What could be causing this?!?!
jingram
jingram is offline
PostPosted: Tue Apr 25, 2017 10:03 am    Post subject: What could be causing this?!?! Reply with quote
So we took the '72 out for a spin yesterday. All stock motor, carb set-up. Was driving fine for a while, then all of a sudden the motor starts max reving. Stopped, turned it off and checked it out. All throttle gear from the pedal, through the accelerator cable, to all of the throttle linkage and springs all seem to be functioning perfectly. But as soon as it starts up the motor redlines RPM's. Nothing seems jammed, disconnected or broken.
What could be causing this? Anybody ever had this happen before, because I sure haven't. Any advice would be helpful.
Thank you in advance.
Joe.
luke9511
luke9511 is offline
PostPosted: Tue Apr 25, 2017 12:22 pm    Post subject: Re: What could be causing this?!?! Reply with quote
i am no expert on vw's or cars in general so take this with a grain of salt but sounds like the carb or something like that is stuck open again take that with a grain of salt
Wildthings
Wildthings is offline
If your carbs are jetted rich a bad vacuum leak can cause it to rev high under no load. Sometimes the engine will rev like crazy and then almost die and then repeat.
williamM
williamM is offline
PostPosted: Tue Apr 25, 2017 6:05 pm    Post subject: Re: What could be causing this?!?! Reply with quote
Embarassed see if your throttle butterfly is still attached to the shaft??
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Spike0180
Spike0180 is offline
PostPosted: Wed Apr 26, 2017 6:38 am    Post subject: Re: What could be causing this?!?! Reply with quote
X2
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
dasdachshund
dasdachshund is offline
PostPosted: Wed Apr 26, 2017 11:45 am    Post subject: Re: What could be causing this?!?! Reply with quote
Wildthings wrote:
.......bad vacuum leak.......
X2
-dasdachshund
jingram
jingram is offline
PostPosted: Wed Apr 26, 2017 1:35 pm    Post subject: Re: What could be causing this?!?! Reply with quote
Thanks for the advice folks!
I checked all vacuum hoses. They seemed in tact.
I will check throttle butterflys next, but it is a dual carb setup so could one, of the two, unattached butterflys be the culprit?
williamM
williamM is offline
PostPosted: Thu Apr 27, 2017 9:16 am    Post subject: Re: What could be causing this?!?! Reply with quote
yes- as it would wedge the throttle open. and feed the balance tube fuel.
Don't step in any!
