Love My Westy Samba Member
Posted: Thu Apr 27, 2017 10:45 am Post subject: Replacing Square Hi Beam |
I am trying to replace my Hi Beam headlamp on my '86 Weekender. It looks like i have to unscrew the headlight adjusters all the way out, but the lower one does not screw out. I don't want to break the plastic parts by forcing anything.
Will someone give me some direction. I have tried a search, and my Bentley only shows the round headlights.
Thanks, Rich |
bluebus86 Banned
Posted: Thu Apr 27, 2017 11:03 am Post subject: Re: Replacing Square Hi Beam |
Love My Westy wrote: |
Thanks, Rich |
dont move the aiming adjustment screws. the small high beam housing is removed with the larger dual beam housing as a unit held together by a steel frame. I recall four screws hold that frame, that frame is held to the body by the four aforementioned screws, the frame holds the two housings and the adjustment screws. once the frame with the two bulb housings is removed, you then have access to change the bulbs.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Apr 27, 2017 11:17 am Post subject: Re: Replacing Square Hi Beam |
bluebus86 wrote: |
Thanks, Rich |
good luck |
I'm not replacing the bulb, the Hi Beam lens is broken and I found a new one. I have removed the housing but the lens is only fastened by the adjusting screws as far as I can tell. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Thu Apr 27, 2017 11:39 am Post subject: Re: Replacing Square Hi Beam |
It looks like I have no choice but to try to remove the adjusters. Can I just turn the back plastic piece to make the tabs slide out through the slots? Since I can't unscrew the lower one, I'll just have to try to loosen it from the back side. |
bluebus86 Banned
Posted: Thu Apr 27, 2017 12:09 pm Post subject: Re: Replacing Square Hi Beam |
the plastic if original is likely brittle now. you might have best luck with appling a bit of lubricant, spray silicone maybe, or wd 40 maybe _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Apr 27, 2017 12:12 pm Post subject: Re: Replacing Square Hi Beam |
I took a pair of pliers and turned the back side 90 degrees and was able to remove the lamp from the mounting plate. Then, carefully, I was able to remove the adjusters from the top, but managed to break a couple of tabs off the lower stationary one. I will try to get it to go together without the two tabs.
Wish me luck! |
Posted: Thu Apr 27, 2017 1:17 pm Post subject: Re: Replacing Square Hi Beam |
Got it all back together. The lower adjuster was loose so I rotated it and it snapped into position with just a slight wiggle. I'll order a new lower adjuster from VC and replace it, but the old one will work for now. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu Apr 27, 2017 2:33 pm Post subject: Re: Replacing Square Hi Beam |
You know these being brittle and so breakable it is worth getting more then one for future needs. _________________ This free advice is worth exactly what you paid for it.
