swharris Samba Member
Joined: September 10, 2010 Posts: 502 Location: N. Orange County
Posted: Mon Jun 25, 2018 12:42 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
Whoa, hold on cowboy. Are you binding your own carpet? Are you renting that? And if not how often does that get used?? lol. That is cool!
Navydave73 Samba Member
Joined: March 09, 2017 Posts: 414 Location: Alta Loma/Los Angeles
Posted: Mon Jun 25, 2018 11:47 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
[quote="swharris"]Whoa, hold on cowboy. Are you binding your own carpet? Are you renting that? And if not how often does that get used?? lol. That is cool!
I have had that sewing machine longer than my kids. Ive reupholstered Smokey and The Bandit Trans Ams, my Jeep seats, Several Buses, and now a Bug. The biggest thing was a Sunbrella cover for our IBEW Local 18 22ft BBQ Trailer.
I don't use it that much, have thought many times about selling it but I always seem to find something to do with it.
"Native Americans believe that working with Hydes and Pelts releases the soul." Will Ferrell-Blades of Glory.
The Binder attachment is new, thought it would be easy but it is not! |
Posted: Tue Jun 26, 2018 8:21 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
Navydave73 wrote: |
Sewing/ upholstery is one skill I've never attempted. Wish I had. My mom is quite good and an amazing quilter. I guess I should give it a try, but I've got enough irons in the fire. Ha. |
Posted: Fri Jun 29, 2018 11:09 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
Sure would be nice to start cutting some costs. Instead of $50 trim rings around the heater outlets, I’m going to attempt to bind the opening. I still suck with this attachment.
Using a round hole punch for the corners of the 2” x 3” opening and then cut the straight edges with a carpet knife.
Size looks good on this scrap piece
YIKES!!!! This looks like @#$%.
OK, second try is a little better but still not great. Believe it or not, I’m usually pretty good with this machine but the carpet binder is kicking my butt
on another note, my daughters buddy had this billabong backpack on her yesterday when we were at my sons water polo game. I was looking at it, pretty neat color combinations, even has the white piping. Headed to the upholstery shop today to see if i can find a match. This would look sweet in my Dove Blue/Arctic Bus.....just sayin!
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Jun 29, 2018 11:15 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
Navydave73 wrote: |
thank you....Obsessive Compulsive Disorder is my special power and I must use for the good of the universe. over the years I have also learned to push the "F%$@ It" button and move forward. We can analyze forever and never get anything done, but at some point we gotta aim for 80% and launch the damn plane. |
If you think y'all have it bad, my OCD gets trumped by my ADD on a regular basis. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Jul 02, 2018 4:26 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
Using the faded original panels for a template to start.
Pretty wrinkled and shriveled. Almost 2 inches smaller in each direction
So I’m at the upholstery shop and i had a sample of the original door panels. I ran into another customer that seemed very interested in what i was trying to do. Turns out, he is a professional custom upholsterer. He gave me some tips on how to get back the factory pleats without heat seam equipment.
Posted: Mon Jul 02, 2018 4:29 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
This is my first shot at it, driver side rear panel. I cut 5/8” strips of 1/8” panel board from Home Depot and glued them 1/4” apart. Then, after tons of glue, I used a screen door tool to press in the white vinyl into the gaps between the strips. First shot......OK.....learned a few things to try different.
Posted: Mon Jul 02, 2018 4:33 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
Here is the second one. Much better. I left enough material around the edges for me to grab and wrap around. I also used glue instead of trying to staple the piping at the same time. I made some chalk marks to make sure the white vinyl was in the correct place and had my boy hold the material while i glued and rolled the seams with the screen door tool. The first time, i set the white vinyl on there and tried to stretch the material into the valleys and it did not stay. This time, i rolled each seam into the gap, smoothed the top of the next strip, and moved on. This is the way i will be doing it for the front panels. I am going to wait until i get the door kits with all the rubber trim so we can put them back together to ensure all of my holes are in the right place for the door handle and window roller. |
Posted: Mon Jul 02, 2018 4:35 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
The bottom looks crooked how the hell did that happen
This is the rear seat i bought with original upholstery. 11 1/4” gap between the pleated areas and the pleats are 2” apart.
Here is the top panel for the bottom of the seat.
67ctbug Samba Member
Posted: Sat Jul 28, 2018 6:36 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
The paint job looks wicked great! And you’re doing your own upholstery... awesome! _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Tue Aug 14, 2018 4:26 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
The bottom seat
Laying out the lines for the pleats. Sewn pleats are technically not correct for a 60, but neither is Anthracite paint.
Poser shot with the seat belts!
Steering wheel. My boy remolded this steering wheel over the last few months. He used POR15 putty and spent a lot of time sanding and filing. We just painted it with single stage PPG that we matched off the WW spray can Silver Beige. LOOKS BEAUTIFUL!!!!! The 60-61 rebuilt wheels go for $700+ we saved a ton of money and it looks great. Now he is working on my buddy’s oval window wheel
Posted: Tue Aug 14, 2018 4:32 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
I had original upholstery for all of the seats except the upper fronts. I borrowed an old seat from my buddy and used its seat cover for a template. It sucked, the sides were awful and you can see they don’t fit correctly. I re-did it on the passenger and its even worse. I’m making a template from scratch now, pics to follow |
Posted: Tue Aug 14, 2018 4:35 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
Bleeding the brakes. Fluids are going in, its becoming a real car. My boy crawled underneath the rear and held the tailpipes in making engine noises. What a dork! Love that kid
Posted: Tue Aug 14, 2018 4:42 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
Here we are making the first front door panel
Decided to grow up and use real glue sprayed in one of my old primer guns instead of the expensive spray cans.
Spraying the backside while Logan holds the material tight.
Using the screen roller tool to press the vinyl down into the valleys between the strips of door panel board
Important to make sure the vinyl doesn’t stick to the top of the next strip before i push it down into the valley. Otherwise, this stretches the material and causes it to pull away making the seams less pronounced. That’s what happened on the first rear panel.
Posted: Tue Aug 14, 2018 4:45 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
Finished product. I spent a lot of time making a perfect template so i can duplicate for the driver side and my friends bug. I put the holes for the clips to the rear of the holes on the door. This is a mistake because the clips barely fit in where the material folds over and the piping staples. I will move the holes on the door panel directly under where the holes would be on the door next time. I didn’t have any panels to look at while i was doing this and it didn’t occur to me until i was laying in bed that night. Doh!! |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Aug 14, 2018 11:02 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
Pretty amazing how much this project has progressed in such a short time . . . I just went back to take another look at the first page of this thread . . . GREAT JOB!!!!! _________________ Jesucristo es mi Señor y Salvador! |
Posted: Wed Aug 15, 2018 6:42 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
57BLITZ wrote: |
Pretty amazing how much this project has progressed in such a short time . . . I just went back to take another look at the first page of this thread . . . GREAT JOB!!!!! |
Thank you for the compliment. It is cool to see it so close to being complete |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Wed Aug 15, 2018 8:22 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
Nice work on the panels and seats.. - Did you make that table pictured above out of Trex? I have the same colored Beach Dune Trex on my deck and like that idea. _________________ 1963 Ragtop Bug
Posted: Wed Aug 15, 2018 12:34 pm Post subject: Re: 1960 Ragtop Resurrection from Baja |
EMPIImp69 wrote: |
Nice work on the panels and seats.. - Did up make that table pictured above out of Trex? I have the same colored Beach Dune Trex on my deck and like that idea. |
No, its just a folding camping table. I plan to build a shop for my woodworking and upholstery equipment. #1 on the list is a taller, counter height upholstery table wide enough for large rolls of fabric 65” x 8ft or so....have to see how that shakes out. |
Jackrobbo Samba Member
Posted: Fri Sep 14, 2018 12:36 am Post subject: Re: 1960 Ragtop Resurrection from Baja |
Amazing build so far I will also be getting a Baja conversion and unbastardising soon. |
