VagNaToOtH Samba Member
Posted: Sun Apr 23, 2017 2:09 pm Post subject: ecotec sandrail major issue |
so i get my sandrail all together with the adapter kit they sell at apple tree auto for the 6 rib trans with the ecotec 2.2 and i go test drive it around the block and the flywheel bolts sheer off. i call the company who give me the manufacturers number who agrees to send me new bolts and tell me to torque them to 39 with some blue loc tite which i did.well i get 10 mins down the trail and the thing grenades and sheers all the bolts again and the guy has no idea and nothing to say. can anyone help me out thanks |
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Sun Apr 23, 2017 3:08 pm Post subject: Re: ecotec sandrail major issue |
Get some grade 8 domestic bolts and try again . _________________ Go outside and do something. |
jdcool4 Samba Member
Joined: September 19, 2010 Posts: 98 Location: Temperance MI
Posted: Sun Apr 23, 2017 3:30 pm Post subject: Re: ecotec sandrail major issue |
It looks like it should be torqed to 39 plus 25 degrees i think i did 39 plus a little . If not maybe theres something wrong with there flywheel |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Apr 23, 2017 4:17 pm Post subject: Re: ecotec sandrail major issue |
What are size of bolts..
https://zzperformance.com/ecotec/oem-flywheel-bolts.html
Seems to me first pass is 39 ft-lbs... Second pass additional 25°... According this this web site...
Posted: Sun Apr 23, 2017 5:08 pm Post subject: Re: ecotec sandrail major issue |
so i pulled the motor and my clutch is dam near melted to the flywheel i dont get it it ran and shifted fine for about 15 mins
Posted: Sun Apr 23, 2017 8:26 pm Post subject: Re: ecotec sandrail major issue |
I think you need a stronger clutch. That got really hot. _________________ Go outside and do something. |
Posted: Mon Apr 24, 2017 3:26 am Post subject: Re: ecotec sandrail major issue |
B Ramsey wrote: |
I think you need a stronger clutch. That got really hot. |
you think that would cause it to sheer flywheel bolts ? |
Posted: Mon Apr 24, 2017 6:39 am Post subject: Re: ecotec sandrail major issue |
VagNaToOtH wrote: |
B Ramsey wrote: |
it certainly didn't help. I would have the flywheel resurfaced and install a high HP clutch kit. And use quality hardware. with the right setup, there is no reason for this to be happening. Youre not tryng to do burnouts with 33' tires are you?
let see some photos of what you're working with, to better help. _________________ Go outside and do something. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5389 Location: Holland, MI
Posted: Mon Apr 24, 2017 7:43 am Post subject: Re: ecotec sandrail major issue |
That 39Ft*Lbs of torque figure can't be a stand alone figure. Either it is wrong or there is a torque angle following it up as others have suggested.
That flywheel got so hot I would check it over carefully. You may find surface cracks on it. Small ones radiating from the center to the perimeter shouldn't be an issue, but any that are circular can be the death of a flywheel. If all looks ok, you can just as easy resurface it. Shouldn't cost more than $20 at any automotive machine shop worth thier name. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Mon Apr 24, 2017 8:03 am Post subject: Re: ecotec sandrail major issue |
Also flywheel bolt are 'ONE TIME' only, ... "Torque to yield" ... Do not reuse as the are stretched and torque values are skewed if trying to reuse....
https://en.wikipedia.org/wiki/Torque-to-yield_fastener
Posted: Mon Apr 24, 2017 4:12 pm Post subject: Re: ecotec sandrail major issue |
B Ramsey wrote: |
VagNaToOtH wrote: |
B Ramsey wrote: |
let see some photos of what you're working with, to better help. |
no burn outs all i did was go around the block they broke then i put it all back together went down the trail maybe 15 mins and its grenaded i |
Posted: Mon Apr 24, 2017 4:14 pm Post subject: Re: ecotec sandrail major issue |
manufacturer says the bolts supplied are grade 10.9 |
Posted: Mon Apr 24, 2017 4:16 pm Post subject: Re: ecotec sandrail major issue |
oh and thank you all for your help!!! |
Posted: Mon Apr 24, 2017 4:22 pm Post subject: Re: ecotec sandrail major issue |
yes sir both sets of bolts where brandy new |
pallen Samba Member
Posted: Thu Apr 27, 2017 6:12 pm Post subject: Re: ecotec sandrail major issue |
so what iv come up with is the clutch wasnt strong enough to hold at high rpm and made everything super hot and soft also found cracks in flywheel between the bolt holes so im working on getting the proper clutch and a new flywheel and ill keep ya posted |
race-desert Samba Member
Posted: Thu Apr 27, 2017 9:01 pm Post subject: Re: ecotec sandrail major issue |
I run a kenedy stage 2 with 33 tires.. |
Sandbar Norm Samba Member
Joined: August 02, 2008 Posts: 115 Location: A Sandbar in Fl.
Posted: Fri Apr 28, 2017 7:29 am Post subject: Re: ecotec sandrail major issue |
I also use a kenedy stage 2 with a kush lock disc.
My had some slipping issues and it was the hyd slave cly. not releasing completely.
It had a little bind so I reworked the mounting bracket.
Works good now.
Norm |
Posted: Sat Apr 29, 2017 7:29 am Post subject: Re: ecotec sandrail major issue |
i did not have the kennedy clutch system before. they warrantied the flywheel and i ordered the proper clutch.ill have everything next weekend and will keep yall posted thankyou |
Posted: Tue May 09, 2017 3:36 pm Post subject: Re: ecotec sandrail major issue |
ok got all the parts yesterday and put her together some lastnight and finished her up tonight send some prayers my way this will be round 3 will drive it this weekend
