you could get any GLS/MV sliding glass (fairly easy to find) and just epoxy the release back to the correct location. |
Posted: Fri Apr 14, 2017 8:11 am Post subject: Re: broken sliding door window |
mvaska, that would be good news. Thanks for looking into it. |
rcowan Samba Member
Posted: Fri Apr 14, 2017 9:41 am Post subject: Re: broken sliding door window |
Westy windows pane width is different than MV/GLS windows. Take a look at images of westy vs MV/GLS and it will become very obvious to you. I never noticed until ours broke also. |
rcowan Samba Member
Posted: Fri Apr 14, 2017 9:43 am Post subject: Re: broken sliding door window |
I ended up buying an MV slider since it fits the door, just to block the hole until I could get a westy slider. The overall dimensions are the same. I still have the MV slider if you are interested..... |
57 Zwitter? Samba Member
Joined: November 07, 2003 Posts: 418 Location: Boston, Mass.
Posted: Wed Apr 19, 2017 9:06 am Post subject: Re: broken sliding door window |
If you get a complete Westy weekender window assy. I will buy your good stationary pc of glass. I just broke my Weekender stationary pc of glass (drivers side) and have a good sliding pc. Let me know. Thanks! |
