mjtracy Samba Member
Joined: March 22, 2016 Posts: 65 Location: Waynesboro, Virginia
Posted: Wed Apr 26, 2017 6:47 pm Post subject: Hubcap noise |
I've installed stock steel wheels and smootie hubcaps on my '70 beetle. I have a clicking coming from the wheels now. If I take the caps off, no clicking. Was wondering if anybody else has seen this. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Wed Apr 26, 2017 6:56 pm Post subject: Re: Hubcap noise |
A few times.
Check the rivets and clips on the rims? |
Posted: Wed Apr 26, 2017 8:59 pm Post subject: Re: Hubcap noise |
No clips on my rims. They are 4 lug and have four bumps that the caps snap onto. |
Posted: Thu Apr 27, 2017 7:48 am Post subject: Re: Hubcap noise |
Sorry man, I know better than that! Regarding the 4 lug not having the clips and rivets. That kind of thinking comes about after working in the sun all day long!
Could it be the cotter key at the rear nut is moving around?
Speedo cable end hitting?
Wish that I could hear it! |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Thu Apr 27, 2017 7:55 am Post subject: Re: Hubcap noise |
VW_Jimbo wrote: |
Could it be the cotter key at the rear nut is moving around? |
This happened to me once. Give it a check. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
andrewwebb58 Samba Member
Posted: Thu Apr 27, 2017 8:30 am Post subject: Re: Hubcap noise |
Sounds to me like either the rear cotter pins are coming into contact with rear hub caps, or the speedometer cable is coming into contact with the left front hub cap.
It would be super helpful at this point to remove one hub cap at a time, and drive around the block to isolate which wheel the noise is coming from _________________ 1974 Super beetle Lime Green 1600 DP (originally my Grandpa's before he passed)
1995 GMC 1500 4x4
2015 Silverado 4x4 |
Posted: Sun Apr 30, 2017 7:58 pm Post subject: Re: Hubcap noise |
Just to close this out, all hubcaps were 'pinging' and clicking. Nothing on the inside hitting. It seemed to be the steel wheel flexing just enough to make hubcaps ring. My solution was to install some Stick and Seal to the inside of the caps. Problem solved! |
Posted: Sun Apr 30, 2017 9:08 pm Post subject: Re: Hubcap noise |
Wow! Excellent trouble shooting on your behalf. Thanks for posting the solution! |
