leec Samba Member
Posted: Mon Apr 24, 2017 1:44 am Post subject: 67 door, on 64 notch? |
I have a type 3 1967 door, will it work with an early door catch? (on b pillar)
Thanks,
Lee |
leec Samba Member
Posted: Mon Apr 24, 2017 1:48 pm Post subject: Re: 67 door, on 64 notch? |
Anyone? |
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3686 Location: San Jose, CA
Posted: Mon Apr 24, 2017 4:16 pm Post subject: Re: 67 door, on 64 notch? |
All Notchbacks used 3-bolt hinges. 1961-1966 Type 3s used a particular door latch and striker plate. 1967 was a one year only latch, and used a certain striker plate (1967-1971) as well.
Short answer: No. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Mon Apr 24, 2017 5:33 pm Post subject: Re: 67 door, on 64 notch? |
squaretobehip wrote: |
Short answer: No. |
Don't forget all Notchbacks (61-73) used 3 bolt hinges, while Fastbacks and Squares used 2 bolt hinges from 66 to 73. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
leec Samba Member
Posted: Mon Apr 24, 2017 11:40 pm Post subject: Re: 67 door, on 64 notch? |
Thanks guys,
Just to confirm the hinge end is all sorted. Basically what I have are 67 only nos doors that I am wanting to fit to a 64 shell. I have the 67 only inner door workings but wasn't sure if they would be compatible with the early latch on the 64 notch b pillar. The car is a Ron lummus tube chassis race car so originality is not hugely important.
Could I adapt the early door catch in any way?
Lee |
Posted: Tue Apr 25, 2017 8:44 am Post subject: Re: 67 door, on 64 notch? |
Bobnotch wrote: |
All Notchbacks used 3-bolt hinges. |
Don't forget all Notchbacks (61-73) used 3 bolt hinges, while Fastbacks and Squares used 2 bolt hinges from 66 to 73. |
There are 3-bolt '66 Fastbacks & Squarebacks. The three bolt hinge went up to Ch. No. 316 218 359 on those models. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
Posted: Tue Apr 25, 2017 7:01 pm Post subject: Re: 67 door, on 64 notch? |
Bobnotch wrote: |
There are 3-bolt '66 Fastbacks & Squarebacks. The three bolt hinge went up to Ch. No. 316 218 359 on those models. |
Yes, I know that, but I was trying to simplify it for the OP. Especially since you're only dealing with a half year of Squares only, since all Fastbacks came with 2 bolt hinges. That is unless someone has a 3 bolt door set up on a Fastback and has pics of it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Apr 26, 2017 9:16 am Post subject: Re: 67 door, on 64 notch? |
Bobnotch wrote: |
Especially since you're only dealing with a half year of Squares only, since all Fastbacks came with 2 bolt hinges. That is unless someone has a 3 bolt door set up on a Fastback and has pics of it. |
I believe you're correct about all Fastbacks being 2-bolt from '66. We've had a lot of early '66 3-bolt Squares come through the shop so they're all blurring together. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
miketyp3 Samba Member
Joined: September 04, 2003 Posts: 130 Location: Northampton UK
Posted: Fri May 19, 2017 6:04 am Post subject: Re: 67 door, on 64 notch? |
I know we have discussed this Lee, but there is also a difference between pre 66 and post 66 3 bolt hinges as this pic shows...
Can you spot it? |
Posted: Sat May 20, 2017 1:46 am Post subject: Re: 67 door, on 64 notch? |
miketyp3 wrote: |
Can you spot it? |
Yup. The upper piece is for a 2 bolt door. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
