911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Mon Apr 24, 2017 7:48 am Post subject: Wiper motor woes |
My newly acquired Thing blows number 1 fuse (wipers/turn signals) when I turn on the ignition. Unplugging the wiper wire stopped the fusing blowing, so the problem must be with the wiper motor.
Any idea what I should be looking for? |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Mon Apr 24, 2017 11:18 am Post subject: Re: Wiper motor woes |
Please read all of Post. If your wiper switch is off, you should be looking at the 53a circuit, black/white wire. It is always hot with the ignition on. The wire could be shorted to ground, but not likely, the wire is connected to the connector block and is part of the park switch. The connector block and park switch are one in the same. Most likely the park switch is shorted to ground, It could be broken or damaged. The park switch is under the white plastic cover. You can carefully remove the white cover and inspect the park switch (looks like a set of points) to see if it is broken or damaged. I have the park switch if you need one. One thing you will want to do FIRST is to check and make sure it's NOT you wiper switch. With the ignition off, remove the black/white wire from the wiper motor and tape the brass connector so that it will not short out. Replace the fuse, turn on the ignition and see if you blow a fuse. If not then it is the park switch. If it still blows the fuse, it's the wiper switch or the wire itself. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Apr 24, 2017 12:17 pm Post subject: Re: Wiper motor woes |
Another spot to check is where the wire bundle comes thru the dash- had a grommet there at one time, but if its missing, you might have cut a wire there. gently lift the wire bundle and look for frayed insulation-- this is the "easy" fix. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon Apr 24, 2017 4:38 pm Post subject: Re: Wiper motor woes |
Willaim and Al, thanks for the replies.
I took the black/white wire off the park switch, turned the key on, and the fuse didn't blow.
I'll remove the white cover and inspect the park switch tomorrow, when I have more time. |
