Braukuche Samba Member
Posted: Mon Apr 24, 2017 5:31 pm Post subject: Re: Ken Virgin twin carb kit for a 36hp engine |
I'm running dual 28 PCIs on my Rethwish kit. No issues other then those related to the ginky linkage. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Wed Apr 19, 2017 7:55 pm Post subject: Re: Ken Virgin twin carb kit for a 36hp engine |
Nice setup you have there.
I have had similar problems with my dual 28PCI setup. However, my carbs were worn. I am now using fully rebuilt carbs and now getting things far closer to what I want. My problem is now my linkage, which I hope to sort in the next few weeks (it is not allowing the carbs to close fully as it is sticking). I am confident that once I sort that I will be able to obtain a good idle speed.
My carbs have been rejetted. See https://www.thesamba.com/vw/forum/viewtopic.php?t=670827&highlight=jetting
Richard _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
rlmartinez Samba Member
Joined: December 09, 2005 Posts: 233 Location: Whittier, CA
Posted: Mon Apr 17, 2017 10:41 am Post subject: Re: Ken Virgin twin carb kit for a 36hp engine |
Looks great! _________________ 54 Bug
56 convertible |
Dave Becker Samba Member
Joined: October 16, 2003 Posts: 147 Location: Australia
Posted: Mon Apr 17, 2017 3:36 am Post subject: Ken Virgin twin carb kit for a 36hp engine |
Don't know a lot about this kit, I was told it was available in Australia in the late 50's It was a kit made by Ken Virgin a VW racer from South Australia.
It uses 36hp Solex PCI carbs, the left carb is modified so the throttle linkage is on the right of the carb so it can attach to the linkage located behing the fan shroud.
I have it running but having a little trouble getting the idle right, I soldiered up the holes in the throttle butterflys and this has helped, I am running 50 idle jets and will try some smaller ones as the mixture screws run best turned almost all the way in.
I would be interested in hearing what others have found running twin PCI's _________________ FAHRVERGNUGEN;
Description of a pleasurable sensation,
Experienced when a car and it's driver are in mutual harmony, A unique driving experience, Pleasure, Satisfaction,
A feeling experienced by Volkswagen Drivers.
