New2me69 Samba Member
Posted: Sun Apr 23, 2017 7:02 pm Post subject: Is there a seal here? |
Just removed my manifold and looking in it looks like the old seal is still there? Am I correct? Or is that part of the head.
Do I need to pick this out before putting new seal in?
beetlenut Samba Member
Posted: Sun Apr 23, 2017 7:07 pm Post subject: Re: Is there a seal here? |
I haven't worked on a single port before, but that looks like a copper "O" ring that crushes when you tighten down on it. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Yes, it's copper pick it out and replace it |
Zundfolge1432 Samba Member
Posted: Sun Apr 23, 2017 7:35 pm Post subject: Re: Is there a seal here? |
They are not always copper here's a few new ones. Look at the new one and notice how it's made, place the open side facing down. Inspect the contact area of intake manifold and lightly polish with 400 Emory paper for a good seal and you may install this seal slightly wet with sealant like aviation permatex Perfect seal no leaks
Posted: Sun Apr 23, 2017 9:19 pm Post subject: Re: Is there a seal here? |
Thanks guys. That's what I was thinking.
Any tips on how to get it out. Pick the only way? I moved on to other stuff while I waited for a response.
Much appreciated.
Got some seized up tin screws to drill out which really sucks.
Figured out a few issues while dismantling stuff back there though. Should run much nicer when back together..................I hope.
Posted: Mon Apr 24, 2017 6:04 am Post subject: Re: Is there a seal here? |
New2me69 wrote: |
Much appreciated.
I just did this yesterday! Those tin screws are hardened steel, and not fun to drill out. If there is any of the screw threads sticking out the back side of the tin, what worked for me was to grind two flats on either side of the remaining screw threads so that you can get some vicegrips to grab on. Then I heated the broken tin screw and surrounding metal, and slowly worked, tightening and untightening the broken tin screw, until it broke loose and unscrewed. No drilling required. _________________ scrapyards are for quitters
Wetstuff wrote: |
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Mon Apr 24, 2017 6:40 am Post subject: Re: Is there a seal here? |
Zundfolge1432 wrote: |
I thought the seals faced up when you install them? |
Maddel Samba Member
Posted: Mon Apr 24, 2017 7:00 am Post subject: Re: Is there a seal here? |
eashc wrote: |
...Look at the new one and notice how it's made, place the open side facing down... |
He's talking about the "seam" (or splice) of the squish seal ring I guess...
It should face down towards the cylinder head. |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Mon Apr 24, 2017 7:28 am Post subject: Re: Is there a seal here? |
Pry it up w/ a small flat blade screwdriver, dental pick, etc.
Do not hammer on it.
New2me69 wrote: |
...... Any tips on how to get it out. Pick the only way? |
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Posted: Mon Apr 24, 2017 7:51 am Post subject: Re: Is there a seal here? |
If you have a feeler gauge, you could use one of the blades to slip under one side of the old seal and get it started. _________________ scrapyards are for quitters
Wetstuff wrote: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Mon Apr 24, 2017 7:57 am Post subject: Re: Is there a seal here? |
beetlenut wrote: |
If you have a feeler gauge, you could use one of the blades to slip under one side of the old seal and get it started. |
What VW owner doesn't have a $%&#$%^&$# feeler gauge ?
How the #$^&$$^%&*$$ would they adjust the @$^*^%##%&#@ valves otherwise ??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mark tucker Samba Member
Posted: Mon Apr 24, 2017 8:12 am Post subject: Re: Is there a seal here? |
keep all the dirt&grit outa there too.it's a intake crush gasket, not a oil seal. |
Posted: Mon Apr 24, 2017 8:24 am Post subject: Re: Is there a seal here? |
mark tucker wrote: |
For sure. I know that one. Doing the absolute best I can there for sure. |
Posted: Mon Apr 24, 2017 8:27 am Post subject: Re: Is there a seal here? |
Cusser wrote: |
beetlenut wrote: |
How the #$^&$$^%&*$$ would they adjust the @$^*^%##%&#@ valves otherwise ??? |
Wasn't sure how new school or old school he was. Not much use for a feeler gauge on new engines today. And based on some of the questions on this forum, I'd bet there are some VW owners that don't! _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Mon Apr 24, 2017 8:33 am Post subject: Re: Is there a seal here? |
beetlenut wrote: |
Cusser wrote: |
beetlenut wrote: |
Wasn't sure how new school or old school he was. Not much use for a feeler gauge on new engines today. And based on some of the questions on this forum, I'd bet there are some VW owners that don't! |
I have gauges. My valves get adjusted. |
Posted: Mon Apr 24, 2017 8:34 am Post subject: Re: Is there a seal here? |
This works well
Cusser Samba Member
