VW engine, porsche trans question
Anthrax
Anthrax is offline
PostPosted: Fri Apr 21, 2017 3:12 pm    Post subject: VW engine, porsche trans question Reply with quote
I have a 1974 Porsche 914.
Current setup is a 1974 Bus engine and the original Porsche trans.
The trans is trashed and its a ridiculous price to rebuild.
Is there a VW trans that is a side-shifter that I can put into this build?
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sat Apr 22, 2017 3:37 pm    Post subject: Re: VW engine, porsche trans question Reply with quote
Even if you could get clutch, starter and linkage hooked up and trans supported you have 4 reverse gears and one forward! There are lots of rusted out 914s with ok trans. Here's a $600 on SAMBA but I've seen them int $150-250 range.
https://www.thesamba.com/vw/classifieds/detail.php?id=2030810
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
raygreenwood
raygreenwood is offline
PostPosted: Sat Apr 22, 2017 4:32 pm    Post subject: Re: VW engine, porsche trans question Reply with quote
Yes....that is correct. The flywheel issue is easy. The only one that uses a different flywheel is really the 2.0.
The problem as noted is that you will either have to flip the differential which is not always possible.....or run the trans upside down to get four forward gears.
Also....no side shifts among vw trans.
One positive side of a flipped trans...is that for tail shift ....the hockey stick would now be on the correct side....in the lower position.
The only VW trans that is similar in dimensions, has the same CV flange and the tail/hocky stick on the bottom.....is the VW type 4 trans.....the 004. Sadly...they are rare as hens teeth, have "0" parts availability, cannot be run upside down and the differential cannot be flipped.
As noted.....find a good used 914 trans. Ray
reservoirdubs
reservoirdubs is offline
PostPosted: Fri Jan 26, 2018 4:05 pm    Post subject: Re: VW engine, porsche trans question Reply with quote
Can anyone tell me which, if any, VW flywheel/pressure plate combos will work with a 901 transaxle? I have a 1972 914, and am wanting to use (if possible) a VW Flywheel/pressure plate I have on hand.
Any advice would be greatly appreciated.
1960 Canadian Custom
1970 Double Cab
1972 Porsche 914
Bleyseng
Bleyseng is offline
PostPosted: Sat Jan 27, 2018 12:35 pm    Post subject: Re: VW engine, porsche trans question Reply with quote
I don't think any VW bus flywheels work as the ring gear won't line up with the starter teeth. Tons of used flywheels out there for a 914 so check on the 914World.com site
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
Wolfgangdieter
PostPosted: Sun Jan 28, 2018 1:38 pm    Post subject: Re: VW engine, porsche trans question Reply with quote
A VW flywheel (except '72 up Bus T2 and 411/412) has a large center gland nut and 4/8 dowels to hold flywheel to crank. The 914 (and T4 engine VW above) all use 5 bolts to mount it to the crank. 914 flywheels are forged so strong and are not that difficult to locate.
