Frodge Samba Member
Posted: Fri Apr 21, 2017 4:28 pm Post subject: Checking oil oddity. |
My car has sat since December. Went out checked everything, pulled the dipstick out without wiping and reinserting and the oil level was at the bottom line. Wiped, reinserted and it is 3/4 the way up to the top line. Why the difference, I have noticed this in the past as well. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Fri Apr 21, 2017 5:38 pm Post subject: Re: Checking oil oddity. |
dipstick probably wasn't down all the way to begin with. |
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Fri Apr 21, 2017 5:41 pm Post subject: Re: Checking oil oddity. |
Other possibility?
Gas leaking into crankcase.
Take lighter to dipstick to see... But be careful! _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.) |
Frodge Samba Member
Posted: Fri Apr 21, 2017 6:14 pm Post subject: Re: Checking oil oddity. |
Why do you suspect gas? |
mark tucker Samba Member
Posted: Fri Apr 21, 2017 7:07 pm Post subject: Re: Checking oil oddity. |
pressure differential. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Fri Apr 21, 2017 8:35 pm Post subject: Re: Checking oil oddity. |
When the engine runs oil level drops below the end of the tube the dipstick is in, due to oil being pumped up thru the cooler and bearings. When engine is turned off the oil level in the sump rises back up over ten or fifteen minutes when oil drains back, but top of tube is sealed so an air pocket is trapped in there. Pull the dipstick out and the air is no longer sealed in there, and oil level in the tube rises up, so when you put dipstick back in it shows higher. _________________ In Stereo, Where Available! |
goober Samba Member
Posted: Fri Apr 21, 2017 9:59 pm Post subject: Re: Checking oil oddity. |
"Why the difference..."
I get this too. I have to overfill a little to allow for my coolers and lines. That drives the full mark even further up the dipstick.
I find if I rock the dipstick back and forth 4-5 times and then check, I get a more predictable reading. |
gingergypsy Samba Member
Joined: April 28, 2016 Posts: 129 Location: Yosemite Valley
Posted: Sat Apr 22, 2017 1:15 am Post subject: Re: Checking oil oddity. |
dipsticks are weird sometimes. for some reason or another I've found the disticks to be terribly unreliable when cold. a few times when the engine was cold i would check the dipstick like 10 times and it would tell me i was at the half mark which i knew for a fact was not the case. i started checking when hot and i have gotten more consistent readings. _________________ Royal Red 1970 Beetle "Elizabeth Bathory"
Currently residing in yosemite valley with Elizabeth, if you are in the park come say hi! |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Apr 22, 2017 5:48 am Post subject: Re: Checking oil oddity. |
Eric&Barb wrote: |
When the engine runs oil level drops below the end of the tube the dipstick is in, due to oil being pumped up thru the cooler and bearings. When engine is turned off the oil level in the sump rises back up over ten or fifteen minutes when oil drains back, but top of tube is sealed so an air pocket is trapped in there. Pull the dipstick out and the air is no longer sealed in there, and oil level in the tube rises up, so when you put dipstick back in it shows higher. |
That must be quite the dipstick seal to hold pressure for for months. |
Frodge Samba Member
Posted: Sat Apr 22, 2017 5:50 am Post subject: Re: Checking oil oddity. |
Showed fine this am.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Apr 22, 2017 7:14 am Post subject: Re: Checking oil oddity. |
Mine does it too. I agree, pressure differential. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
garyt Samba Member
Posted: Sat Apr 22, 2017 8:08 am Post subject: Re: Checking oil oddity. |
You just always have to do it three or four times to get a sure reading. |
Posted: Sat Apr 22, 2017 8:25 am Post subject: Re: Checking oil oddity. |
iowegian wrote: |
Seal plus a little oil will hold a tiny amount of pressure no problem. _________________ In Stereo, Where Available! |
Q-Dog Samba Member
Posted: Sat Apr 22, 2017 8:49 am Post subject: Re: Checking oil oddity. |
I was taught to wipe the dipstick first, then dip it and read it. The first time is never correct. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sat Apr 22, 2017 9:16 am Post subject: Re: Checking oil oddity. |
I'm a double dipper. Never trust the first reading hot or cold.
It's inaccurate. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
andrewwebb58 Samba Member
Posted: Mon Apr 24, 2017 7:00 am Post subject: Re: Checking oil oddity. |
i agree with most of the other folks here...ignore the initial reading you get. its always a good idea to clean the dipstick and re-check _________________ 1974 Super beetle Lime Green 1600 DP (originally my Grandpa's before he passed)
1995 GMC 1500 4x4
2015 Silverado 4x4 |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Mon Apr 24, 2017 7:15 am Post subject: Re: Checking oil oddity. |
Q-Dog wrote: |
I was taught to wipe the dipstick first, then dip it and read it. The first time is never correct. |
This. Who just pulls the dipstick and takes that reading? Do you people not have fathers? Uncles? Anyone who has ever worked on a car before? Its probably in the manual but I've never bothered looking. Pull dipstick, wipe, reinsert, now check level seems to be the all time accepted method of checking oil. In all internal combustion engines. Ever. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Posted: Mon Apr 24, 2017 7:24 am Post subject: Re: Checking oil oddity. |
It is:
The above is from AUG69 OM. _________________ In Stereo, Where Available! |
