OregonMGReplica52 Samba Member
Posted: Tue Apr 25, 2017 1:22 am Post subject: Carburetor |
My 1974 1600cc dual port motor has a dual barrel holley carb on it. I cannot find any information about it online. My VW has been sitting for a long time and I was going to rebuild the carb. At this point, I'm wondering if it might be worth it just to get a new weber carb so that parts and information will be easier to find in the future. So my question is this: does anyone know anything about this holley carb, or will it make my life easier to go with a weber? Thank you!
I have included a picture of the Holley carb just in case it's useful.
wcfvw69 Samba Purist
Posted: Tue Apr 25, 2017 5:07 am Post subject: Re: Carburetor |
If you're going to purchase a new carb, why not get a original, restored and correct German Solex 34-3 carb? Even better would be to also get a matching, correct distributor for it as well.
http://www.volkzbitz.com/
Tim's carbs are like brand new. The correct air cleaners mount on them too. _________________ Contact me at [email protected]
The Samba member since 2004.
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Tue Apr 25, 2017 5:31 am Post subject: Re: Carburetor |
Looks as though there is remains of fire extinguisher powder. |
Zundfolge1432 Samba Member
Posted: Tue Apr 25, 2017 5:35 am Post subject: Re: Carburetor |
Looks great that will buff right out. |
Posted: Tue Apr 25, 2017 8:15 am Post subject: Re: Carburetor |
i would personally like to go with an aftermarket carb. And yes, thats from an extinguisher. It's seen better days but we're on track to be on the road agin. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76906 Location: Sneaking up behind you
Posted: Tue Apr 25, 2017 8:20 am Post subject: Re: Carburetor |
OregonMGReplica52 wrote: |
i would personally like to go with an aftermarket carb. |
Why?
For a stock engine, a correctly rebuilt German 34PICT-3 would work best. Those aftermarket carbs will not add any real power. _________________ Glenn
Member #1009
#BlueSquare |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Tue Apr 25, 2017 8:26 am Post subject: Re: Carburetor |
Have at it.
Take your pick.
There are a number of options available.
You want a weber buy a weber.
The last time I read a thread about them it got lambasted pretty well.
Be prepared to make it the point of comsumption to your technical prowess getting it to run right.
Apparently it's been discussed, maybe even beat to death, and on file here somewhere.
I believe it was mentioned it is just too big.
So go take your holley into your local auto parts and trade it for a rebuilt.
Oh but perhaps note the jetting and ancillary corrections already made for your application.
Can O worms dude
and chances are whatever you put on it, it probably has an 009 type dist and will haunt you (and us) for eons as you fight unacceptable drivability issues.
ooops there I go again |
Posted: Wed Apr 26, 2017 5:05 am Post subject: Re: Carburetor |
well i figured an aftermarket carb would add power. But if not, I will certainly be looking into a stock one. from what i am coming to understand here I don't want to deal with the headache of getting it squared away with a weber. that holley never seemed to work just right anyway. thanks for the advice y'all! |
jfly Samba Member
Joined: August 27, 2013 Posts: 213 Location: CALDWELL IDAHO
Posted: Wed Apr 26, 2017 8:07 am Post subject: Re: Carburetor |
DeathTrap wrote: |
I have a 34 PICT 3 on my bug (currently my backup carb by EMPI, in the process of rebuilding the SOLEX). I looked through the flyers and manuals and couldn't find anything "consistent" specifying the stock setup for a 1600 DP engine.
So... what was stock? What the 34-3 intended to run with a vacuum dizzy? or 009? _________________ 1973 Super Beetle, aka BUGLY, Daily Driver
SOLD:
1968 VW Beetle, Daily Driver, #68flybug
Photos: http://www.thesamba.com/vw/forum/album_search.php?search_author=jfly |
Posted: Wed Apr 26, 2017 8:29 am Post subject: Re: Carburetor |
[quote="jfly"]
DeathTrap wrote: |
vacuum dizzy? |
I think the word is distributor
And the answer perhaps yes.
depending on year model and carburetor
there are threads and charts somewhere here matching carburetors to distributors |
Posted: Wed Apr 26, 2017 8:48 am Post subject: Re: Carburetor |
jfly wrote: |
So... what was stock? What the 34-3 intended to run with a vacuum dizzy? or 009? |
A 1973 bug would of had a 113905205AN DVDA distributor in it. They are excellent when restored BUT, they need to be matched to the correct German Solex 34-3. The vast majority of the German Solex 34-3's were made for DVDA's. However, some of those carbs were made for SVDA's too. You want to match the correct German 34-3 to the correct distributor. All German Solex carbs have a base flange number on them. Usually on the bottom of the carb or the back of it. It will say something like 325-1 on it. _________________ Contact me at [email protected]
Glenn Mr. 010
jfly wrote: |
34PICT-3 originally came with a vacuum/mechanical and specifically the 0231 170 034. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Apr 26, 2017 9:02 am Post subject: Re: Carburetor |
Glenn wrote: |
jfly wrote: |
34PICT-3 originally came with a vacuum/mechanical and specifically the 0231 170 034. |
Only in 1974 did the German Solex 34-3's come matched to the SVDA for bugs. Prior to that, they were matched to primarily DVDA's 205AJ, 205AN, etc. The 74 German Solex 34-3's had a base flange number in the 400's-1 range. _________________ Contact me at [email protected]
jfly Samba Member
Posted: Wed Apr 26, 2017 11:02 am Post subject: Re: Carburetor |
Thank you, gentlemen.
So for my own purposes and for that of the OP who is probably leaning towards going stock at this point, the distributor (aka dizzy ) and the carburetor need to match.
My current blown engine has a 009 with an EMPI 34-3. My donor engine has a solex 34-3 which I am rebuilding and a vacuum style distributor. The pictures below will clarify. Out of curiosity, can you guys tell what style vacuum distributor is on the donor (second pic)?
First pic isnof my bug with blown engine.
Other pics are of donor showing the carb and distributor.
SOLD:
Posted: Wed Apr 26, 2017 12:06 pm Post subject: Re: Carburetor |
It's a DVDA distributor on the second engine with the original German Solex carb. It will have numbers on the side of that distributor to tell you which model it is. Most often the vacuum cans are blown on the retard side or both sides. You need to get a hand vacuum pump with a gauge which cost $20ish bucks. Hook up the hose to each side of the vacuum can and pump it up and see if the can leaks down at all.
The carb could be sent off to Tim at http://www.volkzbitz.com for his magic. Unless it's a very low mileage engine, the carbs throttle shaft bushings will need to be replaced.
That original DVDA distributor also should be disassembled, inspected and cleaned. They get all gummed up w/dirt and dust and the original 40 plus year old grease in them hardens which can freeze up the advance plate.
Those DVDA's work fantastic when they are restored and are matched to the correct German Solex carb. I sell restored ones or I can restore yours. PM me if interested. _________________ Contact me at [email protected]
